I need a clarification about the update of gpiote driver. I've passed from the NCS 2.5.1 to the 2.6.1 and now I have issues in the configuration of my ppi infrastructure. The original code that works in the NCS 2.5.1 is
uint8_t taskChannel;
void Enable_Stream_Ppi_Infrastructure( void )
spiStartTaskAddr = nrfx_spim_start_task_address_get( &inertialSpiInst );
spiEndEventAddr = nrfx_spim_end_event_address_get( &inertialSpiInst );
timerCompareEventAddr = nrfx_timer_compare_event_address_get( &inertialReadingTimerInst, NRF_TIMER_CC_CHANNEL0 );
if ( nrfx_gpiote_channel_alloc( &taskChannel ) != NRFX_SUCCESS )
LOG_WRN( "\n[W] DEVICE - Allocation gpiote channel failed" );
return;
nrfx_gpiote_output_config_t outputConfig = NRFX_GPIOTE_DEFAULT_OUTPUT_CONFIG;
nrfx_gpiote_task_config_t taskConfig = {
.task_ch = taskChannel,
.polarity = NRF_GPIOTE_POLARITY_TOGGLE,
.init_val = NRF_GPIOTE_INITIAL_VALUE_HIGH
if ( nrfx_gpiote_output_configure( ICM20948_CS_PIN, &outputConfig, &taskConfig ) != NRFX_SUCCESS )
LOG_WRN( "\n[W] DEVICE - Configure ICM20948_CS_PIN failed" );
return;
nrfx_gpiote_out_task_enable( ICM20948_CS_PIN );
spiCsTaskAddr = nrfx_gpiote_out_task_address_get( ICM20948_CS_PIN );
if ( nrfx_ppi_channel_assign( spiStartPpiChan, timerCompareEventAddr, spiStartTaskAddr ) != NRFX_SUCCESS )
LOG_WRN( "\n[W] DEVICE - Assign spiStartPpiChan ppi channel to timerCompareEventAddr failed" );
return;
if ( nrfx_ppi_channel_fork_assign( spiStartPpiChan, spiCsTaskAddr ) != NRFX_SUCCESS )
LOG_WRN( "\n[W] DEVICE - Assign spiStartPpiChan ppi channel fork to spiCsTaskAddr failed" );
return;
if ( nrfx_ppi_channel_assign( spiEndPpiChan, spiEndEventAddr, spiCsTaskAddr ) != NRFX_SUCCESS )
LOG_WRN( "\n[W] DEVICE - Assign spiEndPpiChan ppi channel to spiEndEventAddr failed" );
return;
if ( nrfx_ppi_channel_enable( spiStartPpiChan ) != NRFX_SUCCESS )
LOG_WRN( "\n[W] DEVICE - Enable spiStartPpiChan ppi channel failed" );
return;
if ( nrfx_ppi_channel_enable( spiEndPpiChan ) != NRFX_SUCCESS )
LOG_WRN( "\n[W] DEVICE - Enable spiEndPpiChan ppi channel failed" );
return;
void Disable_Stream_Ppi_Infrastructure( void )
nrfx_gpiote_out_task_disable( ICM20948_CS_PIN );
nrfx_gpiote_pin_uninit( ICM20948_CS_PIN );
nrfx_gpiote_channel_free( taskChannel );
if ( nrfx_ppi_channel_disable( spiStartPpiChan ) != NRFX_SUCCESS )
LOG_WRN( "\n[W] DEVICE - Disable spiStartPpiChan ppi channel failed" );
return;
if ( nrfx_ppi_channel_disable( spiEndPpiChan ) != NRFX_SUCCESS )
LOG_WRN( "\n[W] DEVICE - Disable spiEndPpiChan ppi channel failed" );
return;
Now in the NCS 2.6.1 the gpiote driver needs to define a gpiote instance so I modified the code above:
nrfx_gpiote_t gpioteInstance;
if ( nrfx_gpiote_channel_alloc( &gpioteInstance, &taskChannel ) != NRFX_SUCCESS )
return;
if ( nrfx_gpiote_output_configure( &gpioteInstance, ICM20948_CS_PIN, &outputConfig, &taskConfig ) != NRFX_SUCCESS )
return;
nrfx_gpiote_out_task_enable( &gpioteInstance, ICM20948_CS_PIN );
spiCsTaskAddr = nrfx_gpiote_out_task_address_get( &gpioteInstance, ICM20948_CS_PIN );
return;
return;
return;
return;
return;
nrfx_gpiote_out_task_disable( &gpioteInstance, ICM20948_CS_PIN );
nrfx_gpiote_pin_uninit( &gpioteInstance, ICM20948_CS_PIN );
nrfx_gpiote_channel_free( &gpioteInstance, taskChannel );
return;
return;
But it doesn't work. Then I assumed that I had to initialize the instance with
if ( nrfx_gpiote_init( &gpioteInstance, 0 ) != NRFX_SUCCESS )
LOG_WRN( "\n[W] DEVICE - Initializzation gpiote instance failed" );
return;
but I found this example that for initializzation uses
#define GPIOTE_INST NRF_DT_GPIOTE_INST(DT_ALIAS(sw0), gpios)
const nrfx_gpiote_t gpiote = NRFX_GPIOTE_INSTANCE(GPIOTE_INST);
err = nrfx_gpiote_init(&gpiote, 0);
if (err != NRFX_SUCCESS) {
LOG_ERR("nrfx_gpiote_init error: 0x%08X", err);
return 0;
Now my doubts:
Is the use of NRFX_GPIOTE_INSTANCE(x) macro mandatory in the definition of gpiote instance? And if so, can anyone explain me the use of NRF_DT_GPIOTE_INST(DT_ALIAS(sw0), gpios)?
How to initialize in the rght way the gpiote driver in my case?
