Mqtt AND Gnss
in devacademy there are mqtt and gnss sample. when I put the mqtt configs to gnss sample. give an error. I did not add main code yet. just only put configs and cmake.
after combining mqtt to gnss , mqtt code is running but gnss code give error.
it is built, after flush when it is coming to gps int function . give  failed to set gnss fix interval.
# Copyright (c) 2019 Nordic Semiconductor ASA
# Logging
CONFIG_LOG=y
# Button and LED support
CONFIG_DK_LIBRARY=y
# Newlib
CONFIG_NEWLIB_LIBC=y
# STEP 2.2 - Enable printing of floating-points
CONFIG_FPU=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
# Memory
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_MAIN_STACK_SIZE=4096
# Modem library
CONFIG_NRF_MODEM_LIB=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS=y
# STEP 7.1 - Request eDRX from the network
CONFIG_LTE_EDRX_REQ=y
# STEP 7.2 - Request PSM periodic TAU and active time
CONFIG_LTE_PSM_REQ_RPTAU="00101000"
CONFIG_LTE_PSM_REQ_RAT="00001000"
CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT=y
# MQTT
# STEP 2.1 - Enable and configure the MQTT library
CONFIG_MQTT_LIB=y
CONFIG_MQTT_CLEAN_SESSION=y
# Application
CONFIG_MQTT_SUB_TOPIC="devacademy/subscribe/topic"
CONFIG_BUTTON_EVENT_PUBLISH_MSG="Hi from the nRF91 Series device"
CONFIG_MQTT_BROKER_PORT=1883
CONFIG_MQTT_PUB_TOPIC=""
CONFIG_MQTT_BROKER_HOSTNAME=""
CONFIG_MQTT_CLIENT_ID="MyClient"
CONFIG_PRINTK=y
CONFIG_COUNTER=y
menu "Cellfund Lesson 6 Exercise"
config MQTT_PUB_TOPIC
	string "MQTT publish topic"
	default "devacademy/publish/topic"
config MQTT_SUB_TOPIC
	string "MQTT subscribe topic"
	default "devacademy/subscribe/topic"
config MQTT_CLIENT_ID
	string "MQTT Client ID"
	help
	  Use a custom Client ID string. If not set, the client ID will be
	  generated based on IMEI number (for nRF91 Series based targets) or
	  randomly (for other platforms).
	default ""
config MQTT_BROKER_HOSTNAME
	string "MQTT broker hostname"
	default "test.mosquitto.org"
config MQTT_BROKER_PORT
	int "MQTT broker port"
	default 1883
config MQTT_MESSAGE_BUFFER_SIZE
	int "MQTT message buffer size"
	default 128
config MQTT_PAYLOAD_BUFFER_SIZE
	int "MQTT payload buffer size"
	default 128
config BUTTON_EVENT_PUBLISH_MSG
	string "The message to publish on a button event"
	default "Hi from nRF91 Series device"
config TURN_LED_ON_CMD
	string "Command to turn on LED"
	default "LED1ON"
config TURN_LED_OFF_CMD
	string "Command to turn off LED"
	default "LED1OFF"
config MQTT_RECONNECT_DELAY_S
	int "Seconds to delay before attempting to reconnect to the broker."
	default 60
config GNSS_PERIODIC_INTERVAL
	int "Fix interval for periodic GPS fixes. This determines your tracking frequency"
	range 10 65535
	default 120
	help
	  Fix interval (in seconds) for periodic fixes.
config GNSS_PERIODIC_TIMEOUT
	int "Fix timeout for periodic GPS fixes"
	range 0 65535
	default 600
	help
	  Fix timeout (in seconds) for periodic fixes.
	  If set to zero, GNSS is allowed to run indefinitely until a valid PVT estimate is produced.
endmenu
menu "Zephyr Kernel"
source "Kconfig.zephyr"
endmenu
cmake_minimum_required(VERSION 3.20.0)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(cellular_fundamentals)
# NORDIC SDK APP START
target_sources(app PRIVATE src/main.c)
target_sources(app PRIVATE src/mqtt_connection.c)
# NORDIC SDK APP END
