Build fails after update to v2.6.0
I am currently working with NCS v2.0.2 with toochain v2.0.2
I followed the steps in "How to change a workspace application SDK version" update to NCS 2.6.0.
when i build it fails with the following error.
I have modified the revision in west.yml to v2.6.0
Do I need to modify the settings of other files?
Arnold
  • Hello Arnold,
    It looks like you are enabling CONFIG_PM in your board or project configuration. Support for this option was removed in nRF Connect SDK v2.5.0:
     What function should be used instead of pm_state_force(0u, &(const struct pm_state_info){PM_STATE_STANDBY, 0, 0}); in SDK 2.5.0
    Vidar
  • I disable CONFIG_PM in my project configuration.but still have same error.
    So I tried updating to NCS 2.4.0 and still have the same problem
    CMake Error at C:/core3_workspace/zephyr/cmake/modules/kconfig.cmake:339 (message):
      command failed with return code: 1
      C:/core3_workspace/nrf/cmake/modules/kconfig.cmake:29 (include)
      C:/core3_workspace/zephyr/cmake/modules/zephyr_default.cmake:115 (include)
      C:/core3_workspace/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      C:/core3_workspace/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:11 (find_package)
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\v2.0.2\opt\bin\cmake.EXE' '-DWEST_PYTHON=C:\ncs\toolchains\v2.0.2\opt\bin\python.exe' '-BC:\core3_workspace\core3_FW\build' -GNinja '-SC:\core3_workspace\core3_FW\app'
    It seems that version 2.0.2 of cmake is still being executed. Is it possible that there is anything else that needs to be set ?
  • Did you run 'west update' after switching to the v2.4.0 tag to ensure the SDK repositories were updated according to the west manifest?
    /nrf$ git checkout v2.4
    /nrf$ west update
    If so, were there any errors reported for the "west update" command?
  • Yes, I did run west update before you mentioned.
    Arnold@DESKTOP-1DLAP66 MINGW64 /c/core3_workspace/core3_FW (C3L_KLE)
    $ west update
    === updating sdk-nrf (nrf):
    HEAD is now at 0677b0991 manifest: NCS 2.4.0
    === updating zephyr (zephyr):
    HEAD is now at 0933a4b2949 [nrf fromtree] cmake: support snippets scope for `zephyr_get()`
    === updating bsim (tools/bsim):
    HEAD is now at 908ffde west.yaml: Namespace all projects
    === updating hostap (modules/lib/hostap):
    HEAD is now at c54b1efd0 Remove verbose print
    === updating mcuboot (bootloader/mcuboot):
    HEAD is now at d5d451ec [nrf noup] boot: bootutil: Fix bl_secp256r1_validate call
    === updating qcbor (modules/tee/tf-m/qcbor):
    HEAD is now at b0e7033 Make option to compile with warnings on (#162)
    === updating mbedtls (modules/crypto/mbedtls):
    HEAD is now at 829e3edc7 [nrf fromlist] psa_crypto: Fix psa_key_derivation_output_key ECC without builtin keys
    === updating nrfxlib (nrfxlib):
    HEAD is now at c3d4ead5 doc: update versions for 2.4.0 release
    === updating trusted-firmware-m (modules/tee/tf-m/trusted-firmware-m):
    HEAD is now at f0bac9349 [nrf fromtree] platform: nordic_nrf: Add nrf9161 DK and nrf9120 SoC support
    === updating matter (modules/lib/matter):
    HEAD is now at 9e6386ca75 [nrf noup] use CMake command instead of bash in build script
    M       third_party/jsoncpp/repo
    Synchronizing submodule url for 'third_party/nlio/repo'
    Synchronizing submodule url for 'third_party/nlassert/repo'
    Synchronizing submodule url for 'third_party/nlunit-test/repo'
    Synchronizing submodule url for 'third_party/pigweed/repo'
    === updating cjson (modules/lib/cjson):
    HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611)
    === updating azure-sdk-for-c (modules/lib/azure-sdk-for-c):
    HEAD is now at 308c171c [nrf fromlist] Make repository a Zephyr module
    === updating cirrus (modules/hal/cirrus-logic):
    HEAD is now at 9f6b381 sdk-mcu-drivers: Added build system configs and generated files
    === updating openthread (modules/lib/openthread):
    HEAD is now at d9abe3071 [dns-client] new API resolve host and address (#9054)
    === updating cmock (test/cmock):
    HEAD is now at f65066f Merge pull request #404 from tz18/patch-1
    Synchronizing submodule url for 'vendor/c_exception'
    Synchronizing submodule url for 'vendor/unity'
    === updating memfault-firmware-sdk (modules/lib/memfault-firmware-sdk):
    HEAD is now at efd97b9 Memfault Firmware SDK 0.43.3 (Build 2200)
    === updating canopennode (modules/lib/canopennode):
    HEAD is now at dec12fa stack: map CANopenNode crc16_ccitt() to Zephyr crc16_itu_t()
    === updating chre (modules/lib/chre):
    HEAD is now at b7955c27 Merge pull request #7 from stephanosio/require_full_libcpp
    === updating cmsis (modules/hal/cmsis):
    HEAD is now at 74981bf Update DSP library for additional platforms
    === updating edtt (tools/edtt):
    HEAD is now at 64e5105 edttt_bsim: Avoid infinite exception loop
    === updating fatfs (modules/fs/fatfs):
    HEAD is now at 427159b zephyr: fix ffconf.h override use of STRINGIZE
    === updating hal_nordic (modules/hal/nordic):
    HEAD is now at 140140e nrfx: mdk: Fix handling of APPROTECT on nRF91
    === updating hal_st (modules/hal/st):
    HEAD is now at 5948f7b sensor/stmemsc: Align stmemsc i/f to v2.02
    === updating hal_wurthelektronik (modules/hal/wurthelektronik):
    HEAD is now at 24ca987 Initialized WE HAL module repository.
    === updating libmetal (modules/hal/libmetal):
    HEAD is now at efa2ace lib: update libmetal to SHA cd4fb67a4f50
    === updating liblc3 (modules/lib/liblc3):
    HEAD is now at 448f3de Merge pull request #8 from carlescufi/rename
    === updating littlefs (modules/fs/littlefs):
    HEAD is now at ca583fd Merge tag 'v2.5.0' of https://github.com/littlefs-project/littlefs into zephyr
    === updating loramac-node (modules/lib/loramac-node):
    HEAD is now at ce57712f Don't memset the TXRX buffer when radio is set to receive mode (#1345)
    === updating lvgl (modules/lib/gui/lvgl):
    HEAD is now at 1557cb3e zephyr: update SYS_INIT calls
    === updating lz4 (modules/lib/lz4):
    HEAD is now at 8e303c2 zephyr: make this repo a zephyr module
    === updating mipi-sys-t (modules/debug/mipi-sys-t):
    HEAD is now at 0d521d8 mipi_syst_api.c: Change MIPI_SYST_PCFG_PRINTF_ARGBUF_SIZE macro.
    === updating nanopb (modules/lib/nanopb):
    HEAD is now at 42fa8b2 Merge pull request #2 from pdgendt/zephyr
    === updating net-tools (tools/net-tools):
    HEAD is now at e0828aa net-setup: Add instructions for NAT and routing
    === updating nrf_hw_models (modules/bsim_hw_models/nrf_hw_models):
    HEAD is now at bad9877 TEMP: Connect at the top level
    === updating open-amp (modules/lib/open-amp):
    HEAD is now at aedcc26 lib: update open-amp lib to release v2022.10.0
    === updating picolibc (modules/lib/picolibc):
    HEAD is now at 93b5d5f2a Version 1.8.1
    === updating segger (modules/debug/segger):
    HEAD is now at 4bfaf28 zephyr: use external Kconfig
    === updating tinycrypt (modules/crypto/tinycrypt):
    HEAD is now at 3e9a49d cmake: Fix conditional in root CMakeLists.txt
    === updating TraceRecorderSource (modules/debug/TraceRecorder):
    HEAD is now at bc839bf zephyr: update SYS_INIT calls
    === updating tf-m-tests (modules/tee/tf-m/tf-m-tests):
    HEAD is now at 0f80a65 Merge pull request #6 from microbuilder/tfm17_limit_attestation
    === updating psa-arch-tests (modules/tee/tf-m/psa-arch-tests):
    HEAD is now at 6a17330 dev-apis: platform: Increase timeout for nRF devs
    === updating uoscore-uedhoc (modules/lib/uoscore-uedhoc):
    HEAD is now at e892019 Merge pull request #11 from rlubos/zephyr-integration
    === updating zcbor (modules/lib/zcbor):
    HEAD is now at 0556eda Update version from 0.5.99 to 0.6.0
    === updating zscilib (modules/lib/zscilib):
    HEAD is now at 0035be5 Merge pull request #45 from uLipe/feature/qrd_no_recursion
    git is at 2.4.0
    And i have run 'pip3 install west --upgrade' check all requirements.
    $ pip3 install west --upgrade
    Requirement already satisfied: west in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (1.2.0)
    Requirement already satisfied: colorama in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (from west) (0.4.6)
    Requirement already satisfied: PyYAML>=5.1 in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (from west) (5.4.1)
    Requirement already satisfied: pykwalify in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (from west) (1.8.0)
    Requirement already satisfied: setuptools in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (from west) (67.8.0)
    Requirement already satisfied: packaging in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (from west) (20.8)
    Requirement already satisfied: pyparsing>=2.0.2 in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (from packaging->west) (2.4.7)
    Requirement already satisfied: docopt>=0.6.2 in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (from pykwalify->west) (0.6.2)
    Requirement already satisfied: python-dateutil>=2.8.0 in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (from pykwalify->west) (2.8.1)
    Requirement already satisfied: ruamel.yaml>=0.16.0 in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (from pykwalify->west) (0.17.21)
    Requirement already satisfied: six>=1.5 in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (from python-dateutil>=2.8.0->pykwalify->west) (1.15.0)
    Requirement already satisfied: ruamel.yaml.clib>=0.2.6 in c:\ncs\toolchains\31f4403e35\opt\bin\lib\site-packages (from ruamel.yaml>=0.16.0->pykwalify->west) (0.2.6)
  • Thanks. Everything appears correct from the west update output. However, the error message "FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\v2.0.2\opt\bin\cmake.EXE' '-DWEST_PYTHON=C:\ncs\toolchains\v2.0.2\opt\bin\python.exe' '-BC:\core3_workspace\core3_FW\build' -GNinja '-SC:\core3_workspace\core3_FW\app'" and build log  indicate that the build is using the wrong toolchain version.
    Are you opening the bash terminal from the toolchain manager app?
  • No,I'm not using toolchain manager app.I just opening the bash terminal at target folder.
    This is the result of my earlier build. I did not change anything. It seems using the right toolchain version?But still has build fails issues.
  • You can open the Bash terminal via the Toolchain Manager or the Toolchain Terminal profile from the VS Code extension to ensure the environment is set for the toolchain. This includes setting the PYTHONPATH to the Python executable included with the toolchain.
    Alternatively, you can configure the environment in your current shell by running '$ source <(nrfutil toolchain-manager env --as-script)'.
    The Kconfig errors shown in your last screenshot are caused by your application using Kconfig symbols which have been either renamed.
    From the Zephyr v3.3 release notes:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.6.1/zephyr/releases/release-notes-3.3.html
