i want collect modem trace logs for nRF9160, can you please help with steps how to collect modem trace logs
BR,
Pradeep Gamidi
BR,
Pradeep Gamidi
Hi Runar,
The log file generated contains unreadable data and cannot be imported into the Cellular Monitor because it is saved with a .log extension. Could you please provide guidance on how to generate a log file that can be used with the Cellular Monitor?
Hi Pradeep
Did you save the log as .bin as I wrote in the instructions? Just renmae the file from logfile.log to logfile.bin
runsiv said:
- Use the J-Link RTT logger to collect the trace or traces and save in binary (
.bin) format.
See SEGGER Real Time Transfer (RTT) for more information.- Load and playback the trace in Cellular Monitor.
See Loading modem traces for playback for more information.
Regards
Runar
Hi Runar,
As mentioned, I have saved the log file with a .bin extension. However, when I loaded this file into the Cellular Monitor, it did not display any data. I am attaching the log file for your reference.
Could you please assist in resolving this issue?
Hi
Could you confirm a thing for me. Are you connect to turkcell over NB-Iot? If so set AT%XEPCO=0 as Turkcell do not support ePCO. If you run into issues after that you can provide a new trace.
What is the issues you are experiencing?
Try
Regards
Runar
Hi Runar,
We are not using Turkcell; we are working with Cat M1 and enabling eDRX feature.
