Beacon output suddenly stops
Hello.
In the BLE software being developed, the device uses nRF52840, s140 v7.2.0 or v7.3.0, and I am building a system that periodically sends a beacon (ADV_NONCONN_IND) in the peripheral role at the same time as scanning in the central role.
In the software currently under development, after setting a beacon (ADV_NONCONN_IND) and executing ble_advertising_start, the advertisements at the set interval suddenly stops after a while.
The time it takes for the problem to occur varies, ranging from a few hours to several tens of hours, and other functions appear to be working fine even after the problem occurs.
The operation of this device is to continuously perform a sequence of transmitting beacons, connecting in a central role based on advertisements from external devices that capture the beacons, and then disconnecting after communication.
For this reason, the central role frequently start and stop scanning, connects and disconnects, but the peripheral role's beacon output has never stopped since the start advertising.
I believe that the output of ADV_NONCONN_IND started with ble_advertising_start will not stop unless sd_ble_gap_adv_stop is executed, but is it possible that external factors such as SCAN or connection of the central role can stop advertising of peripheral roles?
Also, as a failsafe, we are considering implementing code that monitors the advertisement output and restarts it when the advertisement stops, but is there a way to detect that the ADV_NONCONN_IND has been output to RADIO?
I looked into Radio Notification, but since the event callback can only receive the radio_active state, I determined that it is not possible to capture only the advertisement output in a multi-role operating environment.
Please give me some advice.
best regard.
    There was an issue in some SoftDevice versions that coudl cause also important events to be lost if the applications does not pull/process evetns on time. This was fixed in SoftDevice version v7.3.0 though, so I wonder if you can confirm that that is what is used on the failing devices? (You mentionned v7.2.0 as well, where this issue still existed).
    It is regardless important to process SoftDevice events in a timely manner. Do you know more about when this issue occurs? Could it be that the application have not pulled events in a long time due to other activity? And if you use the SoftDvice hanler with app scheduler, could it be that the app scheduler queue is too short, for instance?
  • Hello Einar,
    Currently the SoftDevice version that is having the issue is v7.3.0.
    The most time-consuming BLE event is the process between receiving NRF_BLE_SCAN_EVT_NOT_FOUND(SCAN_RSP) and calling sd_ble_gap_connect (a maximum of about 100 ms).
    Specifically, what should be the upper limit for this event processing time?
    This issues always occurred right after sd_ble_gap_connect in the NRF_BLE_SCAN_EVT_NOT_FOUND event.
    The logs at the time the problem occurred show no evidence of any events other than BLE being active.
    In fact, no BLE events (<debug> nrf_sdh_ble: BLE event: xx) have been issued from the SD card since sd_ble_gap_connect at the time of the problem.
    No, SoftDevice events are set to use interrupts.
    #define NRF_SDH_DISPATCH_MODEL 0
    // <i> NRF_SDH_DISPATCH_MODEL_INTERRUPT: SoftDevice events are passed to the application from the interrupt context.
    FYI, this issues seems to be the same.
    Best regards.
    I see. I understand that this issue is difficult to reproduce, but are you ablet share a project that can reproduce this on a DK (given enough time)?
    Regardgin the other thread that is using the nRF Connect SDK which is using a different Bluetooth stack (though the controller / link layer inherits components from the SoftDevice).
  • Hello Einar,
    I have something to confirm.
    When providing this software, the internal code contains confidential security information, so I would like to ask that you not use it for anything other than bug analysis. Is that okay?
    You can answer this ticket instead of signing an NDA.
    Also, to run it, you will need a PC with a UART connection and two or more Android smartphones.
    If there are no problems with the above, I will send you the currently working set of the software, so please send the recipient's email address to my email address.
    If there are any problems, we will need to create a subset with limited functionality in order to reproduce the phenomenon, so this will take some time, including confirming that the phenomenon can be reproduced with the subset.
    Best regards.
  • Hi Iwasaki,
    We handle all prive support cases confidentlially (not that this is a public case at the moment).
    Is it possibel to reproduce without Android devices? I should be able to obtain one or two for quick testing, though.
    Please make a private support ticket where you refer to this thread. There you can upload your code as a zip file.
    If it is so that this issue is difficult to consisently and fairly quickly reproduce it would be prefrable if it is possible to reproduce it usign a simpler setup. A simple setup is also benefisial for narrowing down the root cause of the issue. (We can of course inspect the code and see if we see somehting suspicious also without having been able to reproduce it on our end).
    Br,
    Einar
