i'm trying to get an interrupt using sensor lis2dw12 , i have connected my int1 pin of sensor to my gpio 0.10. whenever data is ready it should give me an interrupt
static void trigger_handler(const struct device *dev,
const struct sensor_trigger *trig)
printk("signal\n");
struct sensor_value accel[3];
if (sensor_sample_fetch(dev) < 0)
printk("Sample fetch error\n");
return;
if (sensor_channel_get(dev, SENSOR_CHAN_ACCEL_XYZ, accel) < 0)
printk("Channel get error\n");
return;
printk("Acceleration (m/s^2): x: %f, y: %f, z: %f\n",
sensor_value_to_double(&accel[0]),
sensor_value_to_double(&accel[1]),
sensor_value_to_double(&accel[2]));
void main(void)
const struct device *dev = DEVICE_DT_GET(DT_INST(0, st_lis2dw12));
if (dev == NULL)
printk("Could not get LIS2DW12 device\n");
return;
struct sensor_trigger trig = {
.type = SENSOR_TRIG_DATA_READY,
.chan = SENSOR_CHAN_ACCEL_XYZ,
if (sensor_trigger_set(dev, &trig, trigger_handler) < 0)
printk("Unable to set trigger\n");
return;
while (1)
return;
}this is my code
and
&i2c0 {
status = "okay";
lis2dw12: lis2dw12@19 {
compatible = "st,lis2dw12";
reg = <0x19>;
label = "LIS2DW12";
int-pin = <1>;
irq-gpios = <&gpio0 10 GPIO_ACTIVE_HIGH>;
wakeup-duration = <3>;
this is my dts file
