I can't seem to get the FIFO to work and I think it is because I'm not dereferencing the consumer thread properly. I have reviewed the nRF Connect SDK Intermediate, data passing and exercise2 FIFO already.
Within the data_item_t struct I am adding another struct. The data seems to go into the structure ok (checked via LOG_INF), but I can't get it out properly... Assuming I did all the FIFO stuff correctly. Any advice on how to dereference, or if I setup FIFO wrong, would be appreciated.
My producer thread creates:
LOG_INF("dcheck: producer thread: cmd: %d uuid: %s d0: %d", tx_data->MYGATE.cmd, tx_data->MYGATE.uuid, tx_data->MYGATE.d0);
[00:00:51.509,948] <inf> esb_child_event_handler: dcheck: producer thread: cmd: 7 uuid: 3BD5142E4BA09B49 d0: 9696110 (this is correct)
My consumer thread:
LOG_INF("dcheck: consumer thread: cmd: %d uuid: %s d0: %d\n", command, rx_data->MYGATE.uuid, rx_data->MYGATE.d0);
//[00:00:44.177,856] <inf> esb_child_event_handler: dcheck: consumer thread: cmd: 181 uuid: d0: 0 (not correct!)
I didn't show it, but I added data to MYGATE which is why the producer LOG_INF has the correct data.
For clarification and testing the data is produced and consumed immediately, so I expect the data to be the same.
typedef struct{
uint8_t cmd; //command
uint8_t chan; //channel number
uint8_t prod; //product: Gate, Wearable, etc
uint8_t isParent; //parent or child
char uuid[HW_ID_LEN]; //processor uuid (char array)
uint32_t d0; //data (integer)
uint32_t d1; //data (integer)
uint32_t d2; //data (integer)
uint32_t d3; //data (integer)
uint32_t d4; //data (integer)
uint32_t d5; //data (integer)
uint32_t d6; //data (integer)
} Device_t;
struct data_item_t {
void *fifo_reserved; /* 1st word reserved for use by FIFO */
Device_t MYGATE;
void producer_thread(Device_t *_mygate)
/* create data item to send */
struct data_item_t *tx_data = k_malloc(sizeof(struct data_item_t));
tx_data->MYGATE = *_mygate;
//[00:00:51.509,948] <inf> esb_child_event_handler: dcheck: producer thread: cmd: 7 uuid: 3BD5142E4BA09B49 d0: 9696110 (this is correct)
/* send data to consumers */
k_fifo_alloc_put(&my_fifo, &tx_data);
//k_free(tx_data); I don't think this can be freed before reading from consumer thread?
//or can it because I used: k_fifo_alloc_put??
void consumer_thread()
struct data_item_t *rx_data;
if(k_fifo_is_empty(&my_fifo) == 0){
LOG_ERR("FIFO1 Queue is Empty");
else{
rx_data = k_fifo_get(&my_fifo, K_NO_WAIT);
/* process FIFO data item */
Device_t temp = rx_data->MYGATE;
k_free(rx_data);
void send_child_data2()
COMMON_CHILD_TX_DATA_TO_SEND_FLAG = true;
int duration = MYGATE.d1 - MYGATE.d0;
MYGATE.d0 = MYGATE.d0 + PARENT_TIMESTAMP_OFFSET;
MYGATE.d1 = MYGATE.d1 + PARENT_TIMESTAMP_OFFSET;
MYGATE.cmd = cmd_data;
if(!MYGATE.isParent)
// esb_child_ptx_send_Tx2();
producer_thread(&MYGATE);
consumer_thread();
LOG_WRN("CHILD(%s) d0: %d, d1: %d (%d) (P_TS_OFFSET: %d )", MYGATE.uuid, MYGATE.d0, MYGATE.d1, duration, PARENT_TIMESTAMP_OFFSET);
