ADC values with no input
I'm trying to read voltage signals from a sensor using internal ADC and send them OTA. For now, my codes seems to work, but the only problem with my codes is it gives maximum ADC value (e.g. 0xFF at 8 bit resolution) when the analog input pin is not connected to the sensor. It is usually fine when stable voltages are provided to the input pin but at certain condition it seems to cause wrong readings (e.g. 01 FF 02 FF 00 FF... instead of 01 00 02 00 00 00...) So, I'm wondering if there is a way to set ADC values when there is no voltage reading.
Thank you for your help in advance.
