Bluetooth Observer Parse Advertising Manufacturing Data?
Before, posting I tried this post below, but it did not work for me. It did not print the manufacturing data.
https://devzone.nordicsemi.com/f/nordic-q-a/84753/scan-and-parse-manufacturer-specific-data-zephyr/353544#353544
This is my device Redmi Note 12S from the serial print out.
[DEVICE]: 45:98:2E:F7:04:19 (random), AD evt type 5, Tx Pwr: 127, RSSI -63 Data        status: 0, AD data len: 25 Name: Redmi Note 12S C:0 S:0 D:0 SR:0 E:1 Pri PHY: LE        1M, Sec PHY: LE 1M, Interval: 0x0000 (0 ms), SID: 5
For Bluetooth Advertiser I am using nRF Connect App with these settings below.
Here is my code below based from Bluetooth Observer example program.
prj.conf:
CONFIG_BT=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_EXT_ADV=y
main.c:
#include <zephyr/bluetooth/hci.h>
#define NAME_LEN 30
static void device_found(const bt_addr_le_t *addr, int8_t rssi, uint8_t type,
			 struct net_buf_simple *ad)
	char addr_str[BT_ADDR_LE_STR_LEN];
	bt_addr_le_to_str(addr, addr_str, sizeof(addr_str));
	printk("Device found: %s (RSSI %d), type %u, AD data len %u\n",
	       addr_str, rssi, type, ad->len);
#if defined(CONFIG_BT_EXT_ADV)
static bool data_cb(struct bt_data *data, void *user_data)
	char *name = user_data;
	uint8_t len;
	switch (data->type) {
	case BT_DATA_MANUFACTURER_DATA:
		len = MIN(data->data_len, NAME_LEN - 1);
		memcpy(name, data->data, len);
		name[len] = '\0';
	return false;
	case BT_DATA_NAME_SHORTENED:
	case BT_DATA_NAME_COMPLETE:
		(void)memcpy(name, data->data, len);
		name[len] = '\0';
		return false;
		return true;
static const char *phy2str(uint8_t phy)
	switch (phy) {
	case BT_GAP_LE_PHY_NONE: return "No packets";
	case BT_GAP_LE_PHY_1M: return "LE 1M";
	case BT_GAP_LE_PHY_2M: return "LE 2M";
	case BT_GAP_LE_PHY_CODED: return "LE Coded";
	default: return "Unknown";
static void scan_recv(const struct bt_le_scan_recv_info *info,
		      struct net_buf_simple *buf)
	char le_addr[BT_ADDR_LE_STR_LEN];
	char name[NAME_LEN];
	uint8_t data_status;
	uint16_t data_len;
	(void)memset(name, 0, sizeof(name));
	data_len = buf->len;
	bt_data_parse(buf, data_cb, name);
	data_status = BT_HCI_LE_ADV_EVT_TYPE_DATA_STATUS(info->adv_props);
	bt_addr_le_to_str(info->addr, le_addr, sizeof(le_addr));
	printk("[DEVICE]: %s, AD evt type %u, Tx Pwr: %i, RSSI %i "
	       "Data status: %u, AD data len: %u Name: %s "
	       "C:%u S:%u D:%u SR:%u E:%u Pri PHY: %s, Sec PHY: %s, "
	       "Interval: 0x%04x (%u ms), SID: %u\n",
	       le_addr, info->adv_type, info->tx_power, info->rssi,
	       data_status, data_len, name,
	       (info->adv_props & BT_GAP_ADV_PROP_CONNECTABLE) != 0,
	       (info->adv_props & BT_GAP_ADV_PROP_SCANNABLE) != 0,
	       (info->adv_props & BT_GAP_ADV_PROP_DIRECTED) != 0,
	       (info->adv_props & BT_GAP_ADV_PROP_SCAN_RESPONSE) != 0,
	       (info->adv_props & BT_GAP_ADV_PROP_EXT_ADV) != 0,
	       phy2str(info->primary_phy), phy2str(info->secondary_phy),
	       info->interval, info->interval * 5 / 4, info->sid);
static struct bt_le_scan_cb scan_callbacks = {
	.recv = scan_recv,
#endif /* CONFIG_BT_EXT_ADV */
int observer_start(void)
	struct bt_le_scan_param scan_param = {
		.type       = BT_LE_SCAN_TYPE_PASSIVE,
		.options    = BT_LE_SCAN_OPT_FILTER_DUPLICATE,
		.interval   = BT_GAP_SCAN_FAST_INTERVAL,
		.window     = BT_GAP_SCAN_FAST_WINDOW,
	int err;
	bt_le_scan_cb_register(&scan_callbacks);
	printk("Registered scan callbacks\n");
	err = bt_le_scan_start(&scan_param, device_found);
	if (err) {
		printk("Start scanning failed (err %d)\n", err);
		return err;
	printk("Started scanning...\n");
	return 0;
At data_cb the set data->type is BT_DATA_NAME_COMPLETE. There is no option to set the data->type to BT_DATA_MANUFACTURER_DATA. That is why I am unable to receive the manufacturer data.
Markel
  • Hello Markel,
    The sample you are working on is only looking for the device name, but it should not be a problem to expand it to also look for the BT_DATA_MANUFACTURER_DATA field in the payload. However, you need to return 'true' if the advertisement name is found to continue parsing the payload.
    	uint8_t len;
    		printk("Found manuf. data\n);
    		name[len] = '\0';
    	return false;
    		name[len] = '\0';
    		return true;
    		return true;
    Vidar
  • Hi Vidar,
    It is not possible with current code. The call of bt_data_parse() within scan_recv() is only 1 times. Is there an example program where I can get the advertisement data which includes the manufacturing data.
    	uint16_t data_len;
    I have a working Bluetooth Broadcaster running on nRF52840 DK with advertisement data below.
    /* Define and initialize a variable of type adv_mfg_data_type */
    static adv_mfg_data_type adv_mfg_data = {COMPANY_ID_CODE, 0x00, 0x00, 0x00, 0x00, 0x00};
    static unsigned char url_data[] = { };
    LOG_MODULE_REGISTER(Scoreboard, LOG_LEVEL_INF);
    static const struct bt_data ad[] = {
    	BT_DATA_BYTES(BT_DATA_FLAGS, BT_LE_AD_NO_BREDR),
    	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    	/* Include the Manufacturer Specific Data in the advertising packet. */
    	BT_DATA(BT_DATA_MANUFACTURER_DATA, (unsigned char *)&adv_mfg_data, sizeof(adv_mfg_data)),
    I need to parse this advertisement data at another nRF52840 DK with Bluetooth Observer code running. I already ordered the nRF52840 DK and will arrive next week.
    Markel
  • Hello Markel,
    I'm not sure I follow. Did you change the callback function to return 'True' on BT_DATA_NAME_COMPLETE as I suggested?
    Vidar
  • Hi Vidar,
    It worked following the answer in this post below. But, I think I would need to implement filtering.
    https://devzone.nordicsemi.com/f/nordic-q-a/86216/no-mfg-data-during-scan-response-when-bt_data_parse
    Markel
