Low Power consumption for nRF52 series of devices
I was looking for different power options for nRF52/53 series of devices and possible want more information on how to reduce power such that device can run for months on a battery.
There was one interesting thread which discuss this for nRF51 series of devices. But that one is quite old (over 9 years now). So can someone from Nordic guide on this how to reduce power consumption of the device and individual blocks of SoC?
https://devzone.nordicsemi.com/f/nordic-q-a/1657/how-to-minimize-current-consumption-for-ble-application-on-nrf51822
Note: I have selected some tags to address topic for power consumption discussion.
    Many of the options discussed in that thread is also relevant for the nRF52 and nRF53 series. In addition we have this blog post for the nRF52 which should be a good read for this topic, and this for the nRF53 and nRF52.
    regards
    Jared
    Thanks for posting.
    One more question is how much minumum current can be achieved for BLE device advertising itself? My research shows that in the range of arround ~10uA.
    Is that correct?
    Right now I can measure current on nRF52840-DK of arround ~100uAmps. With this the device can run on a battery such as CR2032 for arround ~60 days. Is that reliable?
    It depends on several factors such as how your board is configured (DC-DC vs LDO) etc. But you can use the online power profiler tool for BLE to estimate what current you'll get with your connection parameters and configuration,
    regards
    Jared
  • I was working on this topic and want to ask some more question regarding power consumption and reducing the power on nRF52840 device.
    Currently, I do not have Nordic PPK-2 and measure the current through ampere meter via header P21 on the nRF52840-DK. The current consumption is around ~25uAmps when device it ideal(not advertising) with spike of around ~100uAmps when device do advertise.
    To reduce the power I did some changes to my application. First, I disabled the serial monitor and Logging through config options. This reduces significant amount of current consumption.
    Still I think there can be reduction in power consumption hence I am posting some questions and my current code.
    I have disabled the peripherals which are not needed in device.overlay file. As the following file, there are many of them in disabled state.
    &uart0 {
        status = "disabled";
    &uart1 {
    &spi0 {
    &gpiote{
    &spi1 {
    &spi3 {
    &qspi {
    &adc {
    &pdm0 {
    &i2c0 {
    &i2c1 {
    &nfct {
    In Kconfig file, I have enabled DC-DC converter which in my understanding enabled by default and I do not need to enable through power API in my application. The same is for clock configuration which I have enabled the external low power LFCLK 32khz clock through Kconfig as well as in my code by nrfx_clock_start(NRF_CLOCK_DOMAIN_LFCLK);
    I also have powered down unused RAM by power_down_unused_ram();
    My question is what else can I change in my code to reduce power?
    The config file is as follows.
    CONFIG_GPIO=y
    CONFIG_BT=y
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_DEBUG_LOG=y
    CONFIG_BT_SMP=y
    CONFIG_BT_DIS=y
    CONFIG_BT_DIS_PNP=n
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_GATT_CLIENT=y
    CONFIG_BT_DEVICE_NAME="Key"
    CONFIG_BT_DEVICE_APPEARANCE=833
    CONFIG_PM=y
    # Required to disable default behavior of deep sleep on timeout
    CONFIG_PM_DEVICE=y
    CONFIG_LOG=n
    CONFIG_SERIAL=n
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    CONFIG_RAM_POWER_DOWN_LIBRARY=y
    CONFIG_CAF_POWER_MANAGER=y
    CONFIG_CAF_POWER_MANAGER_TIMEOUT=10
    CONFIG_CAF_POWER_MANAGER_STAY_ON=y
