Issue with IMU Sensor (LSM6DSV16X) Sample Rate in Sensor Hub Mode
I am using an IMU sensor in sensor hub mode (LSM6DSV16X, LIS2MDL) with the FIFO interrupt interval set at 30 Hz. The data is sent over BLE. It works perfectly when using RTT, but when I disable debug mode, the sample rate drops to around 1 Hz.
Could someone please help me resolve this issue?
Thank you.
  • Could you please share hardware connection over the I2C.
  • SaeedZadeh said:
    I apologize for the confusion. The IMU_simulation value should be set to 1. This is the only change that needs to be made,
    RTT logging was also disabled. This makes me think there may be other changes as well.
    Regarding the video. Are you saying that the text in the UART terminal on the left is increasing when you enable RTT? It didn't look like it.
    The amount of logs on RTT is higher, yes. Is that what you are saying? That doesn't mean that the sampling is higher. That just depends what you are logging. Also, RTT has a higher throughput than UART.
    I think the video clarified that I am not looking at the same thing as you, so I need some more details on what you mean the issue is.
    BR,
    Edvin
  • Thank you for your attention, Edvin! To clarify, please take a look at the system's block diagram. There are two DK boards.
    Also, to be more intuitive, I'm trying to toggle a pin in a while(1) loop every 20ms. I've noticed that the timing significantly increases when the RTT is not connected but normalizes once I connect the RTT. I've attached a video for your reference.
    	while (1) {
    		ret = gpio_pin_toggle_dt(&signal_pin);
    		if(ret < 0){
    			return 0;
    		k_msleep(20);
    		//k_sleep(K_FOREVER);
    Best,
    Yes. I used nRF Connect for Dekstop -> Bluetooth Low Energy as my central.
    Please zip a project that replicates the issue with the sensor simulation set to true, and RTT logging enabled, and try to unzip it to check that it still replicates the issue using nRF connect for Desktop as the central. If it only reproduces with your specific central application, please upload that as well.
    Then upload the zipped application that requires no modifications to reproduce the issue.
    Edvin
