Fail to build a copy of nRF5340 example audio application
I own an nRF5340 Audio DK, on which I successfully run the example audio application.
Using nRF extension for VSCode, I've created a new application based on the above example, which is saved in a path outside the SDK. When I try to build it using the "buildproj" script, I get the following error:
I'll mention that this process worked fine for other examples, such as blinky and hello world.
I'd appreciate your help with solving this.
Dekel
  • I'll share the solution I've found:
    - I simply copied the audio example code to the desired folder on my PC, just like with any other example code.
    - Instead of using the buildproj script, I build & flash through nRF Extension for VSCode. The build configuration is set for the cpuapp and I set the device as gateway/headset by adding CONFIG_AUDIO_DEV to prj.conf and set it to 2/1 accordingly.
