nRF52840 DK semaphore in uart callback does not work?
I am using https://github.com/NordicDeveloperAcademy/nRF-Connect-SDK-Fundamentals lesson5/fund_less5_exer1 as base. I have set P0.26 as UART RX. Using the code below, I have received the correct UART data at uart callback, code currently commented out at uart_cb and it works.
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <string.h>
/* STEP 3 - Include the header file of the UART driver in main.c */
#include <zephyr/drivers/uart.h>
#include "df2301q.h"
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS   200
/* STEP 10.1.1 - Define the size of the receive buffer */
#define RECEIVE_BUFF_SIZE 13
/* STEP 10.2 - Define the receiving timeout period */
#define RECEIVE_TIMEOUT 1000
#define CONSUMER_STACKSIZE       512
#define CONSUMER_PRIORITY        5
K_SEM_DEFINE(sem, 0, 1);
/* STEP 5.1 - Get the device pointers of the LEDs through gpio_dt_spec */
/* The nRF7002dk has only 2 LEDs so this step uses a compile-time condition to reflect the DK you are building for */
#if defined (CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP)|| defined (CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP_NS)
static const struct gpio_dt_spec led0 = GPIO_DT_SPEC_GET(DT_ALIAS(led0), gpios);
static const struct gpio_dt_spec led1 = GPIO_DT_SPEC_GET(DT_ALIAS(led1), gpios);
#else
static const struct gpio_dt_spec led2 = GPIO_DT_SPEC_GET(DT_ALIAS(led2), gpios);
static const struct gpio_dt_spec led3 = GPIO_DT_SPEC_GET(DT_ALIAS(led3), gpios);
/* STEP 4.1 - Get the device pointer of the UART hardware */
const struct device *uart= DEVICE_DT_GET(DT_NODELABEL(uart0));
/* STEP 9.1 - Define the transmission buffer, which is a buffer to hold the data to be sent over UART */
static uint8_t tx_buf[] =   {"nRF Connect SDK Fundamentals Course\n\r"
                             "Press 1-3 on your keyboard to toggle LEDS 1-3 on your development kit\n\r"};
/* STEP 10.1.2 - Define the receive buffer */
static uint8_t rx_buf[RECEIVE_BUFF_SIZE] = {0};
/* STEP 7 - Define the callback function for UART */
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	switch (evt->type) {
	case UART_RX_RDY:
	k_sem_give(&sem);
	uart_rx_disable(uart);
	if((rx_buf[0] == 0xF4) && (rx_buf[1] == 0xF5))
		if(rx_buf[2] == 0x03)
			if(rx_buf[7] == 0x16)
				gpio_pin_set_dt(&led0, 1);
				gpio_pin_set_dt(&led1, 0);
			else if(rx_buf[7] == 0x17)
				gpio_pin_set_dt(&led0, 0);
				gpio_pin_set_dt(&led1, 1);
		else if(rx_buf[2] == 0x02)
	memset(rx_buf, 0, sizeof(rx_buf));
	uart_rx_enable(dev ,rx_buf,sizeof rx_buf,RECEIVE_TIMEOUT);
	case UART_RX_DISABLED:
//int main(void)
int consumer(void)
	int ret;
/* STEP 4.2 - Verify that the UART device is ready */
	if (!device_is_ready(uart)){
		printk("UART device not ready\r\n");
		return 1 ;
/* STEP 5.2 - Verify that the LED devices are ready */
	if (!device_is_ready(led0.port)){
		printk("GPIO device is not ready\r\n");
		return 1;
	ret = gpio_pin_configure_dt(&led0, GPIO_OUTPUT_INACTIVE);
	if (ret < 0) {
		return 1 ;
	ret = gpio_pin_configure_dt(&led1, GPIO_OUTPUT_INACTIVE);
	if (ret < 0) {
		return 1 ;
	ret = gpio_pin_configure_dt(&led2, GPIO_OUTPUT_INACTIVE);
	if (ret < 0) {
		return 1 ;
	ret = gpio_pin_configure_dt(&led3, GPIO_OUTPUT_INACTIVE);
	if (ret < 0) {
		return 1 ;
/* STEP 8 - Register the UART callback function */
	ret = uart_callback_set(uart, uart_cb, NULL);
	if (ret) {
		return 1;
/* STEP 9.2 - Send the data over UART by calling uart_tx() */
	ret = uart_tx(uart, tx_buf, sizeof(tx_buf), SYS_FOREVER_MS);
	if (ret) {
		return 1;
	while (1) {
		ret = uart_rx_enable(uart ,rx_buf,sizeof rx_buf,RECEIVE_TIMEOUT);
		if (ret) {
			return 1;
		k_sem_take(&sem, K_FOREVER);
		//k_msleep(SLEEP_TIME_MS);
K_THREAD_DEFINE(consumer_id, CONSUMER_STACKSIZE, consumer, NULL, NULL, NULL,
				CONSUMER_PRIORITY, 0, 0);
I would like to process the received uart data at main thread while 1. So, I used semaphore with definition below.
at uart_cb() I call below.
case UART_RX_RDY:
k_sem_give(&sem);
in consumer thread I call below in while(1).
But, it does not work. How do I make this work?
Markel
