Does the nrf5340 audio DK can support the mutichannel USB device?
In the nrf5340_aduio application. I found it support 2 channels both of output(mic signal) and input(audio signal) on the USB device.
But i want to know if it can support mutichannel for the USB devic? for example, support 4 or 6 channel mic signal to PC through USB.
I know if that possible, the driver and the audio process part both need to modify.
But first step i want to modiify the driver part first to make the PC can identify the decice has up to 4 or 6 channels, Even if it is only displayed on a PC, the audio part cannot function properly.
In the default sample, the Windows11 can recognized it:
Then I have tried to add the "mic-channel-c;" to the dt overlay file.
&hs_0 {
    mic-channel-c;
Then the PC seems can recognized the USB audio device, but there is no Advanced page to check the channel:
So can you help me to modify the driver part to make the PC can identify the right number of the channles?
I think if the driver part work well, then i can go to modify the audio processing part.
Thank you very much!
