So now that I understand the problem with overlapping asserted events on the GPIO port, I can't figure out the correct way to reset the sense field in the GPIOTE_IRQHandler correctly.
I have initialized a couple of input pins like so:
NRF_GPIO->PIN_CNF[PIN_GPIO_REED2] =
(GPIO_PIN_CNF_SENSE_Low << GPIO_PIN_CNF_SENSE_Pos)
| (NRF_GPIO_PIN_PULLUP << GPIO_PIN_CNF_PULL_Pos)
| (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos)
| (GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos);
NRF_GPIO->PIN_CNF[PIN_GPIO_REED1] =
And the interrupt handler is
void GPIOTE_IRQHandler(void)
if (NRF_GPIOTE->EVENTS_PORT != 0) {
NRF_GPIOTE->EVENTS_PORT = 0;
if (!nrf_gpio_pin_read(PIN_GPIO_REED1))
//first reed switch activated - do stuff
if (!nrf_gpio_pin_read(PIN_GPIO_REED2))
//second reed switch activated - do other stuff
//I lose events if these assertions overlap
What additions are necessary to properly toggle the sense field so that the overlapping assertions don't result in lost events?
I don't understand under what conditions each pin's sense value should be toggled appropriately.
