Maximum iso data length of NRF5340 audio increased
I am using bis gateway on nrf5340 audio dk to transmit data.
In addition to audio encoded data, I also wanted to send some additional data, so I put these data after the audio encoded data and sent them together, and then I encountered the -EMSGSIZE error.
It seems that the maximum iso data length is 120, if the data length exceeds this size, it will not be transmitted.
Can this maximum length be increased?
    Do you use nrf5340_audio application? Can you show your changes?
    Do you use I2S or USB?
    Can you provide a full error log?
    Dejan
  • Yes, I use nrf5340_audio application, and I use USB in.
    Here are my changes, I increased the data length when sending it.
    [audio_system.c]
    static void encoder_thread(void *arg1, void *arg2, void *arg3)
        if (sw_codec_cfg.encoder.enabled) {
    			/* Send encoded data over IPM */
    			//streamctrl_encoded_data_send(encoded_data, encoded_data_size);
    			streamctrl_encoded_data_send(my_data, 520);
    	STACK_USAGE_PRINT("encoder_thread", &encoder_thread_data);
    And I added the max data related log to iso_chan_max_data_len function in iso.c.
    [iso.c]
    static uint16_t iso_chan_max_data_len(const struct bt_iso_chan *chan,
    				      uint32_t ts)
    	/* Update the max_data_len to take the max_controller_data_len into account */
    	max_data_len = MIN(max_data_len, max_controller_data_len);
    	BT_INFO("Max data len:%d",max_data_len);
    	BT_INFO("Max Controller data len:%d",max_controller_data_len);
    	return max_data_len;
    This is the config I added in prj.conf.
    CONFIG_BT_ISO_TX_MTU=2048
    CONFIG_BT_ISO_RX_MTU=2048
    Then this is my error log.
    GW [00:00:00.130,798] <inf> bis_gateway: Broadcast source 0x2000bc78 started
    GW [00:00:00.131,134] <inf> bis_gateway: Broadcast source 0x2000bc9c started
    GW [00:00:11.588,470] <inf> bt_iso: Max data len:120
    GW [00:00:11.588,470] <inf> bt_iso: Max Controller data len:1536
    GW [00:00:11.588,470] <inf> bt_iso: Cannot send 520 octets, maximum 120
    GW [00:00:11.588,470] <wrn> bis_gateway: Failed to send audio data: -122
    GW [00:00:11.588,500] <wrn> streamctrl: Problem with sending LE audio data, ret: -122
    Which NCS version do you use?
    Can you show full log?
    Dejan
  • The NCS version I use is v2.2.0.
    Here is the full log.
    SEGGER J-Link V7.88j - Real time terminal output
    SEGGER J-Link V9.7, SN=20722384
    Process: JLink.exe
    *** Booting Zephyr OS build v3.2.99-ncs1 ***
    GW [00:00:00.001,922] <dbg> bt_hci_core: bt_hci_driver_register: Registered RPMsg
    GW [00:00:00.002,807] <inf> fw_info:
             nRF5340 Audio nRF5340 Audio DK cpuapp
             NCS base version: 2.2.0
             Cmake run : Tue Jun 11 09:11:00 2024
    GW [00:00:00.002,807] <inf> fw_info: ------- DEBUG BUILD -------
    GW [00:00:00.002,838] <inf> fw_info: Compiled for GATEWAY device
    GW [00:00:00.002,838] <inf> ble: cw_uicr_get_32:ffffffff
    GW [00:00:00.002,838] <inf> ble: cw_uicr_get_16:ffff
    GW [00:00:00.002,929] <dbg> bt_hci_core: hci_tx_thread: Started
    GW [00:00:00.002,929] <dbg> bt_conn: bt_conn_prepare_events:
    GW [00:00:00.002,960] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 2 events
    GW [00:00:00.003,112] <dbg> bt_hci_driver: bt_rpmsg_open:
    --- 836 messages dropped ---
    GW [00:00:05.020,019] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               a4 34 05 00 01 10 00 00  00                      |.4...... .
    GW [00:00:06.019,592] <dbg> bt_hci_core: bt_hci_cmd_create: opcode 0x1001 param_len 0
    GW [00:00:06.019,592] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x2001f0c8
    GW [00:00:06.019,622] <dbg> bt_hci_core: bt_hci_cmd_send_sync: buf 0x2001f0c8 opcode 0x1001 len 3
    GW [00:00:06.019,653] <dbg> bt_hci_core: process_events: count 4
    GW [00:00:06.019,653] <dbg> bt_hci_core: process_events: ev->state 4
    GW [00:00:06.019,683] <dbg> bt_hci_core: send_cmd: calling net_buf_get
    GW [00:00:06.019,683] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
    GW [00:00:06.019,683] <dbg> bt_hci_core: send_cmd: Sending command 0x1001 (buf 0x2001f0c8) to driver
    GW [00:00:06.019,714] <dbg> bt_hci_core: bt_send: buf 0x2001f0c8 len 3 type 0
    GW [00:00:06.019,714] <dbg> bt_hci_driver: bt_rpmsg_send: buf 0x2001f0c8 type 0 len 3
    GW [00:00:06.019,744] <dbg> bt_hci_driver: bt_rpmsg_send: Final HCI buffer:
                                               01 01 10 00                                      |....
    GW [00:00:06.019,775] <dbg> bt_hci_core: process_events: ev->state 0
    GW [00:00:06.019,805] <dbg> bt_conn: bt_conn_prepare_events:
    GW [00:00:06.019,805] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20002450 to poll list
    GW [00:00:06.019,805] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20002518 to poll list
    GW [00:00:06.019,836] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 4 events
    GW [00:00:06.019,897] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 0e 0c 01 01 10 00 0b  ee 0c 0b e8 07 ee 0c    |........ .......
    GW [00:00:06.019,897] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 12
    GW [00:00:06.019,897] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001f0c8)
    GW [00:00:06.019,927] <dbg> bt_hci_core: bt_recv: buf 0x2001f0c8 len 14
    GW [00:00:06.019,927] <dbg> bt_hci_core: hci_cmd_complete: opcode 0x1001
    GW [00:00:06.019,927] <dbg> bt_hci_core: hci_cmd_done: opcode 0x1001 status 0x00 buf 0x2001f0c8
    GW [00:00:06.019,958] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x2001f0c8 opcode 0x1001 len 9
    GW [00:00:06.020,019] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               01 31 00 00 00 0b 00 20  8e                      |.1.....  .
    GW [00:00:07.019,592] <dbg> bt_hci_core: bt_hci_cmd_create: opcode 0x1001 param_len 0
    GW [00:00:07.019,622] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x2001f0c8
    GW [00:00:07.019,622] <dbg> bt_hci_core: bt_hci_cmd_send_sync: buf 0x2001f0c8 opcode 0x1001 len 3
    GW [00:00:07.019,653] <dbg> bt_hci_core: process_events: count 4
    GW [00:00:07.019,653] <dbg> bt_hci_core: process_events: ev->state 4
    GW [00:00:07.019,683] <dbg> bt_hci_core: send_cmd: calling net_buf_get
    GW [00:00:07.019,683] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
    GW [00:00:07.019,683] <dbg> bt_hci_core: send_cmd: Sending command 0x1001 (buf 0x2001f0c8) to driver
    GW [00:00:07.019,683] <dbg> bt_hci_core: bt_send: buf 0x2001f0c8 len 3 type 0
    GW [00:00:07.019,714] <dbg> bt_hci_driver: bt_rpmsg_send: buf 0x2001f0c8 type 0 len 3
    GW [00:00:07.019,714] <dbg> bt_hci_driver: bt_rpmsg_send: Final HCI buffer:
                                               01 01 10 00                                      |....
    GW [00:00:07.019,744] <dbg> bt_hci_core: process_events: ev->state 0
    GW [00:00:07.019,775] <dbg> bt_hci_core: process_events: ev->state 0
    GW [00:00:07.019,775] <dbg> bt_conn: bt_conn_prepare_events:
    GW [00:00:07.019,805] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20002450 to poll list
    GW [00:00:07.019,805] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20002518 to poll list
    GW [00:00:07.019,805] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 4 events
    GW [00:00:07.019,866] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
    GW [00:00:07.019,866] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 12
    GW [00:00:07.019,897] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001f0c8)
    GW [00:00:07.019,897] <dbg> bt_hci_core: bt_recv: buf 0x2001f0c8 len 14
    GW [00:00:07.019,897] <dbg> bt_hci_core: hci_cmd_complete: opcode 0x1001
    GW [00:00:07.019,897] <dbg> bt_hci_core: hci_cmd_done: opcode 0x1001 status 0x00 buf 0x2001f0c8
    GW [00:00:07.019,927] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x2001f0c8 opcode 0x1001 len 9
    GW [00:00:07.019,958] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               8e 02 03 00 0c 00 00 00  06                      |........ .
    GW [00:00:07.926,574] <inf> bt_iso: Max data len:120
    GW [00:00:07.926,574] <inf> bt_iso: Max Controller data len:1536
    GW [00:00:07.926,605] <inf> bt_iso: Cannot send 520 octets, maximum 120
    GW [00:00:07.926,605] <wrn> bis_gateway: Failed to send audio data: -122
    GW [00:00:07.926,605] <wrn> streamctrl: Problem with sending LE audio data, ret: -122
    GW [00:00:07.936,584] <inf> bt_iso: Max data len:120
    GW [00:00:07.936,584] <inf> bt_iso: Max Controller data len:1536
    GW [00:00:07.936,584] <inf> bt_iso: Cannot send 520 octets, maximum 120
    GW [00:00:07.936,584] <wrn> bis_gateway: Failed to send audio data: -122
    GW [00:00:07.946,563] <inf> bt_iso: Max data len:120
    GW [00:00:07.946,563] <inf> bt_iso: Max Controller data len:1536
    GW [00:00:07.946,594] <inf> bt_iso: Cannot send 520 octets, maximum 120
    GW [00:00:07.946,594] <wrn> bis_gateway: Failed to send audio data: -122
    GW [00:00:07.956,573] <inf> bt_iso: Max data len:120
    GW [00:00:07.956,573] <inf> bt_iso: Max Controller data len:1536
    GW [00:00:07.956,604] <inf> bt_iso: Cannot send 520 octets, maximum 120
    GW [00:00:07.956,604] <wrn> bis_gateway: Failed to send audio data: -122
  • Now I already know how to increase the maximum iso data length, just change the codec configuration of bis gateway.
    It seems that the maximum value can only be changed up to 251 bytes.
    Here is my change in bis gateway.
    [le_audio.h]
    #define BT_AUDIO_LC3_BROADCAST_PRESET_RECOMMENDED(_loc, _stream_context)                           \
    	BT_AUDIO_LC3_PRESET(        \
    		BT_CODEC_LC3_CONFIG(                                                               \
    			BT_CODEC_CONFIG_LC3_FREQ_48KHZ, BT_CODEC_CONFIG_LC3_DURATION_10, _loc,     \
    			251u, 1, _stream_context),         \
    		BT_CODEC_LC3_QOS_10_UNFRAMED(251u, 4u,20u, LE_AUDIO_PRES_DELAY_US))
    But I encountered a new problem. When I tried to use bis headset to connect to the modified bis gateway, an Unexpected PA sync lost error occurred in bis headset.
    This is my modification in bis headset.
    [le_audio_bis_headset.c]
    static struct bt_codec codec_capabilities =
    	BT_CODEC_LC3_CONFIG(BT_CODEC_CONFIG_LC3_FREQ_48KHZ, \
    			    BT_CODEC_CONFIG_LC3_DURATION_10, BT_AUDIO_LOCATION_FRONT_LEFT|BT_AUDIO_LOCATION_FRONT_RIGHT, 251u, \
    			    1, BT_AUDIO_CONTEXT_TYPE_MEDIA);
    This is log.
    HL [00:01:30.250,305] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.250,305] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.250,396] <dbg> bt_scan: le_adv_recv: 72:7A:C1:70:09:3A (random) event 0, len 17, rssi -77 dBm
    HL [00:01:30.250,488] <dbg> bt_keys: bt_keys_find_irk: 72:7A:C1:70:09:3A (random)
    HL [00:01:30.250,549] <dbg> bt_keys: bt_keys_find_irk: No IRK for 72:7A:C1:70:09:3A (random)
    HL [00:01:30.250,579] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               44 d5 07 00 1c 96 01 20  00 29 00 00 78 0e 00 20 |D......  .)..x..
                                               de                                               |.
    HL [00:01:30.376,251] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 2b 0d 01 10 00 01  f9 4b da 36 c6 7d 01 00 |.>+..... .K.6.}..
                                               ff 7f b4 00 00 00 00 00  00 00 00 00 11 02 01 1a |........ ........
                                               0d ff 4c 00 16 08 00 ce  62 05 85 4d 4c 0c       |..L..... b..ML.
    HL [00:01:30.376,251] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 43
    HL [00:01:30.376,281] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:30.376,281] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 45
    HL [00:01:30.376,312] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:30.376,312] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 45
    HL [00:01:30.376,342] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:30.376,342] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.376,342] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.376,434] <dbg> bt_scan: le_adv_recv: 7D:C6:36:DA:4B:F9 (random) event 3, len 17, rssi -76 dBm
    HL [00:01:30.376,525] <dbg> bt_keys: bt_keys_find_irk: 7D:C6:36:DA:4B:F9 (random)
    HL [00:01:30.376,586] <dbg> bt_keys: bt_keys_find_irk: No IRK for 7D:C6:36:DA:4B:F9 (random)
    HL [00:01:30.376,647] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               06 00 00 00 18 61 07 00  74 68 07 00 1c 96 01 20 |.....a.. th.....
                                               01                                               |.
    HL [00:01:30.546,844] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 2d 0d 01 13 00 01  b8 2f 7d 79 6b 6b 01 00 |.>-..... ./}ykk..
                                               ff 7f b2 00 00 00 00 00  00 00 00 00 13 02 01 1a |........ ........
                                               02 0a 0c 0c ff 4c 00 10  07 3f 1f e4 de ea 1f 28 |.....L.. .?.....(
    HL [00:01:30.546,844] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 45
    HL [00:01:30.546,875] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:30.546,875] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 47
    HL [00:01:30.546,905] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:30.546,905] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 47
    HL [00:01:30.546,936] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:30.546,936] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.546,936] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.547,027] <dbg> bt_scan: le_adv_recv: 6B:6B:79:7D:2F:B8 (random) event 0, len 19, rssi -78 dBm
    HL [00:01:30.547,119] <dbg> bt_keys: bt_keys_find_irk: 6B:6B:79:7D:2F:B8 (random)
    HL [00:01:30.547,180] <dbg> bt_keys: bt_keys_find_irk: No IRK for 6B:6B:79:7D:2F:B8 (random)
    HL [00:01:30.547,241] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               01 00 00                                         |...
    HL [00:01:30.552,520] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 2c 0d 01 00 00 01  84 1f 15 fb 21 e4 01 02 |.>,..... ....!...
                                               00 7f c5 c0 03 00 00 00  00 00 00 00 12 0a 30 43 |........ ......0C
                                               57 44 4b 2d 47 31 5f 37  06 16 52 18 af 9f 4a    |WDK-G1_7 ..R...J
    HL [00:01:30.552,520] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 44
    HL [00:01:30.552,551] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x200187f4)
    HL [00:01:30.552,551] <dbg> bt_hci_core: bt_recv: buf 0x200187f4 len 46
    HL [00:01:30.552,581] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:30.552,581] <dbg> bt_hci_core: rx_work_handler: buf 0x200187f4 type 1 len 46
    HL [00:01:30.552,581] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:30.552,612] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.552,612] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.552,703] <dbg> bt_scan: le_adv_recv: E4:21:FB:15:1F:84 (random) event 5, len 18, rssi -59 dBm
    HL [00:01:30.552,764] <dbg> bt_keys: bt_keys_find_irk: E4:21:FB:15:1F:84 (random)
    HL [00:01:30.552,825] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               00 46 2d 00 8c d8 00 20  04 00 00 00 e0 d4 07 00 |.F-....  ........
                                               44 d5                                            |D.
    HL [00:01:30.654,449] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 2c 0d 01 13 00 01  4f 80 d2 ef 6c 4e 01 00 |.>,..... O...lN..
                                               ff 7f b0 00 00 00 00 00  00 00 00 00 12 02 01 1a |........ ........
                                               02 0a 0c 0b ff 4c 00 10  06 75 1e 30 33 f4 6e    |.....L.. .u.03.n
    HL [00:01:30.654,479] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 44
    HL [00:01:30.654,479] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:30.654,510] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 46
    HL [00:01:30.654,510] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:30.654,541] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 46
    HL [00:01:30.654,541] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:30.654,541] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.654,571] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.654,632] <dbg> bt_scan: le_adv_recv: 4E:6C:EF:D2:80:4F (random) event 0, len 18, rssi -80 dBm
    --- 9 messages dropped ---
    HL [00:01:30.654,724] <dbg> bt_keys: bt_keys_find_irk: 4E:6C:EF:D2:80:4F (random)
    HL [00:01:30.659,881] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.659,881] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.659,973] <dbg> bt_scan: le_adv_recv: 63:C8:C6:80:D8:50 (random) event 0, len 30, rssi -71 dBm
    HL [00:01:30.660,064] <dbg> bt_keys: bt_keys_find_irk: 63:C8:C6:80:D8:50 (random)
    HL [00:01:30.660,125] <dbg> bt_keys: bt_keys_find_irk: No IRK for 63:C8:C6:80:D8:50 (random)
    HL [00:01:30.660,156] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               03 00 00 00 f8 60 07 00  74 68 07 00 98 0e 00 20 |.....`.. th.....
                                               00 31 00 00 78 0e 00 20  c8 53 2d 00 40 72       |.1..x..  .S-.@r
    HL [00:01:30.663,085] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 39 0d 01 10 00 01  82 1f e6 65 2e 1e 01 00 |.>9..... ...e....
                                               ff 7f bd 00 00 00 00 00  00 00 00 00 1f 1e ff 06 |........ ........
                                               00 01 09 20 02 7a c1 87  3d a8 55 a1 2a 65 02 4f |... .z.. =.U.*e.O
                                               7a 71 9b 76 42 93 74 6e  46 c5 19 cc             |zq.vB.tn F...
    HL [00:01:30.663,116] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 57
    HL [00:01:30.663,116] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:30.663,146] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 59
    HL [00:01:30.663,177] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:30.663,177] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 59
    HL [00:01:30.663,177] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:30.663,208] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.663,208] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.663,299] <dbg> bt_scan: le_adv_recv: 1E:2E:65:E6:1F:82 (random) event 3, len 31, rssi -67 dBm
    HL [00:01:30.663,360] <dbg> bt_keys: bt_keys_find_irk: 1E:2E:65:E6:1F:82 (random)
    HL [00:01:30.663,421] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               01 00 00 00 3a 00 00 00  01 21 00 00 78 0e 00 20 |....:... .!..x..
                                               77 54 2d 00 88 0e 00 20  04 00 00 00 0c 60 07    |wT-....  .....`.
    HL [00:01:30.773,376] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 39 0d 01 13 00 01  5c d4 77 86 70 df 01 00 |.>9..... \.w.p...
                                               ff 7f b1 00 00 00 00 00  00 00 00 00 1f 1e ff 4c |........ .......L
                                               00 12 19 68 08 2b 73 bf  b8 23 e0 3b 93 d0 b8 23 |...h.+s. .#.;...#
                                               c9 70 c4 5a c7 45 a9 83  a0 dc 03 5c             |.p.Z.E.. ...\
    HL [00:01:30.773,406] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 57
    HL [00:01:30.773,406] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:30.773,406] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 59
    HL [00:01:30.773,437] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:30.773,468] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 59
    HL [00:01:30.773,468] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:30.773,468] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.773,468] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.773,559] <dbg> bt_scan: le_adv_recv: DF:70:86:77:D4:5C (random) event 0, len 31, rssi -79 dBm
    HL [00:01:30.773,651] <dbg> bt_keys: bt_keys_find_irk: DF:70:86:77:D4:5C (random)
    HL [00:01:30.773,681] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               ce 53 2d 00 f8 d4 07 00  04 01 00 00 98 6c 07 00 |.S-..... .....l..
                                               54 a5 07 00 8c d8 00 20  03 34 45 3a 36 43 3a    |T......  .4E:6C:
    HL [00:01:30.796,478] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 2b 0d 01 13 00 01  3a 09 70 c1 7a 72 01 00 |.>+..... :.p.zr..
                                               ff 7f b5 00 00 00 00 00  00 00 00 00 11 02 01 1a |........ ........
                                               02 0a 07 0a ff 4c 00 10  05 52 1c dd f8 19       |.....L.. .R....
    HL [00:01:30.796,508] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 43
    HL [00:01:30.796,508] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:30.796,539] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 45
    HL [00:01:30.796,539] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:30.796,569] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 45
    HL [00:01:30.796,569] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:30.796,569] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.796,600] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.796,661] <dbg> bt_scan: le_adv_recv: 72:7A:C1:70:09:3A (random) event 0, len 17, rssi -75 dBm
    HL [00:01:30.796,752] <dbg> bt_keys: bt_keys_find_irk: 72:7A:C1:70:09:3A (random)
    HL [00:01:30.796,813] <dbg> bt_keys: bt_keys_find_irk: No IRK for 72:7A:C1:70:09:3A (random)
    HL [00:01:30.796,875] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               04 00 00 00 e0 d4 07 00  44 d5 07 00 1c 96 01 20 |........ D......
                                               00                                               |.
    HL [00:01:30.839,782] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 22 0d 01 10 00 01  9d 24 67 75 ca de 01 00 |.>"..... .$gu....
                                               ff 7f b4 00 00 00 00 00  00 00 00 00 08 07 ff 4c |........ .......L
                                               00 12 02 00 00                                   |.....
    HL [00:01:30.839,782] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 34
    HL [00:01:30.839,813] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:30.839,813] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 36
    HL [00:01:30.839,843] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:30.839,843] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 36
    HL [00:01:30.839,874] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:30.839,874] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.839,874] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.839,965] <dbg> bt_scan: le_adv_recv: DE:CA:75:67:24:9D (random) event 3, len 8, rssi -76 dBm
    HL [00:01:30.840,057] <dbg> bt_keys: bt_keys_find_irk: DE:CA:75:67:24:9D (random)
    HL [00:01:30.840,087] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               00 21 00 00 7c 0e 00 20                          |.!..|..
    HL [00:01:30.852,508] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               00 7f c6 c0 03 00 00 00  00 00 00 00 12 0a 30 43 |........ ......0C
    HL [00:01:30.852,539] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 44
    HL [00:01:30.852,539] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x200187f4)
    HL [00:01:30.852,539] <dbg> bt_hci_core: bt_recv: buf 0x200187f4 len 46
    HL [00:01:30.852,569] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:30.852,600] <dbg> bt_hci_core: rx_work_handler: buf 0x200187f4 type 1 len 46
    HL [00:01:30.852,600] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:30.852,600] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.852,630] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.852,691] <dbg> bt_scan: le_adv_recv: E4:21:FB:15:1F:84 (random) event 5, len 18, rssi -58 dBm
    HL [00:01:30.852,783] <dbg> bt_keys: bt_keys_find_irk: E4:21:FB:15:1F:84 (random)
    HL [00:01:30.852,813] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               00 00 00 00 08 07 ff 4c  00 12 02 00 00 0e 00 20 |.......L .......
                                               00 21                                            |.!
    HL [00:01:30.910,827] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 2d 0d 01 13 00 01  be 2e 30 fe ce 68 01 00 |.>-..... ..0..h..
                                               ff 7f bb 00 00 00 00 00  00 00 00 00 13 02 01 1a |........ ........
                                               02 0a 0c 0c ff 4c 00 10  07 7b 1f 2e 2c f5 ec 18 |.....L.. .{..,...
    HL [00:01:30.910,858] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 45
    HL [00:01:30.910,888] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:30.910,888] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 47
    HL [00:01:30.910,919] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:30.910,919] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 47
    HL [00:01:30.910,919] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:30.910,919] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:30.910,949] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:30.911,010] <dbg> bt_scan: le_adv_recv: 68:CE:FE:30:2E:BE (random) event 0, len 19, rssi -69 dBm
    HL [00:01:30.911,102] <dbg> bt_keys: bt_keys_find_irk: 68:CE:FE:30:2E:BE (random)
    HL [00:01:30.911,193] <dbg> bt_keys: bt_keys_find_irk: No IRK for 68:CE:FE:30:2E:BE (random)
    HL [00:01:30.911,224] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               05 00 00 00 b8 66 07 00  84 68 07 00 f4 87 01 20 |.....f.. .h.....
                                               2e 00 00                                         |...
    HL [00:01:31.019,897] <dbg> bt_hci_core: bt_hci_cmd_create: opcode 0x1001 param_len 0
    HL [00:01:31.019,897] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x2001a0d8
    HL [00:01:31.019,927] <dbg> bt_hci_core: bt_hci_cmd_send_sync: buf 0x2001a0d8 opcode 0x1001 len 3
    HL [00:01:31.019,958] <dbg> bt_hci_core: process_events: count 3
    HL [00:01:31.019,958] <dbg> bt_hci_core: process_events: ev->state 4
    HL [00:01:31.019,958] <dbg> bt_hci_core: send_cmd: calling net_buf_get
    HL [00:01:31.019,989] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
    HL [00:01:31.019,989] <dbg> bt_hci_core: send_cmd: Sending command 0x1001 (buf 0x2001a0d8) to driver
    HL [00:01:31.019,989] <dbg> bt_hci_core: bt_send: buf 0x2001a0d8 len 3 type 0
    HL [00:01:31.020,019] <dbg> bt_hci_driver: bt_rpmsg_send: buf 0x2001a0d8 type 0 len 3
    HL [00:01:31.020,019] <dbg> bt_hci_driver: bt_rpmsg_send: Final HCI buffer:
                                               01 01 10 00                                      |....
    HL [00:01:31.020,050] <dbg> bt_hci_core: process_events: ev->state 0
    HL [00:01:31.020,080] <dbg> bt_hci_core: process_events: ev->state 0
    HL [00:01:31.020,080] <dbg> bt_conn: bt_conn_prepare_events:
    HL [00:01:31.020,080] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20002828 to poll list
    HL [00:01:31.020,111] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    HL [00:01:31.020,172] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
    HL [00:01:31.020,172] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 12
    HL [00:01:31.020,172] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001a0d8)
    HL [00:01:31.020,202] <dbg> bt_hci_core: bt_recv: buf 0x2001a0d8 len 14
    HL [00:01:31.020,202] <dbg> bt_hci_core: hci_cmd_complete: opcode 0x1001
    HL [00:01:31.020,202] <dbg> bt_hci_core: hci_cmd_done: opcode 0x1001 status 0x00 buf 0x2001a0d8
    HL [00:01:31.020,233] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x2001a0d8 opcode 0x1001 len 9
    HL [00:01:31.020,263] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               03 36 38 3a 43 45 3a 46  45                      |.68:CE:F E
    HL [00:01:31.095,733] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               ff 7f b5 00 00 00 00 00  00 00 00 00 13 02 01 1a |........ ........
    HL [00:01:31.095,733] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 45
    HL [00:01:31.095,764] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:31.095,764] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 47
    HL [00:01:31.095,794] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:31.095,794] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 47
    HL [00:01:31.095,825] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:31.095,825] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:31.095,825] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:31.095,916] <dbg> bt_scan: le_adv_recv: 6B:6B:79:7D:2F:B8 (random) event 0, len 19, rssi -75 dBm
    HL [00:01:31.095,977] <dbg> bt_keys: bt_keys_find_irk: 6B:6B:79:7D:2F:B8 (random)
    HL [00:01:31.096,069] <dbg> bt_keys: bt_keys_find_irk: No IRK for 6B:6B:79:7D:2F:B8 (random)
    HL [00:01:31.096,130] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               04 00 00 00 34 66 07 00  6c 67 07 00 00 00 00 00 |....4f.. lg......
                                               00 19 00                                         |...
    HL [00:01:31.201,354] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 38 0d 01 10 00 01  1d b7 27 62 fb 6f 01 00 |.>8..... ..'b.o..
                                               ff 7f ad 00 00 00 00 00  00 00 00 00 1e 02 01 1a |........ ........
                                               1a ff 4c 00 13 0b 1b 89  35 1f a2 1d bf d4 aa 9a |..L..... 5.......
                                               00 16 08 00 c2 89 35 1f  b0 4f f4                |......5. .O.
    HL [00:01:31.201,385] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 56
    HL [00:01:31.201,416] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:31.201,416] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 58
    HL [00:01:31.201,446] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:31.201,446] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 58
    HL [00:01:31.201,446] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:31.201,477] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:31.201,477] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:31.201,568] <dbg> bt_scan: le_adv_recv: 6F:FB:62:27:B7:1D (random) event 3, len 30, rssi -83 dBm
    HL [00:01:31.201,629] <dbg> bt_keys: bt_keys_find_irk: 6F:FB:62:27:B7:1D (random)
    HL [00:01:31.201,721] <dbg> bt_keys: bt_keys_find_irk: No IRK for 6F:FB:62:27:B7:1D (random)
    HL [00:01:31.201,751] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               00 19 00 00 78 0e 00 20  43 8c 2d 00 84 60 07 00 |....x..  C.-..`..
                                               03 00 00 00 f8 60 07 00  74 68 07 00 78 0e       |.....`.. th..x.
    HL [00:01:31.206,939] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               ff 7f ad 00 00 00 00 00  00 00 00 00 12 02 01 1a |........ ........
    HL [00:01:31.206,970] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 44
    HL [00:01:31.206,970] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:31.207,000] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 46
    HL [00:01:31.207,000] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:31.207,031] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 46
    HL [00:01:31.207,031] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:31.207,031] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:31.207,061] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:31.207,122] <dbg> bt_scan: le_adv_recv: 4E:6C:EF:D2:80:4F (random) event 0, len 18, rssi -83 dBm
    HL [00:01:31.207,214] <dbg> bt_keys: bt_keys_find_irk: 4E:6C:EF:D2:80:4F (random)
    HL [00:01:31.207,275] <dbg> bt_keys: bt_keys_find_irk: No IRK for 4E:6C:EF:D2:80:4F (random)
    HL [00:01:31.207,336] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               3a 00 00 00 d8 a0 01 20  00 19 00 00 78 0e 00 20 |:......  ....x..
                                               c9 99                                            |..
    HL [00:01:31.560,821] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 37 0d 01 10 00 01  07 ce 2b aa ff 25 01 00 |.>7..... ..+..%..
                                               ff 7f 99 00 00 00 00 00  00 00 00 00 1d 1c ff 06 |........ ........
                                               00 01 09 21 2a a8 84 fc  3b c6 74 44 45 53 4b 54 |...!*... ;.tDESKT
                                               4f 50 2d 35 4e 44 41 4b  43 49                   |OP-5NDAK CI
    HL [00:01:31.560,821] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 55
    HL [00:01:31.560,852] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:31.560,852] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 57
    HL [00:01:31.560,882] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:31.560,882] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 57
    HL [00:01:31.560,913] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:31.560,913] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:31.560,913] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:31.561,004] <dbg> bt_scan: le_adv_recv: 25:FF:AA:2B:CE:07 (random) event 3, len 29, rssi -103 dBm
    HL [00:01:31.561,065] <dbg> bt_keys: bt_keys_find_irk: 25:FF:AA:2B:CE:07 (random)
    HL [00:01:31.561,126] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               00 29 00 00 78 0e 00 20  7f 9a 2d 00 40 72 07 00 |.)..x..  ..-.@r..
                                               05 00 00 00 b8 66 07 00  84 68 07 00 1c          |.....f.. .h...
    HL [00:01:31.621,765] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
    HL [00:01:31.621,765] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 43
    HL [00:01:31.621,795] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:31.621,795] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 45
    HL [00:01:31.621,826] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:31.621,826] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 45
    HL [00:01:31.621,826] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:31.621,856] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:31.621,856] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:31.621,948] <dbg> bt_scan: le_adv_recv: 72:7A:C1:70:09:3A (random) event 0, len 17, rssi -76 dBm
    HL [00:01:31.622,009] <dbg> bt_keys: bt_keys_find_irk: 72:7A:C1:70:09:3A (random)
    HL [00:01:31.622,100] <dbg> bt_keys: bt_keys_find_irk: No IRK for 72:7A:C1:70:09:3A (random)
    HL [00:01:31.622,131] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               00 29 00 00 78 0e 00 20  ca c7 2d 00 03 36 46 3a |.)..x..  ..-..6F:
                                               05                                               |.
    HL [00:01:31.736,694] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 39 0d 01 12 00 01  de 76 70 52 b3 4d 01 00 |.>9..... .vpR.M..
                                               ff 7f b8 00 00 00 00 00  00 00 00 00 1f 1e ff 4c |........ .......L
                                               00 07 19 01 0f 20 0b 55  8f 01 00 05 d8 ab b2 78 |..... .U .......x
                                               ef e1 98 35 65 eb a5 5f  a0 1d 06 22             |...5e.._ ..."
    HL [00:01:31.736,694] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 57
    HL [00:01:31.736,724] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:31.736,724] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 59
    HL [00:01:31.736,755] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:31.736,755] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 59
    HL [00:01:31.736,755] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:31.736,785] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:31.736,785] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:31.736,877] <dbg> bt_scan: le_adv_recv: 4D:B3:52:70:76:DE (random) event 2, len 31, rssi -72 dBm
    HL [00:01:31.736,938] <dbg> bt_keys: bt_keys_find_irk: 4D:B3:52:70:76:DE (random)
    HL [00:01:31.737,030] <dbg> bt_keys: bt_keys_find_irk: No IRK for 4D:B3:52:70:76:DE (random)
    HL [00:01:31.737,060] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               00 31 00 00 78 0e 00 20  98 cf 2d 00 46 3a 44 32 |.1..x..  ..-.F:D2
                                               06 00 00 00 18 61 07 00  74 68 07 00 1c 96 01    |.....a.. th.....
    HL [00:01:31.749,481] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               ff 7f bc 00 00 00 00 00  00 00 00 00 13 02 01 1a |........ ........
    HL [00:01:31.749,481] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 45
    HL [00:01:31.749,511] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001961c)
    HL [00:01:31.749,511] <dbg> bt_hci_core: bt_recv: buf 0x2001961c len 47
    HL [00:01:31.749,542] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00z01:31.749,542] <dbg> bt_hci_core: rx_work_handler: buf 0x2001961c type 1 len 47
    HL [00:01:31.749,572] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:31.749,572] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d
    HL [00:01:31.749,572] <dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1
    HL [00:01:31.749,664] <dbg> bt_scan: le_adv_recv: 68:CE:FE:30:2E:BE (random) event 0, len 19, rssi -68 dBm
    HL [00:01:31.749,725] <dbg> bt_keys: bt_keys_find_irk: 68:CE:FE:30:2E:BE (random)
    HL [00:01:31.749,816] <dbg> bt_keys: bt_keys_find_irk: No IRK for 68:CE:FE:30:2E:BE (random)
    HL [00:01:31.749,877] <dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
                                               4e de 2d 00 8c d8 00 20  03 00 00 00 f8 60 07 00 |N.-....  .....`..
                                               74 68 07                                         |th.
    HL [00:01:31.808,135] <dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
                                               04 3e 10 0e 3e 00 00 00  01 84 1f 15 fb 21 e4 02 |.>..>... .....!..
                                               c0 03 07                                         |...
    HL [00:01:31.808,135] <dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 16
    HL [00:01:31.808,166] <dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x200187f4)
    HL [00:01:31.808,166] <dbg> bt_hci_core: bt_recv: buf 0x200187f4 len 18
    HL [00:01:31.808,197] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    HL [00:01:31.808,197] <dbg> bt_hci_core: rx_work_handler: buf 0x200187f4 type 1 len 18
    HL [00:01:31.808,227] <dbg> bt_hci_core: hci_event: event 0x3e
    HL [00:01:31.808,227] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x0e
    HL [00:01:31.808,227] <dbg> bt_audio_broadcast_sink: pa_term: PA sync with broadcast source with ID 0x4A9FAF lost
    HL [00:01:31.808,258] <err> bis_headset: Unexpected PA sync lost
    What else needs to be modified in the bis headset to connect to the bis gateway that increased the sdu size?
