I am trying to read the WHO AM I register of an ICM20948 over SPI with nRF52832, but I am getting incorrect values.
I have tried different SPI modes, but none of them work. Later, I tried reading the same register to make sure the module is working with different controllers, and they worked, which means the module is functioning properly.
Instead of expected value 0xEA, I am getting 0xE0 or some other values.
// boards/nrf52dk_nrf52832.overlay
&i2c0 { status = "disabled";};
&i2c1 { status = "disabled";};
&spi1 { status = "disabled";};
my_spi_master: &spi2 {
compatible = "nordic,nrf-spi";
status = "okay";
pinctrl-0 = <&spi_master_default>;
pinctrl-1 = <&spi_master_sleep>;
cs-gpios = <&gpio0 28 GPIO_ACTIVE_LOW>;
reg_my_spi_master: spi-dev-a@0 {
reg = <0>;
&pinctrl {
spi_master_default: spi_master_default {
group1 {
psels = <NRF_PSEL(SPIM_SCK, 0, 25)>,
<NRF_PSEL(SPIM_MOSI, 0, 23)>,
<NRF_PSEL(SPIM_MISO, 0, 24)>;
spi_master_sleep: spi_master_sleep {
group1 {
low-power-enable;
#define MY_SPI_MASTER DT_NODELABEL(my_spi_master)
#define MY_SPI_MASTER_CS_DT_SPEC SPI_CS_GPIOS_DT_SPEC_GET(DT_NODELABEL(reg_my_spi_master))
const struct device *spi_dev;
static struct spi_config spi_cfg = {
// .operation = SPI_TRANSFER_MSB | SPI_WORD_SET(8), // spi mode 0
// .operation = SPI_TRANSFER_MSB | SPI_WORD_SET(8) | SPI_MODE_CPHA, // spi mode 1
// .operation = SPI_TRANSFER_MSB | SPI_WORD_SET(8) | SPI_MODE_CPOL, // spi mode 2
.operation = SPI_TRANSFER_MSB | SPI_WORD_SET(8) | SPI_MODE_CPOL | SPI_MODE_CPHA, // spi mode 3
.frequency = 4000000,
.slave = 0,
.cs = {.gpio = MY_SPI_MASTER_CS_DT_SPEC, .delay = 0},
void read_register(uint8_t reg, uint8_t *data, uint32_t size)
uint8_t tx_buffer[1];
uint8_t rx_buffer[size];
struct spi_buf tx_buf, rx_buf;
tx_buffer[0] = reg;
tx_buf.buf = tx_buffer;
tx_buf.len = 1;
rx_buf.buf = rx_buffer;
rx_buf.len = size;
struct spi_buf_set tx = { .buffers = &tx_buf, .count = 1 };
struct spi_buf_set rx = { .buffers = &rx_buf, .count = 1 };
int ret = spi_transceive(spi_dev, &spi_cfg, &tx, &rx);
if (ret) {
printk("SPI read failed with error code %d\n", ret);
return;
memcpy(data, rx_buffer, size);
void spi_init(void)
spi_dev = DEVICE_DT_GET(MY_SPI_MASTER);
if (!device_is_ready(spi_dev))
printk("SPI master device not ready!\n");
struct gpio_dt_spec spim_cs_gpio = MY_SPI_MASTER_CS_DT_SPEC;
if (!device_is_ready(spim_cs_gpio.port))
printk("SPI master chip select device not ready!\n");
int err;
spi_init();
uint8_t reg;
uint8_t data[2] = {0};
reg = 0x00 | 0x80;
read_register(reg, data, 2);
Also I am getting the following problem in overlay file but I am able to compile and run the code. I restarted the VS Code but the problem persists.
nRF Connect SDK v2.6.1.
