I am trying to set up unit tests for a new zephyr project on the nrf9160. I don't want to run them on the device and instead want to run them from the command line.
I have a bare bones project set up that builds for the nrf9160. For testing I created a test directory, new prj.conf, CMakeLists.txt, test main and test_ file to test a simple unit test. I am building it with WSL for native posix with the command
west build --board=native_posix . --pristine=always
It builds successfully and then I navigate to build/zephyr and run zephyr.exe which runs OK, but is says the one test that I added is skipped.
*** Booting Zephyr OS build v3.6.0-4011-g4041a2507d6e *** ------ TESTSUITE SUMMARY START ------ SUITE SKIP - 0.00% [addition_tests]: pass = 0, fail = 0, skip = 1, total = 1 duration = 0.000 seconds - SKIP - [addition_tests.test_addition] duration = 0.000 seconds ------ TESTSUITE SUMMARY END ------ =================================================================== PROJECT EXECUTION SUCCESSFUL
Any idea what I am doing wrong? Below are the files I added
CMakeLists.txt
cmake_minimum_required(VERSION 3.13.1)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(add_unit_tests)
target_sources(app PRIVATE src/test_main.c)
target_sources(app PRIVATE src/test_add.c)
target_sources(app PRIVATE ../src/add.c)
prj.conf
CONFIG_ZTEST=y CONFIG_ZTEST_MOCKING=y
test_main.c
#include <zephyr/kernel.h>
#include <zephyr/ztest.h>
/* Entry point for the test suite */
void test_main(void) {
ztest_run_all(NULL, false, 0, 0);
test_add.c
#include "../../src/add.h"
/* Test function */
void test_addition(void) {
zassert_equal(add(1, 1), 2, "1 + 1 should equal 2");
zassert_equal(add(-1, 1), 0, "-1 + 1 should equal 0");
zassert_equal(add(0, 0), 0, "0 + 0 should equal 0");
/* Register the test case */
ZTEST(addition_tests, test_addition) {
test_addition();
/* Test suite registration */
ZTEST_SUITE(addition_tests, NULL, NULL, NULL, NULL, NULL);
add.c
#include "add.h"
/* Function to be tested */
int add(int a, int b) {
return a + b;
