Hello
I have a project, where I need to have NUS-BLE with firmware update functionality and openthread.
BLE and NUS config:
#*****************************************************************************/ #* Bluetooth & NUS */ #*****************************************************************************/ CONFIG_BT=y CONFIG_BT_PERIPHERAL=y # Enable Dynamic name modification CONFIG_BT_DEVICE_NAME_DYNAMIC=y # Maximum character of the device name CONFIG_BT_DEVICE_NAME_MAX=25 # Only allow one device to connect CONFIG_BT_MAX_CONN=1 CONFIG_BT_MAX_PAIRED=1 # Enable the NUS service CONFIG_BT_NUS=y
FOTA config is:
CONFIG_BOOTLOADER_MCUBOOT=y # TODO: Only use needed config inside this one CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=n # Configs from CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU # Must CONFIG_MCUMGR=y CONFIG_NET_BUF=y CONFIG_ZCBOR=y CONFIG_CRC=y CONFIG_MCUMGR_TRANSPORT_BT=y #Should CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y CONFIG_IMG_MANAGER=y CONFIG_STREAM_FLASH=y CONFIG_FLASH_MAP=y CONFIG_FLASH=y CONFIG_MCUMGR_GRP_IMG=y CONFIG_MCUMGR_GRP_OS=y CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO=y CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y # CONFIG_BT_MAX_CONN=1 in \child_image\multiprotocol_rpmsg.conf needed # Sets MTU-Size to 495bytes, yay! CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=n # Enable updates for the network core # Revert of application core is not possible anymore, because netcore can't be reverted CONFIG_NRF53_UPGRADE_NETWORK_CORE=y CONFIG_UPDATEABLE_IMAGE_NUMBER=2
Thread config is:
#*****************************************************************************/ #* Thread */ #*****************************************************************************/ # Enable CoAP utils and CoAP protocol CONFIG_COAP=y CONFIG_COAP_UTILS=y # Generic networking options CONFIG_NETWORKING=y # L2 OpenThread enabling CONFIG_NET_L2_OPENTHREAD=y # Network shell CONFIG_SHELL=y CONFIG_OPENTHREAD_SHELL=y CONFIG_SHELL_ARGC_MAX=26 CONFIG_SHELL_CMD_BUFF_SIZE=416 # Network sockets CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y CONFIG_NET_SOCKETS_POLL_MAX=4 # Same network Master Key for client and server CONFIG_OPENTHREAD_NETWORKKEY="00:11:22:33:44:55:66:77:88:99:aa:bb:cc:dd:ee:ff" CONFIG_MBEDTLS_SHA1_C=n CONFIG_FPU=y
With this configuration, the rom usage of the net-core overflowes by 4496 bytes.
This is the partition report of the cpunet:
CPUNET flash_primary (0x40000 - 256kB): +--------------------------------------------------+ +---0x1000000: b0n_container (0x8800 - 34kB)-------+ | 0x1000000: b0n (0x8580 - 33kB) | | 0x1008580: provision (0x280 - 640B) | +---0x1008800: app (0x37800 - 222kB)---------------+ | 0x1008800: multiprotocol_rpmsg (0x37800 - 222kB) | +--------------------------------------------------+
I have found the option to set the b0n bootloader to minimal-size with -Dmultiprotocol_rpmsg_b0n_OVERLAY_CONFIG=overlay-minimal-size.conf
But know I get the warning about the anomaly 160:
Should I take this warning for serious, or can I supress this warning?
Another option would be to set CONFIG_ASSERT=n in child_image\multiprotocol_rpmsg.conf
This reduces the used size of the cpunet app by 19.5kB.
Is this the better option, than to have the minimal-size b0n?
Or is it not a good idea to CONFIG_ASSERT=n the cpunet application?
Thank you for your help
Kind regards, Chris
