Code that compiles just fine under V2.5.3 fails when using V2.6.1. It appears we have all the conditions met, not sure what we are missing.
warning: LOG_PRINTK (defined at subsys/logging\Kconfig.processing:8) has direct dependencies !USERSPACE && !LOG_MODE_MINIMAL && LOG with value n, but is currently being y-selected by the following symbols:
- LOG_BACKEND_RTT_FORCE_PRINTK (defined at subsys/logging\backends\Kconfig.rtt:103), with value y, direct dependencies LOG_BACKEND_RTT && !LOG_FRONTEND_ONLY && !LOG_MODE_MINIMAL && LOG (value: y), and select condition LOG_BACKEND_RTT && !LOG_FRONTEND_ONLY && !LOG_MODE_MINIMAL && LOG (value: y)
Here is our prj.conf for logging:
# Logging CONFIG_LOG=y CONFIG_USE_SEGGER_RTT=y CONFIG_LOG_BACKEND_RTT=y CONFIG_PRINTK=y CONFIG_LOG_MODE_IMMEDIATE=y # If below config is enabled, printk logs are # buffered. For unbuffered messages, disable this. CONFIG_LOG_PRINTK=y CONFIG_STDOUT_CONSOLE=y # For using printk CONFIG_CONSOLE=y CONFIG_RTT_CONSOLE=y #CONFIG_UART_RTT=y CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=2048 CONFIG_LOG_MODE_MINIMAL=n #CONFIG_LOG_BUFFER_SIZE=4096 CONFIG_UART_CONSOLE=n CONFIG_DEBUG_COREDUMP=n CONFIG_SERIAL=n
