I am able to open up the Cellular Monitor and successrully select the device an get a connection. However the option to ' Open a Serial Terminal' is greyed out, and so not available.
Hi Elfving,
OK, I have installed JLink_V7.94e, and now the 'Open Serial Terminal' widget works (it didn't before), but I'm stll not able to populate the dashboard. Also, when I open the terminal and try to send AT commands to the device, nothing works.
Here's log file:
2024-06-11T16:04:43.474Z INFO Initialising nrfutil module: device
2024-06-11T16:04:43.510Z DEBUG Application data folder: C:\Users\jackw\AppData\Roaming\nrfconnect\pc-nrfconnect-cellularmonitor
2024-06-11T16:04:43.529Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-11T16:04:43.532Z DEBUG App pc-nrfconnect-cellularmonitor v2.4.0 (official)
2024-06-11T16:04:43.532Z DEBUG App path: C:\Users\jackw\.nrfconnect-apps\node_modules\pc-nrfconnect-cellularmonitor
2024-06-11T16:04:43.532Z DEBUG nRFConnect 5.0.0, required by the app is (>=4.4.1)
2024-06-11T16:04:43.532Z DEBUG nRFConnect path: C:\Users\jackw\AppData\Local\Programs\nrfconnect\resources\app.asar
2024-06-11T16:04:43.532Z DEBUG HomeDir: C:\Users\jackw
2024-06-11T16:04:43.532Z DEBUG TmpDir: C:\Users\jackw\AppData\Local\Temp
2024-06-11T16:04:44.657Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-11T16:04:49.748Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-11T16:04:49.754Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-11T16:04:49.894Z INFO Using nrfutil-device core version: 7.11.1
2024-06-11T16:04:50.596Z INFO Using nrfutil-device version: 2.1.1
2024-06-11T16:04:50.596Z INFO Using nrf-device-lib version: 0.17.5
2024-06-11T16:04:50.596Z INFO Using nrfjprog DLL version: 10.24.0
2024-06-11T16:04:50.596Z INFO Using JLink version: JLink_V7.94e
2024-06-11T16:04:50.876Z INFO Getting serialport options from persistent store THINGY91 12PLACEHLDRS.pc-nrfconnect-cellularmonitor
2024-06-11T16:04:50.876Z DEBUG Sending event "cellularmonitor: device connected"
2024-06-11T16:04:52.347Z INFO Selected device with s/n THINGY91 12PLACEHLDRS
2024-06-11T16:04:52.349Z DEBUG Terminal Serial Port: Will attempt to auto-connect to serial port COM6
2024-06-11T16:04:52.352Z DEBUG Sending event "cellularmonitor: device selected"
2024-06-11T16:04:52.357Z INFO Opened port with options: {"path":"COM6","baudRate":115200}
2024-06-11T16:04:53.193Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.4_trace-db.json
2024-06-11T16:04:53.193Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.4-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.193Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.5_trace-db.json
2024-06-11T16:04:53.193Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.5-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.194Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.3_trace-db.json
2024-06-11T16:04:53.194Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.3-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.194Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.7_trace-db.json
2024-06-11T16:04:53.194Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.7-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.194Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.8_trace-db.json
2024-06-11T16:04:53.194Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.8-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.194Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.0_trace-db.json
2024-06-11T16:04:53.195Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.0-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.195Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.1_trace-db.json
2024-06-11T16:04:53.195Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.1-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.195Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.2_trace-db.json
2024-06-11T16:04:53.195Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.2-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.195Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.3_trace-db.json
2024-06-11T16:04:53.195Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.3-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.196Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.4_trace-db.json
2024-06-11T16:04:53.196Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.4-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.196Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.5_trace-db.json
2024-06-11T16:04:53.196Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.5-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.196Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.6_trace-db.json
2024-06-11T16:04:53.196Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.6-FOTA-TEST_trace-db.json
2024-06-11T16:04:53.369Z DEBUG Terminal Serial Port: Could not detect AT Host library
2024-06-11T16:05:22.657Z INFO Started tracefile
2024-06-11T16:05:22.658Z INFO Refreshing dashboard in 5 seconds
2024-06-11T16:05:22.673Z DEBUG Sending event "cellularmonitor: Starting Raw trace"
2024-06-11T16:06:35.370Z DEBUG Sending event "cellularmonitor: Stopping trace"
2024-06-11T16:06:35.372Z INFO Finished tracefile
Here's a link to a screen shot: Cellular Monitor Screen Image.jpg
Here's the log file from the terminal after I attempted to send an AT command to the device:
2024-06-11T16:07:57.035Z INFO Initialising nrfutil module: device
2024-06-11T16:07:57.058Z DEBUG Application data folder: C:\Users\jackw\AppData\Roaming\nrfconnect\pc-nrfconnect-serial-terminal
2024-06-11T16:07:57.084Z DEBUG Sending event "serial-terminal: running nrfutil device"
2024-06-11T16:07:57.084Z DEBUG App pc-nrfconnect-serial-terminal v1.4.0 (official)
2024-06-11T16:07:57.084Z DEBUG App path: C:\Users\jackw\.nrfconnect-apps\node_modules\pc-nrfconnect-serial-terminal
2024-06-11T16:07:57.084Z DEBUG nRFConnect 5.0.0, required by the app is (>=4.4.1)
2024-06-11T16:07:57.084Z DEBUG nRFConnect path: C:\Users\jackw\AppData\Local\Programs\nrfconnect\resources\app.asar
2024-06-11T16:07:57.084Z DEBUG HomeDir: C:\Users\jackw
2024-06-11T16:07:57.084Z DEBUG TmpDir: C:\Users\jackw\AppData\Local\Temp
2024-06-11T16:07:57.782Z DEBUG Sending event "serial-terminal: running nrfutil device"
2024-06-11T16:08:02.566Z DEBUG Sending event "serial-terminal: running nrfutil device"
2024-06-11T16:08:02.575Z DEBUG Sending event "serial-terminal: running nrfutil device"
2024-06-11T16:08:02.706Z INFO Using nrfutil-device core version: 7.11.1
2024-06-11T16:08:03.412Z INFO Using nrfutil-device version: 2.1.1
2024-06-11T16:08:03.412Z INFO Using nrf-device-lib version: 0.17.5
2024-06-11T16:08:03.412Z INFO Using nrfjprog DLL version: 10.24.0
2024-06-11T16:08:03.412Z INFO Using JLink version: JLink_V7.94e
2024-06-11T16:08:03.742Z INFO Device Connected SN:THINGY91 12PLACEHLDRS
2024-06-11T16:08:03.743Z INFO Getting serialport options from persistent store THINGY91 12PLACEHLDRS.pc-nrfconnect-serial-terminal
2024-06-11T16:08:03.746Z DEBUG Sending event "serial-terminal: device connected"
2024-06-11T16:08:03.746Z INFO Selected device with s/n THINGY91 12PLACEHLDRS
2024-06-11T16:08:03.748Z DEBUG Sending event "serial-terminal: device selected"
2024-06-11T16:08:03.758Z INFO Opened port with options: {"path":"COM6","baudRate":115200}
2024-06-11T16:08:03.763Z INFO Get terminal settings from persistent store THINGY91 12PLACEHLDRS.vCom-0.TerminalSettings
2024-06-11T16:11:12.303Z DEBUG The app will need to read the content of C:\Users\jackw\AppData\Roaming\nrfconnect\pc-nrfconnect-serial-terminal\.history, becuase it may not be in-sync with the (in-memory) history buffer.
2024-06-11T16:13:45.962Z DEBUG The app will need to read the content of C:\Users\jackw\AppData\Roaming\nrfconnect\pc-nrfconnect-serial-terminal\.history, becuase it may not be in-sync with the (in-memory) history buffer.
2024-06-11T18:06:33.433Z DEBUG The app will need to read the content of C:\Users\jackw\AppData\Roaming\nrfconnect\pc-nrfconnect-serial-terminal\.history, becuase it may not be in-sync with the (in-memory) history buffer.
Here's a link to a screen shot showing the terminal: Terminal screen shot.jpg
Note that when attempting to send the AT command, nothing happens.
Hi Elfving,
I disconnected the Cellular Monitor from our prototype device and hooked it up to my nRF9160 Dev Kit instead to see if the problem was with our prototype.
I discovered that the Cellular Monitor isn't working with the Dev Kit either.
So something is defiinitely wrong with the nRF Connect for Desktop Cellular Monitor app.
This is a huge problem for me and I really need to get this fixed. I need to be able to use the terminal to send AT Commands to our device for testing purposes. I was able to do that in the old nRF Connect for Desktop app, but I can't make it work in the new Cellular Monitor app.
Please help me fix this.
Elfving,
Please, I need answers. This is taking way too long. It's been 2 1/2 weeks since I opened this ticket and we still haven't solved the problem. Please reply.
Hi Jack,
I am here to help since my college has other tasks to handle. Let's verify if your Cellular Monitor 2.4.0 has issue or not first.
Open Cellular Monitor->ADVANCED OPTIONS->Program device to program your nRF9160 Dev Kit(Is it nRF9160DK or Thingy91?) with Serial LTE Modem firmware.
Now you can test with Cellular Monitor, make sure "Refresh Dashboard on start" is enabled and "Modem Trace database" is set to the MFW version you are using, when "Open Serial Terminal" and wait for device connected, you would be able to see AT commands log in Serial Terminal and Dashboard updated.
Just let me know if you still have problems with Cellular Monitor 2.4.0.
Charlie
Hi Charlie,
Thank you very much for taking over this case.
OK, to start with I opened up the Program Device option and selected the Serial LTE Modem. I then programmed my nRF9160 Dev Kit with the mFW_nrf9160_1.3.5 and with the slm-with-trace.hex application.
2024-06-14T15:41:09.343Z INFO Initialising nrfutil module: device
2024-06-14T15:41:09.396Z DEBUG Application data folder: C:\Users\jackw\AppData\Roaming\nrfconnect\pc-nrfconnect-cellularmonitor
2024-06-14T15:41:09.430Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-14T15:41:09.437Z DEBUG App pc-nrfconnect-cellularmonitor v2.4.0 (official)
2024-06-14T15:41:09.437Z DEBUG App path: C:\Users\jackw\.nrfconnect-apps\node_modules\pc-nrfconnect-cellularmonitor
2024-06-14T15:41:09.437Z DEBUG nRFConnect 5.0.0, required by the app is (>=4.4.1)
2024-06-14T15:41:09.437Z DEBUG nRFConnect path: C:\Users\jackw\AppData\Local\Programs\nrfconnect\resources\app.asar
2024-06-14T15:41:09.437Z DEBUG HomeDir: C:\Users\jackw
2024-06-14T15:41:09.437Z DEBUG TmpDir: C:\Users\jackw\AppData\Local\Temp
2024-06-14T15:41:10.704Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-14T15:41:17.606Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-14T15:41:17.607Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-14T15:41:17.615Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-14T15:41:17.754Z INFO Using nrfutil-device core version: 7.12.0
2024-06-14T15:41:18.415Z INFO Using nrfutil-device version: 2.1.1
2024-06-14T15:41:18.415Z INFO Using nrf-device-lib version: 0.17.5
2024-06-14T15:41:18.415Z INFO Using nrfjprog DLL version: 10.24.0
2024-06-14T15:41:18.415Z INFO Using JLink version: JLink_V7.94e
2024-06-14T15:41:18.671Z INFO Getting serialport options from persistent store 000960000943.pc-nrfconnect-cellularmonitor
2024-06-14T15:41:18.672Z DEBUG Sending event "cellularmonitor: device connected"
2024-06-14T15:41:46.919Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-14T15:41:47.788Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.4_trace-db.json
2024-06-14T15:41:47.789Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.4-FOTA-TEST_trace-db.json
2024-06-14T15:41:47.789Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.5_trace-db.json
2024-06-14T15:41:47.789Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.5-FOTA-TEST_trace-db.json
2024-06-14T15:41:47.789Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.3_trace-db.json
2024-06-14T15:41:47.790Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.3-FOTA-TEST_trace-db.json
2024-06-14T15:41:47.790Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.7_trace-db.json
2024-06-14T15:41:47.790Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.7-FOTA-TEST_trace-db.json
2024-06-14T15:41:47.790Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.8_trace-db.json
2024-06-14T15:41:47.790Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.8-FOTA-TEST_trace-db.json
2024-06-14T15:41:47.790Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.0_trace-db.json
2024-06-14T15:41:47.791Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.0-FOTA-TEST_trace-db.json
2024-06-14T15:41:47.791Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.1_trace-db.json
2024-06-14T15:41:47.791Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.1-FOTA-TEST_trace-db.json
2024-06-14T15:41:47.791Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.2_trace-db.json
2024-06-14T15:41:47.791Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.2-FOTA-TEST_trace-db.json
2024-06-14T15:41:47.791Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.3_trace-db.json
2024-06-14T15:41:47.791Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.3-FOTA-TEST_trace-db.json
2024-06-14T15:41:47.791Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.4_trace-db.json
2024-06-14T15:41:47.791Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.4-FOTA-TEST_trace-db.json
2024-06-14T15:41:47.792Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.5_trace-db.json
2024-06-14T15:41:47.792Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.5-FOTA-TEST_trace-db.json
2024-06-14T15:41:47.792Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.6_trace-db.json
2024-06-14T15:41:47.792Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.6-FOTA-TEST_trace-db.json
2024-06-14T15:41:48.711Z INFO Selected device with s/n 000960000943
2024-06-14T15:41:48.717Z DEBUG Terminal Serial Port: Will attempt to auto-connect to serial port COM3
2024-06-14T15:41:48.717Z DEBUG Sending event "cellularmonitor: device selected"
2024-06-14T15:41:48.722Z INFO Opened port with options: {"path":"COM3","baudRate":115200}
2024-06-14T15:41:49.726Z DEBUG Terminal Serial Port: Could not detect AT Host library
2024-06-14T15:42:50.653Z INFO Sample not found locally, downloading https://developer.nordicsemi.com/.pc-tools/nrfconnect-apps/samples/mfw_nrf9160_1.3.5.zip
2024-06-14T15:42:50.653Z INFO Sample not found locally, downloading https://developer.nordicsemi.com/.pc-tools/nrfconnect-apps/samples/slm-with-trace.hex
2024-06-14T15:42:50.654Z INFO Sample is bundled with app, copying.
2024-06-14T15:42:50.655Z DEBUG Sending event "cellularmonitor: Program sample application"
2024-06-14T15:42:50.663Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-14T15:42:50.668Z INFO Closed port: COM3
2024-06-14T15:42:52.166Z ERROR Error: Failed with exit code 1.
One or more program tasks failed.
Message: Failed, [jlink] INVALID_PARAMETER.
2024-06-14T15:42:52.166Z ERROR Failed with exit code 1.
2024-06-14T15:42:52.166Z ERROR Failed to program a sample
2024-06-14T15:58:11.070Z DEBUG Sending event "cellularmonitor: Program sample application"
2024-06-14T15:58:11.077Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-14T15:58:12.279Z INFO 1/3: 100% - {"chip_erase_mode":"ERASE_ALL","qspi_erase_mode":"ERASE_NONE","reset":"RESET_NONE","verify":"VERIFY_NONE"}
2024-06-14T15:58:12.279Z INFO 2/3: 0% - Uploading image through JLink.
2024-06-14T15:58:57.415Z INFO 3/3: 100% - Uploading image through JLink.
2024-06-14T15:58:58.012Z DEBUG Sending event "cellularmonitor: Program sample application"
2024-06-14T15:58:58.026Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-14T15:58:59.493Z INFO 1/3: 100% - {"chip_erase_mode":"ERASE_ALL","qspi_erase_mode":"ERASE_NONE","reset":"RESET_NONE","verify":"VERIFY_NONE"}
2024-06-14T15:58:59.493Z INFO 2/3: 0% - Uploading image through JLink.
2024-06-14T15:59:01.844Z INFO 3/3: 100% - Uploading image through JLink.
2024-06-14T15:59:02.125Z INFO Programming complete, reseting device.
2024-06-14T15:59:02.144Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-14T15:59:05.144Z DEBUG Terminal Serial Port: Will attempt to auto-connect to serial port COM3
2024-06-14T15:59:05.150Z INFO Opened port with options: {"path":"COM3","baudRate":115200}
2024-06-14T15:59:05.156Z INFO Device is in line mode.
2024-06-14T15:59:05.156Z DEBUG Terminal Serial Port: Detected AT Host Library: Device is in Line mode
2024-06-14T15:59:31.558Z INFO Started tracefile
2024-06-14T15:59:31.558Z INFO Reseting device
2024-06-14T15:59:31.575Z DEBUG Sending event "cellularmonitor: Starting Raw trace"
2024-06-14T15:59:31.582Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2024-06-14T15:59:33.260Z INFO Refreshing dashboard in 5 seconds
2024-06-14T15:59:38.456Z ERROR AT command AT+CPIN? failed:
+CME ERROR:
2024-06-14T15:59:38.462Z ERROR AT command AT+CIMI failed: 13
+CME ERROR
2024-06-14T15:59:38.873Z ERROR AT command AT%XICCID failed:
+CME ERROR: 0
2024-06-14T15:59:38.924Z ERROR AT command AT+CPINR="SIM PIN" failed:
+CME ERROR
2024-06-14T15:59:38.936Z ERROR AT command AT+CPINR="SIM PIN2" failed: : 0
+CME ERROR: 0
2024-06-14T15:59:38.945Z ERROR AT command AT+CPINR="SIM PUK" failed:
+CME ERROR: 0
2024-06-14T15:59:38.955Z ERROR AT command AT+CPINR="SIM PUK2" failed:
+CME ERROR:
2024-06-14T16:00:01.564Z DEBUG Sending event "cellularmonitor: Stopping trace"
2024-06-14T16:00:01.566Z INFO Finished tracefile
2024-06-14T16:10:55.868Z DEBUG Sending event "cellularmonitor: Open file directory"
I get a series of AT command failed messages. See the attached log file.
