Hi Community,
I report this issue in github, it seems nobody reply me, so I ask here again.
lesson 8 exercise 3 solution build failed · Issue #9 · NordicDeveloperAcademy/ncs-inter (github.com)
regards
Danny
Hi Community,
regards
Danny
Hi
Which version of NCS are you using?
As the thing53 is not on the list of supported boards I would not expect it work without having to do some adjustments yourself. Anyhow could you post your prjf.conf and child_image/hci_rpmsg.conf or hci_ipc.conf depending on NCS version.
Regards
Runar
ncs2.6.0 I`m using.
I just use the default configuration and build it for thingy53.
Here is the link to the github repo:
ncs-inter/lesson8/inter_less8_exer3_solution at main · NordicDeveloperAcademy/ncs-inter (github.com)
Regards
Danny
Hi
What was your build target and are you sure that you did not change anything? Could you try to compile the solution?
It compiles without any problem at my end
Regards
Runar
Sorry, It´s working now. my configuration was wrong. I deleted the issure report.
I used another version of manage SDKs(v2.6.99).
Now Manage toolchains and SDKs are same: v2.6.0. it´s working.
No worries, don't hesitate to open new cases here at devzone if you have any questions
Regards
Runar
