HI,
I am building an IoT product using NRF58233 ICs.
In which I use 3 PWM channels and 3 ADC channels.
You can review the principle I attached to make sure nothing went wrong. Thanks
HI,
thank you so much. One more question, pin P0.01/XL2 can be used PWM?
The short answer is yes.
As seen in the PSEL.OUT[n] register, every GPIO pin is possible to use with PWM. Some pins are however only recommended for use with "Standard drive, low frequency I/O only", as described in the pin assignments, which could make them less suited for use with PWM. But this is not the case for the P0.01/XL2 pin.
