LTE model not found.
I get the registration "parse_cereg: LTE mode not found, error code: -22" error,when try to connect to LTE network in china shenzhen.the hardware is custom use nrf9160 chip.can anyone help analysis the error?why  Network registration status is 4,what does it mean.and what is "fallback network mode"?thanks.
[00:00:00.667,083] <inf> main: Connecting to LTE...
[00:00:00.687,683] <dbg> lte_lc: init_and_config: System mode (4) and preference (0) configured
[00:00:00.700,347] <inf> main: Requesting EDRX mode
[00:01:13.940,887] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 4
[00:01:13.949,432] <dbg> lte_lc_helpers: parse_cereg: Network registration status: 4
[00:01:13.957,946] <dbg> lte_lc_helpers: parse_cereg: LTE mode not found, error code: -22
[00:01:13.966,949] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching events:
[00:01:13.975,860] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x00017A0D
[00:01:13.985,015] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x0000BC71
[00:01:13.994,140] <inf> main: ************************************* LTE event: 0
[00:01:14.002,380] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
[00:01:14.009,948] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching events:
[00:01:14.018,890] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x00017A0D
[00:01:14.028,015] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x0000BC71
[00:01:14.037,139] <inf> main: ************************************* LTE event: 4
[00:01:14.045,410] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
[00:10:00.757,781] <inf> lte_lc: Network connection attempt timed out
[00:10:00.772,735] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 0
[00:10:00.781,311] <dbg> lte_lc_helpers: parse_cereg: Network registration status: 0
[00:10:00.789,825] <dbg> lte_lc_helpers: parse_cereg: LTE mode not found, error code: -22
[00:10:00.798,797] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching events:
[00:10:00.807,739] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x00017A0D
[00:10:00.816,864] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x0000BC71
[00:10:00.825,988] <inf> main: ************************************* LTE event: 0
[00:10:00.834,197] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
[00:10:00.841,888] <inf> lte_lc: Using fallback network mode
[00:11:21.896,820] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"7879","078D412A",9
[00:11:21.907,226] <dbg> lte_lc_helpers: parse_cereg: Network registration status: 2
[00:11:21.915,771] <dbg> lte_lc_helpers: parse_cereg: LTE mode: 9
[00:11:21.922,637] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching events:
[00:11:21.931,610] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x00017A0D
[00:11:21.941,253] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x0000BC71
[00:11:21.950,378] <inf> main: ************************************* LTE event: 0
[00:11:21.958,618] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
[00:11:21.966,217] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching events:
[00:11:21.975,158] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x00017A0D
[00:11:21.984,313] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x0000BC71
[00:11:21.993,438] <inf> main: ************************************* LTE event: 4
[00:11:22.001,678] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
[00:11:22.009,277] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching events:
[00:11:22.018,218] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x00017A0D
[00:11:22.027,343] <dbg> lte_lc_helpers: event_handler_list_dispatch: - handler=0x0000BC71
[00:11:22.036,499] <inf> main: ************************************* LTE event: 5
[00:11:22.044,738] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    Looks like your application by default is trying to connect to LTE-M, but your network only supports NB-IoT.
    It is trying first to connect to LTE-M and then falls back to NB-IoT after failing.
    This means that it is using NB-IoT when it finally got connected.
    Michal
