nRF24LE1 correct timer delay?????
Hello, I'm trying to figure out how to work correctly with timer 0 in the nRF24LE1 microcontroller.
1)The Cclk frequency in my case is 16 MHz
2)Given a fixed limit of 12, we get a 0.75 microseconds delay per 1 tick of the timer.
In the 16-bit timer mode, we have 65536 ticks maximum, which is 65536 * 0.75 = 49152 microseconds = 0.049152 seconds. To set up a fixed delay for me, I use the following calculation:
N = 65536 - (65536 * (X/0.049152))
N - TH0, TL0
X - expected delay
Example: I need a 0.0001 sec delay.
N = 65536 - (65536 * (0.0001 / 0.049152)) = 65402,66666(7) and this means that the exact number will not work. But I found a solution to this problem:
Let's take a look at the numbers close to this: (65536 - 65402) * 0.75 = 100.5  microseconds     (65536 - 65403) * 0.75 = 99.75 microseconds
100.5 - 99.75 = 0.75 microseconds.
It follows from these considerations that in order to calculate the exact delay, we need to change each tick of the timer either by 1 more or by 1 less starting from 65403.
For example, we will switch the LED on the foot P0.1 with a delay of 1 second.
#include <stdio.h>
#include <reg24le1.h>
//10000 * 0.0001 = 1 sec
volatile uint32_t counter = 10000;
volatile uint8_t help_timer = 0;
void timer0_int() interrupt INTERRUPT_T0
    counter--;
    if(help_timer==0)
         help_timer = 1;
        //100.5 us
        TL0 = 0x7A;
        TH0 = 0xFF;
    if(help_timer==1)
        help_timer = 0;
        //99.75 us
        TL0 = 0x7B;
        TH0 = 0xFF;
    if(counter==0)
        counter = 10000;
        help_timer = 0;
        P01=~P01;
        // begin new time from 99.75 us
        TL0 = 0x7B;
        TH0 = 0xFF;
void main()
    P0DIR = 0xFD;
    // begin from 99.75 us
    TL0 = 0x7B;
    TH0 = 0xFF;
    //timer 0 - overflow interrupt and all int enable
    IEN0 = 0x82;
    //timer 0 - 16 bit timer
    TMOD = 0x1;
    //run timer 0
    TR0 = 1;
In the 8-bit timer mode, we have 256 ticks maximum, which is 256 * 0.75 = 192 microseconds = 0.000192 seconds. To set up a fixed delay for me, I use the following calculation:
N = 256 - (256 * (X/0.000192))
N - TH0, TL0
X - expected delay
N = 256 - (256 * (0.0001 / 0.000192)) = 122,66666(7) and this means that the exact number will not work. But I found a solution to this problem:
Let's take a look at the numbers close to this: (256 - 122) * 0.75 = 100.5  microseconds    (256 - 123) * 0.75 = 99.75 microseconds
It follows from these considerations that in order to calculate the exact delay, we need to change each tick of the timer either by 1 more or by 1 less starting from 123.
#include <stdio.h>
    counter--;
    if(help_timer==0)
         help_timer = 1;
        //100.5 us
        TH0 = 0x7A;
    if(help_timer==1)
        help_timer = 0;
        //99.75 us
        TH0 = 0x7B;
    if(counter==0)
        counter = 10000;
        help_timer = 0;
        P01=~P01;
        TH0 = 0x7B;
void main()
    P0DIR = 0xFD;
    TL0 = 0x7B;
    TH0 = 0x7B;
    IEN0 = 0x82;
    //timer 0 - 8 bit timer auto-reload
    TMOD = 0x2;
    //run timer 0
    TR0 = 1;
Is the order of register assignment correct? The documentation for nrf24le1 says that the TF0 flag is cleared automatically.
  • Perhaps my reasoning is completely wrong. The error may be cumulative.
    The first case: 100 - 99.75 = 0.25 us
    The second case: 100.5 - 100 = 0.50 us
    It can be concluded that the error will accumulate at a rate of 1.25 us for every 1000 us.
    Accordingly, if you wait for two cycles of 99.75 and one cycle of 100.5, then the error will not occur.
    #include <stdio.h>
    volatile uint8_t help_timer = 1;
        counter--;
        help_timer++;
        if((help_timer==1) || (help_timer==2))
            //99.75 us
            TL0 = 0x7B;
            TH0 = 0xFF;
        if(help_timer==3)
             help_timer = 0;
            //100.5 us
            TL0 = 0x7A;
            TH0 = 0xFF;
        if(counter==0)
            counter = 10000;
            help_timer = 0;
            P01=~P01;
            TL0 = 0x7B;
            TH0 = 0xFF;
    void main()
        P0DIR = 0xFD;
        TL0 = 0x7B;
        TH0 = 0xFF;
        IEN0 = 0x82;
        TMOD = 0x1;
        //run timer 0
        TR0 = 1;
