Hi dear forumers,
I'm in the goal of achieving lowest current consumption on my PCA10056 DK board, with an nrf52840.
I converted a previous zephyr firmware who perfectly runs low current on PCA10040 to the PCA10056 board but it resulted with an abnormal current consumption.
The target with the nrf52840 is 2.35µA and I'm seeing 3.5µA.
1) To troubleshoot, I decided to build a new project from scratch using the simplest zephyr code and SDK 2.6.1. I disabled every possible peripheral in the device tree overlay.
Correctly cut the SB40 jumper on the board and measure with the PPK2 in ampmeter, and I still saw ... ~3.5µA.
Code Zephyr
prj.conf
measure
2) Then I applied a software SYSTEM OFF (NRF_POWER->SYSTEMOFF = 1) just to be sure, and I measure 1.5µA, which is incorrect and should be ~0.5µA.
3) Thinking that my board might have a ~1µA leak, I decided to flash a firmware from a fellow developer on this forum (here 538705.zephyr.hex), To my surprise, the current consumption dropped to 2.3µA between BLE advertising !
This indicated that my board doesn't have a leak and my measurements are correct.
So, the question is, why can't I achieve the same results as "ujur007" with my simple firmware?
Could it be the Zephyr version (v3.5.99-ncs1-1) ? The SDK version ? Because This is clearly a software issue.
Here my HEX : 6165.zephyr_brotechnic.hex
Best regards.
Vincent
