Hello, I’m developing application for nRF9160 with Zephyr RTOS.
Currently I want to add a task watchdog module with a hardware watchdog fallback.
I use three threads which task watchdog timeouts are set to 30 seconds, 10 minutes and 30 minutes.
In description of a task_wdt_trigger function in task_wdt.c file, there is an information that CONFIG_TASK_WDT_MIN_TIMEOUT should be set to the minimum task watchdog timeout used in application.
1. What should be CONFIG_TASK_WDT_MIN_TIMEOUT set to if watchdog channels have longer timeout than max CONFIG_TASK_WDT_MIN_TIMEOUT value?
2. Why is CONFIG_TASK_WDT_MIN_TIMEOUT limited to 10000ms if task watchdog timeout can to set any uint32_t value?
