how to run DTM on nrf5340
HI Noridc
I am developing with nRF5340, and I need to proceed with DTM test to verify the chip in the production process.
I am currently using this routine C:\ncs\v2.6.0\zephyr\samples\bluetooth\hci_uart
I then added the following configuration to the prj file:
CONFIG_BT_CTLR_DTM_HCI_SUPPORT=y
However, when I build, report the following error.
error: BT_CTLR_DTM_HCI_SUPPORT (defined at subsys/bluetooth\controller\Kconfig.dtm:6) is assigned in
a configuration file, but is not directly user-configurable (has no prompt). It gets its value
indirectly from other symbols. See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_BT_CTLR_DTM_HCI_SUPPORT and/or look up
BT_CTLR_DTM_HCI_SUPPORT in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
How can I solve this problem? I am looking forward to your reply
David
