Issue with IMU Sensor (LSM6DSV16X) Sample Rate in Sensor Hub Mode
I am using an IMU sensor in sensor hub mode (LSM6DSV16X, LIS2MDL) with the FIFO interrupt interval set at 30 Hz. The data is sent over BLE. It works perfectly when using RTT, but when I disable debug mode, the sample rate drops to around 1 Hz.
Could someone please help me resolve this issue?
Thank you.
  • Hi Naeem,
    I appreciate your consideration.
    This project involves receiving data from the IMU and ADC and transferring it via BLE. The IMU has two interrupts: INT1 for FIFO ready and INT2 for special events like taps.
    INT1 should trigger approximately every 10 ms, which it does when the RTT is connected. However, when I disconnect RTT, the trigger time significantly increases to around 170 ms. This is with the first overlay-debug.conf configuration.
    I followed Edvin's advice and changed the overlay-debug.conf. After the IMU initialization, neither INT1 nor INT2 triggered, and the IMU shut down.
    CONFIG_LOG=y
    CONFIG_LOG_MODE_DEFERRED=n
    CONFIG_LOG_MODE_IMMEDIATE=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=n
    CONFIG_RTT_CONSOLE=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_LOG_PRINTK=n
    # Troubleshooting
    CONFIG_ASSERT=y
    CONFIG_RESET_ON_FATAL_ERROR=n
    CONFIG_MAIN_THREAD_PRIORITY=8
    I then applied the following configuration, which allows INT1 to trigger on time even when RTT is disconnected. However, INT2 does not trigger and remains inactive.
    CONFIG_LOG=y
    CONFIG_CONSOLE=y
    CONFIG_RTT_CONSOLE=n
    CONFIG_LOG_BACKEND_RTT=n
    CONFIG_LOG_PRINTK=n
    # Troubleshooting
    CONFIG_ASSERT=y
    I don't believe the issue lies with the IMU itself, as the only changes I made were to the overlay-debug.conf.
    You canjust download the latest file that I uploaded here and build. Please note that the SDK version is v2.5.2.
    Thank you,
  • Are there any special things with the INT2?
    I see that there are 3 modes in which  sensor could be connected,
    and the role of INT1 is same for all the modes, but INT2 is different.
    I have not used this sensor, but just pointing if that is something to look at.
  • The problem doesn't seem to be with the sensor configuration since I haven't changed anything on the sensor side and get the proper result while the RTT is connected. However, changing the overlay_debug alters the sensor's behavior. I believe there might be an issue with my nRF configuration. What are your thoughts?
    Thsnk you,
  • But this:
    does not make sense then, because the RTT is on the DK / MCU side, and the INT1 is generated by sensor which is already configured, right? How changing (logging) behavior can impact the sensor firing interrupt? I do not know about this sensor configurations.
    Can you print system time when interrupt is generated by the sensor, and then from there we see how much time it is taking between interrupts, so we do not see the logging time but rather interrupt firing time.
    Can you show the changes you made in the overlay?
  • Thank you for your reply.
    This is why I am confused, as I don't change anything in the main code or IMU, but I change the overlay_debug and have a different result.
    Please take a look at the image below. You'll notice that INT1 triggers a ~10 ms interrupt, while INT2 remains high, instead of being low and transitioning to high when an event occurs.
    I changed the following line to "n" and got the above result.
    Best,
    Saeed
