nRF5340: net core application image signed by another key is booted
I'm developing a firmware based on Zigbee CLI sample and enabled DFU of app core and net core via serial.
Now I am setting a custom key for image signing and checking the verification. Verifing app core application works fine, but verifing net core application does not seem to work.
What I did,
I created a key A for image signing and set it to MCUBoot by CMakeList with
set(mcuboot_CONFIG_BOOT_SIGNATURE_KEY_FILE \"${CMAKE_CURRENT_SOURCE_DIR}/custom_key_dir/image_sign.pem\")
I built my application and flashed it to nRF5340.
Then, I created another key B for image verification testing, set it and built the application again. In this time, I enabled debug log in prj.conf of 892154_rpmsg to be able to confirm the new net core app is booted or not.
I did DFU with app_update.bin signed by key B. After mcumgr image upload was completed, the new app core application couldn't boot. So the verification for app core image worked.
But I did DFU with net_core_app_update.bin signed by key B, the new net core app could boot and log was outputed. I think the verification for net core image did not work.
My questions are,
Does MCUboot verify the net core image?
What should I do to be able to verify for net core image?
sdk v2.4.2
nRF5340
Thanks
    Yes, the network core image is also signed.
    If I build with "west -vvv build ...", I get the following log:
    [227/236] cd /home/bruk/hdd/nrf_connect_sdk/zephyr/samples/hello_world/build/modules/mcuboot && /opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-objcopy --input-target=ihex --output-target=binary --gap-fill=0xff /home/bruk/hdd/nrf_connect_sdk/zephyr/samples/hello_world/build/hci_ipc/zephyr/signed_by_b0_app.hex /home/bruk/hdd/nrf_connect_sdk/zephyr/samples/hello_world/build/zephyr/net_core_app_to_sign.bin && /home/bruk/hdd/nrf_connect_sdk/venv/bin/python /home/bruk/hdd/nrf_connect_sdk/bootloader/mcuboot/scripts/imgtool.py sign --key /home/bruk/hdd/nrf_connect_sdk/bootloader/mcuboot/root-rsa-2048.pem --header-size 0x200 --align 4 --version 0.0.0+0 --pad-header --slot-size 0x78000 /home/bruk/hdd/nrf_connect_sdk/zephyr/samples/hello_world/build/zephyr/net_core_app_to_sign.bin /home/bruk/hdd/nrf_connect_sdk/zephyr/samples/hello_world/build/zephyr/net_core_app_update.bin
    As you can see, it is signed with the MCUboot key, and with the key of the network core bootloader.
    Try to set the key for the network core bootloader as well, with hci_ipc_CONFIG_SB_SIGNING_KEY_FILE
    Sigurd Hellesvik
  • Thank you for your reply.
    I set the key with 802154_rpmsg_CONFIG_SB_SIGNING_KEY_FILE, because i'm using Zigbee not BT.
    Now my CMakeList has
    set(802154_rpmsg_CONFIG_SB_SIGNING_KEY_FILE \"${CMAKE_CURRENT_SOURCE_DIR}/custom_key_dir/image_sign.pem\")
    I tried DFU same as before with this version.
    However, the behavior remains the same. The net core app is able to start after DFU. This is not my expectation...
    Is there something else I'm missing?
    Thank you.
  • Check with "west -vvv build ..." that the keys were really set as you expected.
    If they are set as expected, then we will take a step back, un-assume that this is related to keys and apply some generic debugging to your issue.
  • Thank you for your support.
    I checked with "west -vvv build ..." and its result was "keys were set as I expected".
    Build log of the base firmware with key name image_sign.pem;
    [392/402] cd /D C:\Users\yuk\dev\git\firmware\zigbee_cli\build_1\modules\mcuboot && C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-objcopy.exe --input-target=ihex --output-target=binary --gap-fill=0xff C:/Users/yuk/dev/git/firmware/zigbee_cli/build_1/802154_rpmsg/zephyr/signed_by_b0_app.hex C:/Users/yuk/dev/git/firmware/zigbee_cli/build_1/zephyr/net_core_app_to_sign.bin && C:\Users\yuk\AppData\Local\Programs\Python\Python312\python.exe C:/Users/yuk/ncs/v2.4.2/bootloader/mcuboot/scripts/imgtool.py sign --key C:/Users/yuk/dev/git/firmware/zigbee_cli/custom_key_dir/image_sign.pem --header-size 0x200 --align 4 --version 1.1.0+4 --pad-header --slot-size 0x74000 C:/Users/yuk/dev/git/firmware/zigbee_cli/build_1/zephyr/net_core_app_to_sign.bin C:/Users/yuk/dev/git/firmware/zigbee_cli/build_1/zephyr/net_core_app_update.bin
    Build log of the test firmware for image verification with key test_image_sign.pem;
    [386/402] cd /D C:\Users\yuk\dev\git\firmware\zigbee_cli\build_1\modules\mcuboot && C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-objcopy.exe --input-target=ihex --output-target=binary --gap-fill=0xff C:/Users/yuk/dev/git/firmware/zigbee_cli/build_1/802154_rpmsg/zephyr/signed_by_b0_app.hex C:/Users/yuk/dev/git/firmware/zigbee_cli/build_1/zephyr/net_core_app_to_sign.bin && C:\Users\yuk\AppData\Local\Programs\Python\Python312\python.exe C:/Users/yuk/ncs/v2.4.2/bootloader/mcuboot/scripts/imgtool.py sign --key C:/Users/yuk/dev/git/firmware/zigbee_cli/custom_key_dir/test_image_sign.pem --header-size 0x200 --align 4 --version 1.1.0+6 --pad-header --slot-size 0x74000 C:/Users/yuk/dev/git/firmware/zigbee_cli/build_1/zephyr/net_core_app_to_sign.bin C:/Users/yuk/dev/git/firmware/zigbee_cli/build_1/zephyr/net_core_app_update.bin
    Thank you
  • Then we take a step back:
    The issue is that verification of network core image does not work, right?
    I think we need logs from the bootloaders in this case.
    Can you get those logs, from both cores?
