Beacon output suddenly stops
Hello.
In the BLE software being developed, the device uses nRF52840, s140 v7.2.0 or v7.3.0, and I am building a system that periodically sends a beacon (ADV_NONCONN_IND) in the peripheral role at the same time as scanning in the central role.
In the software currently under development, after setting a beacon (ADV_NONCONN_IND) and executing ble_advertising_start, the advertisements at the set interval suddenly stops after a while.
The time it takes for the problem to occur varies, ranging from a few hours to several tens of hours, and other functions appear to be working fine even after the problem occurs.
The operation of this device is to continuously perform a sequence of transmitting beacons, connecting in a central role based on advertisements from external devices that capture the beacons, and then disconnecting after communication.
For this reason, the central role frequently start and stop scanning, connects and disconnects, but the peripheral role's beacon output has never stopped since the start advertising.
I believe that the output of ADV_NONCONN_IND started with ble_advertising_start will not stop unless sd_ble_gap_adv_stop is executed, but is it possible that external factors such as SCAN or connection of the central role can stop advertising of peripheral roles?
Also, as a failsafe, we are considering implementing code that monitors the advertisement output and restarts it when the advertisement stops, but is there a way to detect that the ADV_NONCONN_IND has been output to RADIO?
I looked into Radio Notification, but since the event callback can only receive the radio_active state, I determined that it is not possible to capture only the advertisement output in a multi-role operating environment.
Please give me some advice.
best regard.
    Advertising should not just stop by itself. Could it be that a connection was established but in some special cases you do not re-start advertising, for instance? Do you have logging on the device that can shead some information on this?
    As for a workaround, you are right about radio notifications. That will only tell you when the radio is active, but not for what. I would of course suggest to find the root cause and fix that, but as a workaround perhaps you could regularily stop and re-start advertising?
  • Hello,  Einar.
    Sorry for the slight delay in responding due to low reproducibility and another task.
    Subsequent investigation revealed that when this issue occurs, the signal does not reach Radio Notification, so not only advertising but also RADIO stops.
    Attached are excerpt logs, a HEX dump, and a RAM dump from when the problem occurred.
    The heap is initialized with a 1KB incrementing fill pattern, and the stack is initialized with 0xCC by INITIALIZE_STACK.
    Log of the incident.zip
    SD is s140 v7.3.0, the SDK is 17.1.0_ddde560, and the build environment is SES V5.44.
    Best regards.
    I see. Have you confirmed that there is no radio activity?
    Can you check if you always handle SoftDevice asserts in particular and also all SoftDevice events? I ask because critical events should never be missed, so it would be interesting to check if it is possiblet that you loose some events in your application in special cases.
  • Hello,  Einar.
    I confirmed that there is no radio activity by checking that the radio notification event callback is not received for a certain period of time (30sec).
    I believe that asserts that occur in SoftDevices can be trapped with interrupts such as app_error_handler or HardFault, just like in the SDK. Is that correct?
    The main loop continues to run after the Radio Notification has stopped, and still responds on the UART, so it doesn't appear to be asserted.
    What should I monitor to determine why Radio Notification has stopped?
    How can I tell if the SoftDevice is working properly?
    Can you get an idea of ​​the operating status of the SoftDevice from the RAM dump I sent?
    To be honest, I'm at a loss as to what to do, so I'd appreciate it if you could tell me how to identify the cause.
    Best regards.
    Yes, that is correct. If you are using the default error handler from the SDK, this would also detect SoftDevice asserts (and reset for release builds).
    I see.
    To monitor, perhaps you could use an app_timer instance and reset it every time you get a radio notification? If it does not come in time, the app_timer would time out and the timeout handler run, so that you can handle it.
    Generally, the SoftDevice shoud not behave like this. You can moitor things like I sugested, and reset if you detect an issue (you could also use a watchdog instead of a n app timer, and feed the watchdog every time you get a radio notification. And if not, the watchdog would reset).
    No, unfortuantely not.
    This is not an expected issue. To be honest, the SoftDevice is very well tested I do not recall seeing such an issue before. I would be interested in a verification that your application does not stop advertising, or alternatively, if there could be an issue with advertising not being restarted after a timeout or a connection (attempt). Could that be the case? Have you done anything to verify this?
