Beacon output suddenly stops
Hello.
In the BLE software being developed, the device uses nRF52840, s140 v7.2.0 or v7.3.0, and I am building a system that periodically sends a beacon (ADV_NONCONN_IND) in the peripheral role at the same time as scanning in the central role.
In the software currently under development, after setting a beacon (ADV_NONCONN_IND) and executing ble_advertising_start, the advertisements at the set interval suddenly stops after a while.
The time it takes for the problem to occur varies, ranging from a few hours to several tens of hours, and other functions appear to be working fine even after the problem occurs.
The operation of this device is to continuously perform a sequence of transmitting beacons, connecting in a central role based on advertisements from external devices that capture the beacons, and then disconnecting after communication.
For this reason, the central role frequently start and stop scanning, connects and disconnects, but the peripheral role's beacon output has never stopped since the start advertising.
I believe that the output of ADV_NONCONN_IND started with ble_advertising_start will not stop unless sd_ble_gap_adv_stop is executed, but is it possible that external factors such as SCAN or connection of the central role can stop advertising of peripheral roles?
Also, as a failsafe, we are considering implementing code that monitors the advertisement output and restarts it when the advertisement stops, but is there a way to detect that the ADV_NONCONN_IND has been output to RADIO?
I looked into Radio Notification, but since the event callback can only receive the radio_active state, I determined that it is not possible to capture only the advertisement output in a multi-role operating environment.
Please give me some advice.
best regard.
  • Hello,  Einar.
    > To monitor, perhaps you could use an app_timer instance and reset it every time you get a radio notification?
    I have already done that, and the log I attached last time shows that no events occurred in radio notification for 30 seconds.
    > if there could be an issue with advertising not being restarted after a timeout or a connection (attempt). Could that be the case?
    There are places where advertising is stopped for switching, but when I check the log, it appears that it is not passing through there.
    Just to be sure, I will set the advertising output of the beacon (ADV_NONCONN_IND) and then check whether the issue occurs with software that does not stop it thereafter.
    The SoftDevice is designed to stop scanning on connection, but resume scanning on disconnection.
    Is there anything else I can do besides monitoring the radio notification to get a clue as to what might be going on?
    Best regards.
    I see. Then that could work as a recovery mechanism: if you have not had an radio activity for x amount of time, reset to recover. But this will not address the root cause.
    Sond good. Becase advertising really should not stop by itself (unless there is a timeout, and if so you get an event). And I have not found any other reports of such an issue. So I thin it is hightly likely that the application disables or does not restart advertising when it should.
    I would add extensive loggin everywhere you stop or start advertising, and also log all BLE events (you oculd just log the event ID). Then you could go back in the log when advertising unexpectedly stopped and check if there are any events you did not process or if you did stop (or not start) advertising undexpectedly.
  • Hello,  Einar.
    I was able to capture the log when the phenomenon occurred.
    In conclusion, the point at which advertising stopped and switched is unrelated, and the problem appears to be occurring due to the overlapping timing of sd_ble_gap_scan_start during nrf_ble_scan_on_adv_report and the stop of scanning in the SoftDevice after sd_ble_gap_connect.
    00> @@@ nrf_ble_scan_on_adv_report(949)->sd_ble_gap_scan_start
    00>
    00> ==SCAN_RSP== AdType:FF
    00>  4C 00 01 00 00 00 00 0B  55 55 00 53 00 45 00 43  4F 02 4D
    00>
    00> > Addr:59:D7:5E:C8:C4:3B (Resolvable) RSSI:-36dBm(+0) raw:-36dBm
    00>
    00> @@@ scan_connect_judgement(661)->sd_ble_gap_connect
    00> +++ Connecting +++
    00>
    00>
    00> 01:12:37.9172  > 1BACC0DE-50273-09551615/59:D7:5E:C8:C4:3B (Resolvable) was removed from the rssi moving average buffering list, calc end: elapsed 1000ms.
    00>
    00> *** No radio notification for a while(30000ms).
    So here are my questions.
    In SoftDevice, the scanner stops after sd_ble_gap_connect, but at what point does it stop?
    After CONNECT_IND? After that delay?
    The scanner also stops at BLE_GAP_EVT_ADV_REPORT when an advertisement is received, but at what point does it stop?
    After receiving ADV_IND? Before the ADV_REPORT event?
    From the log, nrf_ble_scan_on_adv_report appears only once after sd_ble_gap_connect, but when is scan_start accepted here?
    For your reference, we have attached below the logs showing successful connection and disconnection.
    00>
    00>
    00> 01:12:28.2542  > Continue moving average calculation with RssiList[0]
    00>
    00> > Addr:59:D7:5E:C8:C4:3B (Resolvable) RSSI:-37dBm(+0) raw:-37dBm
    00>
    00>
    00> @@@ on_connected_evt(160)->sd_ble_gattc_exchange_mtu_request
    00> @@@ data_length_update(89)->sd_ble_gap_data_length_update
    00> 01:12:28.4926  NRF_BLE_SCAN_EVT_CONNECTED(6)
    00> > conn_handle=0, conn_count=1
    00>
    00> @@@ request_process(359)->sd_ble_gattc_primary_services_discover
    00> @@@ queue_process(215)->sd_ble_gattc_primary_services_discover
    00> ble_db_discovery_start: err_code=0
    00>
    00> @@@ ble_evt_handler(1024)->sd_ble_gap_rssi_start
    00>
    00> 01:12:28.5242  BLE_GATTC_EVT_EXCHANGE_MTU_RSP(58)
    00> 01:12:28.5392  BLE_GAP_EVT_DATA_LENGTH_UPDATE(36)
    00> @@@ request_process(366)->sd_ble_gattc_characteristics_discover
    00> 01:12:28.5692  BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP(48)
    00> @@@ request_process(372)->sd_ble_gattc_descriptors_discover
    00> 01:12:28.7040  BLE_DB_DISCOVERY_COMPLETE(0)
    00> 01:12:28.7043  BLE_NUS_C_EVT_DISCOVERY_COMPLETE(0)
    00>
    00> @@@ request_process(353)->sd_ble_gattc_write
    00> 01:12:28.7052  BLE_DB_DISCOVERY_AVAILABLE(3)
    00> [APP] CONNECTED
    00>
        === Part omitted ===
    00> @@@ MdlBLE_en_Disconnect(1711)->sd_ble_gap_disconnect
    00> 01:12:29.8440  BLE_GAP_EVT_DISCONNECTED(17)
    00> > conn_handle=0, conn_count=0, reason=0x16
    00>
    00> @@@ ble_evt_handler(1036)->sd_ble_gap_rssi_stop
    00>
    00> @@@ MdlBLE_vd_ConnectStartReq(1614)->sd_ble_gap_tx_power_set
    00> @@@ nrf_ble_scan_stop(1041)->sd_ble_gap_scan_stop
    00> *** SCAN START ***
    00>
    00>
    Does this information help you determine the cause and solution?
    Incidentally, the beacon (ADV_NONCONN_IND) has not been stopped since the parameters were first set, so it was not possible to determine from the log when it stopped.
    Best regards.
  • Additional information.
    After that, I added logs and tried to reproduce the issue several times, and all of the logs at the time the problem occurred recorded that there were no subsequent BLE events after sd_ble_gap_scan_start after sd_ble_gap_connect.
    Also, in the radio notification event received at the same time, the argument radio_active was notified as 0 twice, and radio_active did not become 1 after that.
    I thought that in Radio Notification, radio_active would alternate between 0 and 1, but is that wrong?
    I have attached a chart capturing radio_active just before the radio stopped using data sampling.
    This means that the ad will likely continue playing until the radio is turned off.
    Judging from these logs, I think the reason why radio stopped is due to a conflict within SoftDevice. Is this correct?
    Best regards.
    Sorry for the late reply. Einar is out of of office, so I will try to look into it.
    I am sorry, but I am a bit confused (and there is a lot of information here). So your beacon is also scanning, and connecting to other devices from time to time, is that correct?
    Will another central also connect to the beacon's advertisement at some point?
    How do you set up your advertising? Does it restart advertising after a connection?
    What do you mean by this? The advertisements have stopped at the end of this graph, right?
    It may happen that if there are too many events coming from the softdevice, that an event is not correctly forwarded to the application. In some cases, that can be e.g. the disconnected event.
    When this occurs, and you detect it, is it still possible to start advertising? What happens if you try to do so?
    Edvin
