Hi,all
I need to connect BLE via NFC,but I do not know which example should i use to start。and i am a new field of NFC ,is there some document about NFC?thank you a lot !!
nRF5_SDK_17.1.0_ddde560
Hi,all
Hi!
thank you for you nice answer, i used this sample: nRF5_SDK_17.1.0_ddde560\examples\ble_peripheral\experimental\ble_app_hrs_nfc_pairing\pca10040.
Q1: it seems can bond between nrf52832 and smart phone ,but if i turn off the board,and turn on the board again ,it can not atuo conneted to the smart phone,is some config should i do? or the APP on smart phone should config something?
Q2:is there any function to test the antenna performance,output some value ,like RSSI? Aim to optimize the antenna for a better sensing distance
thank you a lot!!
ycp said:Q1: it seems can bond between nrf52832 and smart phone ,but if i turn off the board,and turn on the board again ,it can not atuo conneted to the smart phone,is some config should i do? or the APP on smart phone should config something?
If you have your own android app, then you have the autoConnect parameter in connectGatt() you can set to true
ycp said:Q2:is there any function to test the antenna performance,output some value ,like RSSI? Aim to optimize the antenna for a better sensing distance
It's already tuned on the DK. For custom nRF52 boards, see this white paper for NFC antenna tuning. https://infocenter.nordicsemi.com/topic/nwp_026/WP/nwp_026/nWP_026_intro.html
Thank you,it is vary useful !,
I have Q3:if the board boned with a phone ,next time this phone put on the board again ,will it pair again? i wish it can just connect ,do not pair ,what i should do?
i read the code below,it seems will generate new Authentication OOB Key again.thank you a lot!
* @brief Function for handling NFC events.
* @details Starts advertising and generates new OOB keys on the NFC_T2T_EVENT_FIELD_ON event.
* @param[in] p_context Context for callback execution, not used in this callback implementation.
* @param[in] event Event generated by hal NFC lib.
* @param[in] p_data Received/transmitted data or NULL, not used in this callback implementation.
* @param[in] data_length Size of the received/transmitted packet, not used in this callback implementation.
static void nfc_callback(void * p_context,
nfc_t2t_event_t event,
uint8_t const * p_data,
size_t data_length)
UNUSED_PARAMETER(p_context);
UNUSED_PARAMETER(p_data);
UNUSED_PARAMETER(data_length);
ret_code_t err_code = NRF_SUCCESS;
nfc_pairing_mode_t pairing_mode;
switch (event)
case NFC_T2T_EVENT_FIELD_ON:
NRF_LOG_DEBUG("NFC_EVENT_FIELD_ON");
pairing_mode = nfc_ble_pair_mode_get();
if ((pairing_mode == NFC_PAIRING_MODE_OOB) ||
(pairing_mode == NFC_PAIRING_MODE_GENERIC_OOB))
// Generate Authentication OOB Key and update NDEF message content.
uint8_t length = random_vector_generate(m_oob_auth_key.tk, BLE_GAP_SEC_KEY_LEN);
random_vector_log(length);
err_code = nfc_tk_group_modifier_update(&m_oob_auth_key);
// Start advertising when NFC field is sensed and there is a place for another connection.
if (m_connections < NRF_SDH_BLE_PERIPHERAL_LINK_COUNT)
err_code = ble_advertising_start(m_p_advertising, BLE_ADV_MODE_FAST);
case NFC_T2T_EVENT_FIELD_OFF:
NRF_LOG_DEBUG("NFC_EVENT_FIELD_OFF");
Q4:can I use S332 softdevice to run NFC ? Because the project need ANT+ feature too!
