Issue with IMU Sensor (LSM6DSV16X) Sample Rate in Sensor Hub Mode
I am using an IMU sensor in sensor hub mode (LSM6DSV16X, LIS2MDL) with the FIFO interrupt interval set at 30 Hz. The data is sent over BLE. It works perfectly when using RTT, but when I disable debug mode, the sample rate drops to around 1 Hz.
Could someone please help me resolve this issue?
Thank you.
  • Thank you, Edvin. Your solution resolved the problem, but afterwards, the IMU stopped working for some reason. Therefore, I kept those lines unchanged and made the following adjustments, and everything worked perfectly. However, the IMU's INT2 doesn't work in this situation. Do you have any idea?
    Best,
    CONFIG_RTT_CONSOLE=n
    CONFIG_LOG_BACKEND_RTT=n
  • I don't know what the IMU's INT2 is used for. I assume it is an interrupt pin, but what do you mean by "doesn't work"? Does it not trigger, or does the nRF not detect it?
    Edvin
  • Sorry for the confusion. INT1 and INT2 are the interrupts of the IMU. INT1 triggers the nRF whenever the IMU's FIFO is full, and INT2 is for special actions, such as a tap or a free fall. Here is the entire situations' conclusion:
    1. In the original code where I first encountered the problem, the system worked perfectly with RTT, but when RTT was disconnected, there was a timing delay.
    2. After applying your provided changes, the timing issue was resolved. However, the IMU couldn't trigger the interrupt on the nRF.
      CONFIG_LOG_MODE_DEFERRED=n
      CONFIG_LOG_MODE_IMMEDIATE=n
    3. I have modified the overlay through trial and error. Now, INT1 (FIFO overflow) triggers correctly, but INT2 remains high and doesn't trigger.
    Additionally, I was wondering what might be changing here. I am confident that the IMU's code is correct, as it works in my original code (the one with the timing delay and RTT connected). However, things go wrong when I change the logging configuration in the overlay file. When I observe the signals on the logic analyzer, it seems like the IMU initializes but then stops functioning.
    Thank you,
  • It seems I may have accidentally closed the ticket. I want to make sure my issue is still being considered.
    Thank you
  • Hi Saeed,
    Advin is out-of-office, and I will be with you for now.
    I see that there has been a lot of communication and also the nature of question has been changed.
    Could you summarize the current situation and the code and the setup (connections and measurements), and how can I reproduce it?
    You have mentioned that "things go wrong when I change the logging configuration in the overlay file". Can you show both overlays and describe behaviors? Showing any output / logs would also be helpful.
    Naeem
