NRFX Oscillator will never allow setting bypass for LFXO
In NRFX Oscillator header, accessing the function
nrf_oscillators_lfxo_bypass_set
 requires the preprocessor macro
NRF_OSCILLATORS_HAS_LFXO_BYPASS
 which in turn requires preprocessor conditional
defined(OSCILLATORS_XOSC32KI_Type)
The problem is that final conditional is using the "defined" preprocessor macro to check if a typedef type exists which AFAIK is not valid usage and will always return false.
Tested using nrfconnect sdk 2.6.1 with a blinky project with CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL
#include <hal/nrf_oscillators.h> and then trying to use the function results in the function declaration being not found even though the NRF5340 has the bypass register.
