spi_read function does not work properly
We are testing SPI communication with the nrf5340 Board as the mater and the nrf52840 board as the slave.
The FW applied to nrf5340 is a FW whose normal operation was confirmed through a communication test with other FWs, so I think there is a problem with nrf52840.
prj.conf is
CONFIG_SPI=y
CONFIG_SPI_SLAVE=y
CONFIG_RTT_CONSOLE=y
CONFIG_PRINTK=y
CONFIG_LOG=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_MAIN_STACK_SIZE=4096
nrf52840dk_nrf52840.overlay is
&spi1{
status = "disabled";
&spi3{
&qspi{
my_spi_slave: &spi2 {
compatible = "nordic,nrf-spis";
status = "okay";
pinctrl-0 = <&spi_slave_default>;
pinctrl-1 = <&spi_slave_sleep>;
def-char = 0x00;
spi_slave_default:&spi2_default {
group1 {
psels = <NRF_PSEL(SPIS_SCK, 0, 19)>,
<NRF_PSEL(SPIS_CSN, 0, 17)>,
<NRF_PSEL(SPIS_MOSI, 0, 20)>,
<NRF_PSEL(SPIS_MISO, 0, 21)>;
spi_slave_sleep:&spi2_sleep {
group1 {
low-power-enable;
and the operation code is as follows.
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/spi.h>
#define MY_SPI_SLAVE DT_NODELABEL(my_spi_slave)
// SPI slave functionality
const struct device *spi_slave_dev;
static const struct spi_config spi_slave_cfg = {
.operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB | SPI_OP_MODE_SLAVE ,
.frequency = 4000000;
.slave = 1;
void spi_slave_init(void)
spi_slave_dev = DEVICE_DT_GET(MY_SPI_SLAVE);
if(!device_is_ready(spi_slave_dev)) {
printk("SPI slave device not ready!\n");
static uint8_t slave_rx_buffer[1];
static uint8_t slave_tx_buffer[1] ={2};
int spi_slave_read_test_msg(void)
struct spi_buf s_rx_buf = {
.buf = slave_rx_buffer,
.len = sizeof(slave_rx_buffer);
const struct spi_buf_set s_rx = {
.buffers = &s_rx_buf,
.count = 1
struct spi_buf s_tx_buf = {
.buf = slave_tx_buffer,
.len = sizeof(slave_tx_buffer);
const struct spi_buf_set s_tx = {
.buffers = &s_tx_buf,
.count = 1
printk("1\n");
int error = spi_read(spi_slave_dev, &spi_slave_cfg, &s_rx);
// int error = spi_transceive(spi_slave_dev, &spi_slave_cfg, &s_tx, &s_rx);
if(error < 0){
printk("SPI slave transceive error: %i\n", error);
return error;
} else {
printk("RX recv: %x\n", slave_rx_buffer[0]);
printk("2\n");
printk("RX recv: %d \n", slave_rx_buffer[0]);
return 0;
spi_slave_init();
while(1)
spi_slave_read_test_msg();
k_msleep(10);
return 0;
At this time, the output is as shown below.
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
One
Since "2" is not output, spi_read(spi_slave_dev, &spi_slave_cfg, &s_rx); I think there's a problem with the function, but I'm not sure.
int error = spi_transceive(spi_slave_dev, &spi_slave_cfg, &s_tx, &s_rx); The result is the same even if you use .
For reference, the config of the main function is as follows.
nrfx_spim_config_t config = NRFX_SPIM_DEFAULT_CONFIG(SCK_PIN,
MOSI_PIN,
MISO_PIN;
CS_PIN);
