nRF52833 cannot reply to the ack automatically after it receives a packet from the nRF24L01+
The PTX is nRF24L01+ and the PRX is nRF52833.
The code for the nRF24L01+:
void RF24L01_Init( void )
    uint8_t addr[5] = {0x34,0x43,0x10,0x10,0x03};
    uint8_t txAddr[5] = {0x34,0x43,0x10,0x10,0x02};
    RF24L01_SET_CE_HIGH( );
    NRF24L01_Clear_IRQ_Flag( IRQ_ALL );
    NRF24L01_Write_Reg( DYNPD, ( 1 << 0 ) );
    NRF24L01_Write_Reg( FEATRUE, 0x07);
    NRF24L01_Read_Reg( DYNPD );
    NRF24L01_Read_Reg( FEATRUE );
    NRF24L01_Write_Reg( CONFIG, /*( 1<<MASK_RX_DR ) |*/
                                      ( 1 << EN_CRC ) |
                                      ( 1 << PWR_UP ) );
    NRF24L01_Write_Reg( EN_AA, ( 1 << ENAA_P0 ) );
    NRF24L01_Write_Reg( EN_RXADDR, ( 1 << ERX_P0 ) );
    NRF24L01_Write_Reg( SETUP_AW, AW_5BYTES );
    NRF24L01_Write_Reg( SETUP_RETR, ARD_4000US |
                        ( REPEAT_CNT & 0x0F ) );
    NRF24L01_Write_Reg( RF_CH, 10 );
    NRF24L01_Write_Reg( RF_SETUP, 0x26 );
    NRF24L01_Write_Reg( RX_PW_P0, 18 );
    NRF24L01_Set_TxAddr( &txAddr[0], 5 );
    NRF24L01_Set_RxAddr( 0, &addr[0], 5 );
    NRF24L01_Set_Speed(SPEED_2M);
    NRF24L01_Set_Power(POWER_0DBM);
uint8_t NRF24L01_TxPacket( uint8_t *txbuf, uint8_t Length )
	uint8_t l_Status = 0;
	uint32_t l_MsTimes = 0;
	RF24L01_SET_CS_LOW( );
    do
        uint8_t RegAddr = FLUSH_TX;
	    HAL_StatusTypeDef errorcode = HAL_OK;
        errorcode = HAL_SPI_Transmit(NF24L01_SPI, &RegAddr, 1, NF24L01_SPI_OP_TIMEOUT);
        if(errorcode != HAL_OK)
            printf("### NRF24L01_TxPacket fail %d ###\r\n", errorcode);
    } while (0);
	RF24L01_SET_CS_HIGH( );
	RF24L01_SET_CE_LOW( );
	NRF24L01_Write_Buf( WR_TX_PLOAD, txbuf, Length );
	l_MsTimes = xTaskGetTickCount();
	while( 0 != RF24L01_GET_IRQ_STATUS( ))
        if ((xTaskGetTickCount() - l_MsTimes) > 100)
			NRF24L01_Write_Reg(FLUSH_TX, 0xff);
			NRF24L01_Write_Reg(STATUS, 0x30);
	l_Status = NRF24L01_Read_Reg(STATUS);
	NRF24L01_Write_Reg( STATUS, l_Status );
	if( l_Status & MAX_TX )
		NRF24L01_Write_Reg( FLUSH_TX,0xff );
		return MAX_TX;
	if( l_Status & TX_OK )
		return TX_OK;
	return 0xFF;
Everytime I call NRF24L01_TxPacket to send out  32 bytes data I get the error code MAX_TX. But the nRF52833 actually has received the data.
So I think the  nRF52833 doesn't reply back to the  nRF24L01+ . And how do I fix this issue?
The nRF52833 sdk version is nRF5_SDK_17.1.0_ddde560.
And I use esb_prx  (pca10100e) this project.
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
#include "nrf_esb.h"
#include <stdbool.h>
#include <stdint.h>
#include "sdk_common.h"
#include "nrf.h"
#include "nrf_esb_error_codes.h"
#include "nrf_delay.h"
#include "nrf_gpio.h"
#include "nrf_error.h"
#include "boards.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
uint8_t led_nr;
nrf_esb_payload_t rx_payload;
/*lint -save -esym(40, BUTTON_1) -esym(40, BUTTON_2) -esym(40, BUTTON_3) -esym(40, BUTTON_4) -esym(40, LED_1) -esym(40, LED_2) -esym(40, LED_3) -esym(40, LED_4) */
void nrf_esb_event_handler(nrf_esb_evt_t const * p_event)
	static uint8_t count = 0;
    switch (p_event->evt_id)
        case NRF_ESB_EVENT_TX_SUCCESS:
            NRF_LOG_DEBUG("TX SUCCESS EVENT");
        case NRF_ESB_EVENT_TX_FAILED:
            NRF_LOG_DEBUG("TX FAILED EVENT");
        case NRF_ESB_EVENT_RX_RECEIVED:
            //NRF_LOG_DEBUG("RX RECEIVED EVENT");
            if (nrf_esb_read_rx_payload(&rx_payload) == NRF_SUCCESS)
                // Set LEDs identical to the ones on the PTX.
                nrf_gpio_pin_write(LED_1, !(rx_payload.data[1]%8>0 && rx_payload.data[1]%8<=4));
                nrf_gpio_pin_write(LED_2, !(rx_payload.data[1]%8>1 && rx_payload.data[1]%8<=5));
                nrf_gpio_pin_write(LED_3, !(rx_payload.data[1]%8>2 && rx_payload.data[1]%8<=6));
                nrf_gpio_pin_write(LED_4, !(rx_payload.data[1]%8>3));
                nrf_gpio_pin_write(LED_1, count % 2);
                nrf_gpio_pin_write(LED_2, count % 2);
                nrf_gpio_pin_write(LED_3, count % 2);
                nrf_gpio_pin_write(LED_4, count % 2);
								count++;
                //NRF_LOG_DEBUG("Receiving packet: Length == %d, rssi == %d", rx_payload.length, rx_payload.rssi);
void clocks_start( void )
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
void gpio_init( void )
uint32_t esb_init( void )
    uint32_t err_code;
    uint8_t base_addr_0[4] = {0x43,0x10,0x10,0x01};
    uint8_t base_addr_1[4] = {0x43,0x10,0x10,0x01};
    uint8_t addr_prefix[8] = {0x34, 0x34, 0xC3, 0xC4, 0xC5, 0xC6, 0xC7, 0xC8 };
    uint8_t base_addr_0[4] = {0x43,0x10,0x10,0x02};
    uint8_t base_addr_1[4] = {0x43,0x10,0x10,0x02};
    nrf_esb_config_t nrf_esb_config         = NRF_ESB_LEGACY_CONFIG;
    nrf_esb_config.payload_length           = 18;
    nrf_esb_config.protocol                 = NRF_ESB_PROTOCOL_ESB_DPL;
    nrf_esb_config.bitrate                  = NRF_ESB_BITRATE_2MBPS;
    nrf_esb_config.mode                     = NRF_ESB_MODE_PRX;
    nrf_esb_config.event_handler            = nrf_esb_event_handler;
    nrf_esb_config.selective_auto_ack       = true;
    err_code = nrf_esb_init(&nrf_esb_config);
    VERIFY_SUCCESS(err_code);
    err_code = nrf_esb_set_base_address_0(base_addr_0);
    err_code = nrf_esb_set_base_address_1(base_addr_1);
    err_code = nrf_esb_set_prefixes(addr_prefix, 8);
    err_code = nrf_esb_set_rf_channel(10);
    return err_code;
    uint32_t err_code;
    gpio_init();
    err_code = NRF_LOG_INIT(NULL);
    clocks_start();
    err_code = esb_init();
    NRF_LOG_DEBUG("Enhanced ShockBurst Receiver Example started.");
    err_code = nrf_esb_start_rx();
    while (true)
        //if (NRF_LOG_PROCESS() == false)
        //    __WFE();
/*lint -restore */
