Thread Viewer Empty during Debug
I am practicing the intermediate Nordic Academy online course, and I have a problem of the thread viewer.
I have enabled debug, I did everything strictly according to the training materials.
However, I could not make the thread info to display.
6523.inter_less1_exer1.zip
The project is attached here with the build. I really tried everything I could, but none of them worked. I tried using different boards as well, and there was no difference.
Can anyone help me to see if there is anything I overlooked?
Thank you very much in advance!
    Can you post your build/zephyr/.config file?
    Try to put a breakpoint inside main(). Can you see the thread viewer from there?
    Which operating system do you use?
    Sigurd Hellesvik
  • Here is the .config file. I could see the debug info is not set, but I have it in .prj file, that's weird.
    I am using Windows 11.
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    # CONFIG_SPI is not set
    CONFIG_BOARD="nrf52840dk_nrf52840"
    CONFIG_NUM_IRQS=48
    CONFIG_SOC_SERIES="nrf52"
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_SOC="nRF52840_QIAA"
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_HEAP_MEM_POOL_SIZE=0
    CONFIG_ROM_START_OFFSET=0
    CONFIG_PINCTRL=y
    CONFIG_CLOCK_CONTROL=y
    # CONFIG_WATCHDOG is not set
    # CONFIG_RESET is not set
    CONFIG_GPIO=y
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    CONFIG_SERIAL_INIT_PRIORITY=55
    # CONFIG_FPU is not set
    # CONFIG_MBEDTLS is not set
    # CONFIG_MEMC is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_TINYCRYPT is not set
    CONFIG_SERIAL=y
    CONFIG_MAIN_STACK_SIZE=1024
    # CONFIG_SRAM_VECTOR_TABLE is not set
    # CONFIG_USE_DT_CODE_PARTITION is not set
    CONFIG_FLASH_LOAD_OFFSET=0
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_IDLE_STACK_SIZE=320
    # CONFIG_PM_DEVICE is not set
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_MP_MAX_NUM_CPUS=1
    # Devicetree Info
    CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED=y
    CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y
    CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_NFCT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (D:/ncs/v2.6.1/nrf)
    # CONFIG_MBOX is not set
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
    CONFIG_LOG_BUFFER_SIZE=1024
    # CONFIG_INIT_STACKS is not set
    # Nordic nRF Connect
    CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK"
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # Subsystems
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # end of Bootloader
    # Bluetooth Low Energy
    # BLE over nRF RPC
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
    CONFIG_FOTA_DL_TIMEOUT_MIN=15
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_FOTA_POLL is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_ALERT is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
    CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
    # CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
    CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
    # CONFIG_NRF_CLOUD_COAP is not set
    # Send shadow info sections on initial connect (MQTT/CoAP)
    # end of Send shadow info sections on initial connect (MQTT/CoAP)
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LEVEL=3
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=25
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # CONFIG_MPSL_PIN_DEBUG is not set
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    # CONFIG_PARTITION_MANAGER_ENABLED is not set
    CONFIG_SRAM_SIZE=256
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_PATH=""
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x40000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_FMFU_LOG_LEVEL=3
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_AES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_GCM is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_CBC_MAC is not set
    # CONFIG_PSA_WANT_ALG_CMAC is not set
    # CONFIG_PSA_WANT_ALG_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    # CONFIG_PSA_WANT_ALG_SHA_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    # CONFIG_PSA_WANT_ALG_SM3 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
    # CONFIG_PSA_WANT_ALG_MD2 is not set
    # CONFIG_PSA_WANT_ALG_MD4 is not set
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CFB is not set
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_OFB is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_FFDH is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # end of nRF Security
    # Audio Module
    # CONFIG_AUDIO_MODULE_TEST is not set
    CONFIG_AUDIO_MODULE_NAME_SIZE=20
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_MODULE_LOG_LEVEL=3
    # end of Audio Module
    # CONFIG_TRUSTED_STORAGE is not set
    # end of Subsystems
    # CONFIG_WPA_SUPP is not set
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_POSIX_MAX_FDS=4
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # Binary libraries
    # Log levels
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_OFF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_ERR is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_WRN is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_INF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_DBG is not set
    CONFIG_BLE_HCI_VSC_LOG_LEVEL_DEFAULT=y
    CONFIG_BLE_HCI_VSC_LOG_LEVEL=3
    # end of Log levels
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_DISABLE_FLASH_PATCH is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
    CONFIG_FPROTECT_BLOCK_SIZE=0x1000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_MODEM_INFO is not set
    CONFIG_RESET_ON_FATAL_ERROR=y
    # CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_INF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
    CONFIG_FATAL_ERROR_LOG_LEVEL_DEFAULT=y
    CONFIG_FATAL_ERROR_LOG_LEVEL=3
    # CONFIG_SMS is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    # CONFIG_HW_UNIQUE_KEY_LOAD is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
    # CONFIG_MODEM_JWT is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_HW_CC3XX=y
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (D:/ncs/v2.6.1/nrf)
    # mcuboot (D:/ncs/v2.6.1/bootloader/mcuboot)
    # MCUboot
    CONFIG_BOOT_SIGNATURE_KEY_FILE=""
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (D:/ncs/v2.6.1/bootloader/mcuboot)
    # mbedtls (D:/ncs/v2.6.1/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    # PSA RNG support
    # end of PSA RNG support
    # PSA key type support
    # end of PSA key type support
    # PSA AEAD support
    # end of PSA AEAD support
    # PSA MAC support
    # end of PSA MAC support
    # PSA Hash support
    # end of PSA Hash support
    # PSA Cipher support
    # end of PSA Cipher support
    # PSA Key agreement support
    # end of PSA Key agreement support
    # PSA Key derivation support
    # end of PSA Key derivation support
    # PSA Asymmetric support
    # Elliptic Curve type support
    # end of Elliptic Curve type support
    # end of PSA Asymmetric support
    # end of mbedtls (D:/ncs/v2.6.1/modules/crypto/mbedtls)
    # trusted-firmware-m (D:/ncs/v2.6.1/modules/tee/tf-m/trusted-firmware-m)
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (D:/ncs/v2.6.1/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    # cjson (D:/ncs/v2.6.1/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (D:/ncs/v2.6.1/modules/lib/cjson)
    # azure-sdk-for-c (D:/ncs/v2.6.1/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (D:/ncs/v2.6.1/modules/lib/azure-sdk-for-c)
    # cirrus-logic (D:/ncs/v2.6.1/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (D:/ncs/v2.6.1/modules/hal/cirrus-logic)
    # openthread (D:/ncs/v2.6.1/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (D:/ncs/v2.6.1/modules/lib/openthread)
    # memfault-firmware-sdk (D:/ncs/v2.6.1/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (D:/ncs/v2.6.1/modules/lib/memfault-firmware-sdk)
    # canopennode (D:/ncs/v2.6.1/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (D:/ncs/v2.6.1/modules/lib/canopennode)
    # chre (D:/ncs/v2.6.1/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (D:/ncs/v2.6.1/modules/lib/chre)
    # lz4 (D:/ncs/v2.6.1/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (D:/ncs/v2.6.1/modules/lib/lz4)
    # nanopb (D:/ncs/v2.6.1/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (D:/ncs/v2.6.1/modules/lib/nanopb)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (D:/ncs/v2.6.1/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (D:/ncs/v2.6.1/modules/lib/zscilib)
    # cmsis (D:/ncs/v2.6.1/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis (D:/ncs/v2.6.1/modules/hal/cmsis)
    # cmsis-dsp (D:/ncs/v2.6.1/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (D:/ncs/v2.6.1/modules/lib/cmsis-dsp)
    # cmsis-nn (D:/ncs/v2.6.1/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (D:/ncs/v2.6.1/modules/lib/cmsis-nn)
    # fatfs (D:/ncs/v2.6.1/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (D:/ncs/v2.6.1/modules/fs/fatfs)
    # hal_nordic (D:/ncs/v2.6.1/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_RADIO_DRIVER is not set
    # CONFIG_NRF_802154_SER_RADIO is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_PPI_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE0=y
    # CONFIG_NRFX_I2S0 is not set
    # CONFIG_NRFX_NFCT is not set
    # CONFIG_NRFX_NVMC is not set
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    CONFIG_NRFX_PPI=y
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC0 is not set
    # CONFIG_NRFX_QSPI is not set
    # CONFIG_NRFX_RNG is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_RTC2 is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPI0 is not set
    # CONFIG_NRFX_SPI1 is not set
    # CONFIG_NRFX_SPI2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TEMP is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TIMER3 is not set
    # CONFIG_NRFX_TIMER4 is not set
    # CONFIG_NRFX_TWI0 is not set
    # CONFIG_NRFX_TWI1 is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    # CONFIG_NRFX_WDT0 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of hal_nordic (D:/ncs/v2.6.1/modules/hal/nordic)
    CONFIG_ZEPHYR_ST_MODULE=y
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # liblc3 (D:/ncs/v2.6.1/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (D:/ncs/v2.6.1/modules/lib/liblc3)
    # littlefs (D:/ncs/v2.6.1/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (D:/ncs/v2.6.1/modules/fs/littlefs)
    # loramac-node (D:/ncs/v2.6.1/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (D:/ncs/v2.6.1/modules/lib/loramac-node)
    # lvgl (D:/ncs/v2.6.1/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (D:/ncs/v2.6.1/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # picolibc (D:/ncs/v2.6.1/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (D:/ncs/v2.6.1/modules/lib/picolibc)
    # segger (D:/ncs/v2.6.1/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    CONFIG_SEGGER_RTT_SECTION_NONE=y
    # CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    # end of segger (D:/ncs/v2.6.1/modules/debug/segger)
    CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    # uoscore-uedhoc (D:/ncs/v2.6.1/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (D:/ncs/v2.6.1/modules/lib/uoscore-uedhoc)
    # zcbor (D:/ncs/v2.6.1/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (D:/ncs/v2.6.1/modules/lib/zcbor)
    # nrfxlib (D:/ncs/v2.6.1/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    # end of nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # CONFIG_MPSL is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_HAS_HW_NRF_CC3XX=y
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_LC3_PLC_DISABLED is not set
    CONFIG_LC3_ENC_CHAN_MAX=1
    CONFIG_LC3_DEC_CHAN_MAX=1
    # Encoder sample rates
    CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Encoder sample rates
    # Decoder sample rates
    CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Decoder sample rates
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (D:/ncs/v2.6.1/nrfxlib)
    # connectedhomeip (D:/ncs/v2.6.1/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (D:/ncs/v2.6.1/modules/lib/matter)
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_THREAD_STACK_SIZE=8192
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL=3
    CONFIG_WIFI_NM_WPA_SUPPLICANT_DEBUG_LEVEL=6
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD_REVISION="$BOARD_REVISION"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF52840DK_NRF52840=y
    # Board Options
    CONFIG_BOARD_ENABLE_DCDC=y
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    # end of Board Options
    # CONFIG_SOC_SERIES_APOLLO4X is not set
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MPS3 is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_MUSCA_S1 is not set
    # CONFIG_SOC_SERIES_AST10X0 is not set
    # CONFIG_SOC_SERIES_SAMC20 is not set
    # CONFIG_SOC_SERIES_SAMC21 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAML21 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAMR34 is not set
    # CONFIG_SOC_SERIES_SAMR35 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_GD32A50X is not set
    # CONFIG_SOC_SERIES_GD32E10X is not set
    # CONFIG_SOC_SERIES_GD32E50X is not set
    # CONFIG_SOC_SERIES_GD32F3X0 is not set
    # CONFIG_SOC_SERIES_GD32F403 is not set
    # CONFIG_SOC_SERIES_GD32F4XX is not set
    # CONFIG_SOC_SERIES_GD32L23X is not set
    # CONFIG_SOC_SERIES_PSOC_60 is not set
    # CONFIG_SOC_SERIES_PSOC_61 is not set
    # CONFIG_SOC_SERIES_PSOC_62 is not set
    # CONFIG_SOC_SERIES_PSOC_63 is not set
    # CONFIG_SOC_SERIES_PSOC_64 is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_CYCLONE5 is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC172X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    CONFIG_SOC_SERIES_NRF52X=y
    # CONFIG_SOC_SERIES_NRF53X is not set
    # CONFIG_SOC_SERIES_NRF54HX is not set
    # CONFIG_SOC_SERIES_NRF54LX is not set
    # CONFIG_SOC_SERIES_NRF91X is not set
    # CONFIG_SOC_SERIES_NPCX4 is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_NPCX9 is not set
    # CONFIG_SOC_SERIES_M46X is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8ML_M7 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT5XX is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC51U68 is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_SERIES_S32K3XX is not set
    # CONFIG_SOC_SERIES_S32ZE_R52 is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_RA4M1 is not set
    # CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    # CONFIG_SOC_RENESAS_RZT2M is not set
    # CONFIG_SOC_SERIES_DA1469X is not set
    # CONFIG_SOC_SERIES_RP2XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32GG12B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG1B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32BG22 is not set
    # CONFIG_SOC_SERIES_EFR32BG27 is not set
    # CONFIG_SOC_SERIES_EFR32FG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_EFR32MG24 is not set
    # CONFIG_SOC_SERIES_STM32C0X is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H5X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32U5X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_SERIES_STM32WBAX is not set
    # CONFIG_SOC_SERIES_STM32WLX is not set
    # CONFIG_SOC_SERIES_AM62X_M4 is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC13X2X7_CC26X2X7 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_HAS_SWO=y
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_GPIO_INIT_PRIORITY=40
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_ACL=y
    CONFIG_HAS_HW_NRF_CC310=y
    CONFIG_HAS_HW_NRF_CCM=y
    CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_ECB=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE0=y
    CONFIG_HAS_HW_NRF_MWU=y
    CONFIG_HAS_HW_NRF_NFCT=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PPI=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_QSPI=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
    CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
    CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
    CONFIG_HAS_HW_NRF_RNG=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPI1=y
    CONFIG_HAS_HW_NRF_SPIM3=y
    CONFIG_HAS_HW_NRF_SWI0=y
    CONFIG_HAS_HW_NRF_SWI1=y
    CONFIG_HAS_HW_NRF_SWI2=y
    CONFIG_HAS_HW_NRF_SWI3=y
    CONFIG_HAS_HW_NRF_SWI4=y
    CONFIG_HAS_HW_NRF_SWI5=y
    CONFIG_HAS_HW_NRF_TEMP=y
    CONFIG_HAS_HW_NRF_TWI0=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_SOC_NRF52840=y
    # CONFIG_SOC_NRF52805_CAAA is not set
    # CONFIG_SOC_NRF52810_QFAA is not set
    # CONFIG_SOC_NRF52811_QFAA is not set
    # CONFIG_SOC_NRF52820_QDAA is not set
    # CONFIG_SOC_NRF52832_CIAA is not set
    # CONFIG_SOC_NRF52832_QFAA is not set
    # CONFIG_SOC_NRF52832_QFAB is not set
    # CONFIG_SOC_NRF52833_QDAA is not set
    # CONFIG_SOC_NRF52833_QIAA is not set
    # CONFIG_SOC_NRF52840_QFAA is not set
    CONFIG_SOC_NRF52840_QIAA=y
    CONFIG_SOC_DCDC_NRF52X=y
    CONFIG_SOC_DCDC_NRF52X_HV=y
    # CONFIG_GPIO_AS_PINRESET is not set
    CONFIG_NRF_ENABLE_ICACHE=y
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_NRF_STORE_REBOOT_TYPE_GPREGRET is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF52X=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M4=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK=y
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    CONFIG_MPU_STACK_GUARD=y
    # CONFIG_MPU_ALLOW_FLASH_WRITE is not set
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    # CONFIG_SHARED_INTERRUPTS is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    CONFIG_BOOT_BANNER=y
    CONFIG_BOOT_DELAY=0
    CONFIG_THREAD_MONITOR=y
    CONFIG_THREAD_NAME=y
    CONFIG_THREAD_MAX_NAME_LEN=32
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # CONFIG_POLL is not set
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_THREAD_LOCAL_STORAGE=y
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # CONFIG_DEVICE_MUTABLE is not set
    # end of Device Options
    # Virtual Memory Support
    # end of Virtual Memory Support
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    # CONFIG_CACHE is not set
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    CONFIG_CLOCK_CONTROL_NPCX_SUPP_APB4=y
    # CONFIG_CLOCK_CONTROL_NPCX_SUPP_FIU1 is not set
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_RTT_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_GSM_MUX is not set
    # CONFIG_EFI_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_COUNTER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    # CONFIG_ENTROPY_GENERATOR is not set
    # CONFIG_ESPI is not set
    # CONFIG_FLASH is not set
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HWINFO is not set
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_1ST_LEVEL_INTERRUPT_BITS=8
    CONFIG_2ND_LEVEL_INTERRUPT_BITS=8
    CONFIG_3RD_LEVEL_INTERRUPT_BITS=8
    # CONFIG_INTC_ESP32 is not set
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MDIO is not set
    # CONFIG_MFD is not set
    # Miscellaneous Drivers
    # CONFIG_GROVE_LCD_RGB is not set
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_REGULATOR is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    # CONFIG_SMBUS is not set
    # CONFIG_SYSCON is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_NRF_GRTC_TIMER is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
    # CONFIG_NRF_USBD_COMMON is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_REQUIRES_FULL_LIBC is not set
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    # CONFIG_MINIMAL_LIBC is not set
    CONFIG_PICOLIBC=y
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    # CONFIG_PICOLIBC_USE_MODULE is not set
    CONFIG_PICOLIBC_USE_TOOLCHAIN=y
    CONFIG_PICOLIBC_HEAP_SIZE=-2
    # CONFIG_PICOLIBC_IO_FLOAT is not set
    CONFIG_PICOLIBC_IO_LONG_LONG=y
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # Deprecated
    # CONFIG_CPLUSPLUS is not set
    # CONFIG_LIB_CPLUSPLUS is not set
    # end of Deprecated
    # end of C++ Language Support
    # CONFIG_CRC is not set
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # OS Support Library
    # CONFIG_FDTABLE is not set
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    CONFIG_ONOFF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # CONFIG_WINSTREAM is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_REBOOT=y
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    # CONFIG_UTF8 is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    CONFIG_SYS_HEAP_SMALL_ONLY=y
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    # CONFIG_SYS_HEAP_AUTO is not set
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Heap and Memory Allocation
    # end of OS Support Library
    # CONFIG_POSIX_API is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL=3
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_COND_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_COND_LOG_LEVEL=3
    # CONFIG_EVENTFD is not set
    # CONFIG_FNMATCH is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_KEY_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_KEY_LOG_LEVEL=3
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL=3
    # CONFIG_PTHREAD_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_LOG_LEVEL=3
    CONFIG_SEM_VALUE_MAX=32767
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL=3
    # CONFIG_TIMER_LOG_LEVEL_OFF is not set
    # CONFIG_TIMER_LOG_LEVEL_ERR is not set
    # CONFIG_TIMER_LOG_LEVEL_WRN is not set
    # CONFIG_TIMER_LOG_LEVEL_INF is not set
    # CONFIG_TIMER_LOG_LEVEL_DBG is not set
    CONFIG_TIMER_LOG_LEVEL_DEFAULT=y
    CONFIG_TIMER_LOG_LEVEL=3
    # CONFIG_TIMER is not set
    CONFIG_MAX_TIMER_COUNT=5
    CONFIG_TIMER_CREATE_WAIT=100
    CONFIG_TIMER_DELAYTIMER_MAX=20
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_ACPI_HID_LEN_MAX=12
    CONFIG_LIBGCC_RTLIB=y
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    # CONFIG_BT is not set
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_ASSERT is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    CONFIG_DEBUG_THREAD_INFO=y
    # CONFIG_DEBUG_COREDUMP is not set
    # end of Debugging Options
    CONFIG_SEGGER_DEBUGMON=y
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM is not set
    # CONFIG_NVS is not set
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    CONFIG_LOG_BACKEND_RTT=y
    # CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
    CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
    # CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
    CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
    CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
    CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
    CONFIG_LOG_BACKEND_RTT_BUFFER=0
    # CONFIG_LOG_BACKEND_SWO is not set
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1
    CONFIG_LOG_BACKEND_UART_AUTOSTART=y
    CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_DOMAIN_ID=0
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_MEM_UTILIZATION is not set
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    CONFIG_MEM_ATTR=y
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    # CONFIG_NET_BUF is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # end of Power Management
    # Portability
    # end of Portability
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    CONFIG_FLASH_LOAD_SIZE=0
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    CONFIG_SRAM_OFFSET=0
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    # CONFIG_SIZE_OPTIMIZATIONS is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    CONFIG_DEBUG_OPTIMIZATIONS=y
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
  • wj_takumi said:
    Here is the .config file. I could see the debug info is not set, but I have it in .prj file, that's weird.
    Then you likely get an Kconfig Override Warning.
    Do you any of those?
  • I am not sure if I understood it.
    I tried compiling it again, and the log is shared here.
    The log did not show the warning.
  • I updated the .prj file as
    # Copyright (c) 2024 Nordic Semiconductor
    CONFIG_GPIO=y
    CONFIG_LOG=y
    # STEP 1 - Enable debugging
    CONFIG_DEBUG=y
    CONFIG_DEBUG_INFO=y
    I could see CONFIG_DEBUG and CONFIG_DEBUG_INFO are both activated in .config, however the thread viewer still shows nothing.
