I'm integrating an external SPI flash W25Q32 with the nRF52840 using the NOR FLASH driver, but it's not functioning properly as the MCU log indicates an MPU error.
I have taken the spi_flash sample and am trying to integrate it into my project, but unfortunately, it's not functioning. I suspect there might be a partition error.
The Log displays the next error:
*** Booting nRF Connect SDK v3.5.99-ncs1 ***
Bluetooth initialized
Mesh initialized
Inicializando NUS-SPP service
Recovered identity for NUS: 1
Advertising successfully started
[00:00:00.001,098] <err> spi_nor: Device id 00 00 00 does not match config 15 40 16
[00:00:00.005,035] <inf> MAIN_THREAD: Initializing...
[00:00:00.019,165] <inf> fs_nvs: 8 Sectors of 4096 bytes
[00:00:00.019,165] <inf> fs_nvs: alloc wra: 7, fb8
[00:00:00.019,195] <inf> fs_nvs: data wra: 7, 58
[00:00:00.019,348] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
36 f0 e5 0e 87 68 48 fb 02 fd 9f 82 cc 32 e5 7b |6....hH. .....2.{
91 b1 5c ed |..\.
[00:00:00.022,827] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.022,857] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:00.022,888] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
[00:00:00.023,315] <inf> bt_hci_core: No ID address. App must call settings_load()
[00:00:00.025,573] <wrn> bt_mesh_access: Unused space in relation list: 1
[00:00:00.318,817] <inf> bt_hci_core: Identity[0]: F6:24:AF:24:B9:8A (random)
[00:00:00.318,908] <inf> bt_hci_core: Identity[1]: F0:21:2E:86:30:2B (random)
[00:00:00.318,939] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x118f, manufacturer 0x0059
[00:00:00.318,969] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x118f
[00:00:00.340,881] <inf> MAIN_THREAD:
spi@40004000 SPI flash testing
[00:00:00.340,881] <inf> MAIN_THREAD: ==========================
[00:00:00.340,911] <inf> MAIN_THREAD:
Perform test on single sector
Test 1: Flash erase
[00:00:00.340,911] <err> os: ***** MPU FAULT *****
[00:00:00.340,942] <err> os: Instruction Access Violation
[00:00:00.340,942] <err> os: r0/a1: 0x00051824 r1/a2: 0x00000000 r2/a3: 0x00001000
[00:00:00.340,972] <err> os: r3/a4: 0x4002f000 r12/ip: 0x20008b00 r14/lr: 0x0001d759
[00:00:00.340,972] <err> os: xpsr: 0x60000000
[00:00:00.341,003] <err> os: Faulting instruction address (r15/pc): 0x4002f000
[00:00:00.341,033] <err> os: >>> ZEPHYR FATAL ERROR 20: Unknown error on CPU 0
[00:00:00.341,064] <err> os: Current thread: 0x20007020 (main)
[00:00:00.554,229] <err> os: Halting system
And also had take a look in the logic lines and this is what I see:
This occurs just before the MCU halting. As you can see the only lines that are working is the CLK and CS.
This is my overlay file:
aliases {
spi-flash0 = &spi1_cs0_flash;
&spi1 {
cs-gpios = <&gpio0 29 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
status = "okay";
spi1_cs0_flash: W25Q32@0 {
compatible = "jedec,spi-nor";
status = "okay";
reg = <0x0>;
spi-hold-cs;
has-dpd;
// wp-gpios = <&gpio0 28 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
// hold-gpios = <&gpio0 4 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
spi-max-frequency = <DT_FREQ_M(1)>;
// label = "W25Q32";
jedec-id = [15 40 16];
size = <4194304>;
&spi1_default {
group1 {
psels = <NRF_PSEL(SPIM_SCK, 0, 31)>,
<NRF_PSEL(SPIM_MISO, 1, 8)>,
<NRF_PSEL(SPIM_MOSI, 0, 30)>;
&spi1_cs0_flash {
partitions {
#address-cells = <1>;
#size-cells = <1>;
ext_storage: partition@0 {
label = "external_storage";
reg = <0x00000000 0x00400000>;
And this is my prj.conf file
# # Copyright (c) 2020 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # CONFIG_NCS_SAMPLES_DEFAULTS=y # Deffered logging helps improve LPN power consumption # when friendship is established. CONFIG_LOG_MODE_DEFERRED=y # General configuration CONFIG_MAIN_STACK_SIZE=4096 CONFIG_HEAP_MEM_POOL_SIZE=2048 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_NVS_LOOKUP_CACHE=y CONFIG_SETTINGS=y CONFIG_SETTINGS_NVS_NAME_CACHE=y CONFIG_HWINFO=y CONFIG_DK_LIBRARY=y CONFIG_PM_SINGLE_IMAGE=y CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x8000 CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE=y # Temperature sensor CONFIG_SENSOR=y CONFIG_TEMP_NRF5=y # Bluetooth configuration CONFIG_BT=y CONFIG_BT_COMPANY_ID=0x0059 CONFIG_BT_DEVICE_NAME="OmegaMesh" CONFIG_BT_L2CAP_TX_BUF_COUNT=8 CONFIG_BT_OBSERVER=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_SETTINGS=y CONFIG_BT_EXT_ADV=y # 5 sets are used by Bluetooth Mesh, 1 is needed for the sample advs. CONFIG_BT_EXT_ADV_MAX_ADV_SET=6 CONFIG_BT_MAX_CONN=3 CONFIG_BT_ID_MAX=2 # Disable unused Bluetooth features # CONFIG_BT_CTLR_DUP_FILTER_LEN=0 CONFIG_BT_CTLR_LE_ENC=n CONFIG_BT_PHY_UPDATE=n CONFIG_BT_CTLR_CHAN_SEL_2=n CONFIG_BT_CTLR_MIN_USED_CHAN=n CONFIG_BT_CTLR_PRIVACY=n # Bluetooth mesh configuration CONFIG_BT_MESH=y CONFIG_BT_MESH_RELAY=y CONFIG_BT_MESH_FRIEND=y CONFIG_BT_MESH_TX_SEG_MAX=32 CONFIG_BT_MESH_RX_SEG_MAX=32 CONFIG_BT_MESH_PB_GATT=y CONFIG_BT_MESH_GATT_PROXY=y CONFIG_BT_MESH_PROXY_USE_DEVICE_NAME=y CONFIG_BT_MESH_DK_PROV=y CONFIG_BT_MESH_NLC_PERF_CONF=y CONFIG_BT_MESH_MODEL_EXTENSION_LIST_SIZE=6 # CONFIG_BT_MESH_PROP_MAXCOUNT CONFIG_BT_MESH_CDB=y CONFIG_BT_MESH_CDB_NODE_COUNT=16 CONFIG_BT_MESH_CDB_SUBNET_COUNT=3 CONFIG_BT_MESH_CDB_APP_KEY_COUNT=3 # Enable the NUS service CONFIG_BT_NUS=y CONFIG_BT_MESH_BATTERY_SRV=y CONFIG_BT_MESH_BATTERY_CLI=y # Enable bonding CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_BT_MESH_SUBNET_COUNT=2 CONFIG_BT_MESH_APP_KEY_COUNT=3 CONFIG_BT_MESH_CRPL=32 CONFIG_BT_MESH_MSG_CACHE_SIZE=64 # CONFIG_BT_MESH_SHELL=y # Bluetooth mesh models CONFIG_BT_MESH_SENSOR_SRV=y CONFIG_BT_MESH_SENSOR_SRV_SENSORS_MAX=5 CONFIG_BT_MESH_SENSOR_CLI=y CONFIG_BT_MESH_SENSOR_USE_LEGACY_SENSOR_VALUE=n CONFIG_BT_MESH_PROP_SRV=y # Debugging CONFIG_BT_MESH_LOG_LEVEL_DBG=y # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_INF=y # Config logger CONFIG_LOG=y # CONFIG_USE_SEGGER_RTT=y CONFIG_LOG_BACKEND_RTT=n CONFIG_LOG_BACKEND_UART=y CONFIG_LOG_PRINTK=n CONFIG_ASSERT=y #External flash CONFIG_SPI=y CONFIG_SPI_NOR=y CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 #debugging CONFIG_RESET_ON_FATAL_ERROR=n CONFIG_THREAD_NAME=y
With the following testing code
#define SPI_FLASH_TEST_REGION_OFFSET 0x0000
#define SPI_FLASH_SECTOR_SIZE 4096
static void single_sector_test(const struct device *flash_dev)
const uint8_t expected[] = { 0x55, 0xaa, 0x66, 0x99 };
const size_t len = sizeof(expected);
uint8_t buf[sizeof(expected)];
int rc;
LOG_INF("\nPerform test on single sector");
/* Write protection needs to be disabled before each write or
* erase, since the flash component turns on write protection
* automatically after completion of write and erase
* operations.
LOG_INF("\nTest 1: Flash erase\n");
/* Full flash erase if SPI_FLASH_TEST_REGION_OFFSET = 0 and
* SPI_FLASH_SECTOR_SIZE = flash size
rc = flash_erase(flash_dev, SPI_FLASH_TEST_REGION_OFFSET,
SPI_FLASH_SECTOR_SIZE);
if (rc != 0) {
LOG_ERR("Flash erase failed! %d\n", rc);
} else {
LOG_INF("Flash erase succeeded!\n");
LOG_INF("\nTest 2: Flash write\n");
LOG_INF("Attempting to write %zu bytes\n", len);
rc = flash_write(flash_dev, SPI_FLASH_TEST_REGION_OFFSET, expected, len);
if (rc != 0) {
LOG_ERR("Flash write failed! %d\n", rc);
return;
memset(buf, 0, len);
rc = flash_read(flash_dev, SPI_FLASH_TEST_REGION_OFFSET, buf, len);
if (rc != 0) {
LOG_ERR("Flash read failed! %d\n", rc);
return;
if (memcmp(expected, buf, len) == 0) {
LOG_INF("Data read matches data written. Good!!\n");
} else {
const uint8_t *wp = expected;
const uint8_t *rp = buf;
const uint8_t *rpe = rp + len;
LOG_ERR("Data read does not match data written!!\n");
while (rp < rpe) {
LOG_INF("%08x wrote %02x read %02x %s\n",
(uint32_t)(SPI_FLASH_TEST_REGION_OFFSET + (rp - buf)),
*wp, *rp, (*rp == *wp) ? "match" : "MISMATCH");
++rp;
++wp;
const struct device *flash_dev = DEVICE_DT_GET(DT_NODELABEL(spi1));
LOG_INF("Initializing...\n");
if (!device_is_ready(flash_dev)) {
LOG_ERR("%s: device not ready.\n", flash_dev->name);
// return 0;
LOG_INF("\n%s SPI flash testing\n", flash_dev->name);
LOG_INF("==========================\n");
single_sector_test(flash_dev);
// app code
What could be happening?
Thanks for advance!
