I cannot re start advertising while connected.
this occurs even when i configure BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED.
I get NRF_ERROR_CONN_COUNT error code when calling sd_ble_gap_adv_start().
I do not understand why do i get this error when the ADV i want to send is not-connectable.
When i change NRF_SDH_BLE_PERIPHERAL_LINK_COUNT from 1 to 2 it works, but why should i do that? i do not want to keep more than one connection, just to keep advertising while connected.
this is my modified ble_advertising_start() code, look for 'is_connectable'.
uint32_t ble_advertising_start(ble_advertising_t * const p_advertising,
ble_adv_mode_t advertising_mode,
bool is_connectable)
uint32_t ret = NRF_SUCCESS;
if (p_advertising->initialized == false)
p_advertising->adv_mode_current = advertising_mode;
(void)memset(&p_advertising->peer_address, 0, sizeof(p_advertising->peer_address));
if ( ((p_advertising->adv_modes_config.ble_adv_directed_high_duty_enabled) && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED_HIGH_DUTY))
||((p_advertising->adv_modes_config.ble_adv_directed_enabled) && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED_HIGH_DUTY))
||((p_advertising->adv_modes_config.ble_adv_directed_enabled) && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED))
if (p_advertising->evt_handler != NULL)
p_advertising->peer_addr_reply_expected = true;
p_advertising->evt_handler(BLE_ADV_EVT_PEER_ADDR_REQUEST);
p_advertising->peer_addr_reply_expected = false;
p_advertising->adv_mode_current = adv_mode_next_avail_get(p_advertising, advertising_mode);
// Fetch the whitelist.
if ((p_advertising->evt_handler != NULL) &&
(p_advertising->adv_mode_current == BLE_ADV_MODE_FAST || p_advertising->adv_mode_current == BLE_ADV_MODE_SLOW) &&
(p_advertising->adv_modes_config.ble_adv_whitelist_enabled) &&
(!p_advertising->whitelist_temporarily_disabled))
p_advertising->whitelist_in_use = false;
p_advertising->whitelist_reply_expected = true;
p_advertising->evt_handler(BLE_ADV_EVT_WHITELIST_REQUEST);
p_advertising->whitelist_reply_expected = false;
// Initialize advertising parameters with default values.
(void)memset(&p_advertising->adv_params, 0, sizeof(p_advertising->adv_params));
if ( is_connectable )
p_advertising->adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
p_advertising->adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED;
// Use 1MBIT as primary phy if no phy was selected.
if (phy_is_valid(&p_advertising->adv_modes_config.ble_adv_primary_phy))
p_advertising->adv_params.primary_phy = (uint8_t)p_advertising->adv_modes_config.ble_adv_primary_phy;
p_advertising->adv_params.primary_phy = BLE_GAP_PHY_1MBPS;
if (p_advertising->adv_modes_config.ble_adv_extended_enabled)
// Use 1MBIT as secondary phy if no phy was selected.
if (phy_is_valid(&p_advertising->adv_modes_config.ble_adv_secondary_phy))
p_advertising->adv_params.secondary_phy = (uint8_t)p_advertising->adv_modes_config.ble_adv_secondary_phy;
p_advertising->adv_params.secondary_phy = BLE_GAP_PHY_1MBPS;
p_advertising->adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
// Set advertising parameters and events according to selected advertising mode.
switch (p_advertising->adv_mode_current)
case BLE_ADV_MODE_DIRECTED_HIGH_DUTY:
ret = set_adv_mode_directed_high_duty(p_advertising, &p_advertising->adv_params);
case BLE_ADV_MODE_DIRECTED:
ret = set_adv_mode_directed(p_advertising, &p_advertising->adv_params);
case BLE_ADV_MODE_FAST:
ret = set_adv_mode_fast(p_advertising, &p_advertising->adv_params);
case BLE_ADV_MODE_SLOW:
ret = set_adv_mode_slow(p_advertising, &p_advertising->adv_params);
case BLE_ADV_MODE_IDLE:
p_advertising->adv_evt = BLE_ADV_EVT_IDLE;
if ( !is_connectable )
if (p_advertising->adv_mode_current != BLE_ADV_MODE_IDLE)
// take the latest status and prepare it encrypted and all
comm_tj_fill_status(true);
// call ble_advertising_advdata_update to swap enc_advdata[0] and enc_advdata[1] to ensure first advertise transmitted updated
comm_tj_pump_update_advertise();
// start advertising
ret = sd_ble_gap_adv_start(p_advertising->adv_handle, p_advertising->conn_cfg_tag);
if (ret != NRF_SUCCESS)
return ret;
p_advertising->evt_handler(p_advertising->adv_evt);
return ret;
