i want collect modem trace logs for nRF9160, can you please help with steps how to collect modem trace logs
BR,
Pradeep Gamidi
BR,
Pradeep Gamidi
Hi
In the current release of Cellular Monitor, the RTT interface is not supported for traces capture. You can only view RTT modem traces captured outside of the tool.
To view RTT modem traces captured outside of the tool in Cellular Monitor, complete the following steps:
CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_RTT in the prj.conf file..bin) format.Regards
Runar
Hi Runar,
As mentioned in the Minimum Requirements and Limitations, my modem firmware version is 1.3.1 and SDK version is 1.7.0, which do not meet the minimum requirements for modem trace logging.
We are currently blocked by an eDRX issue and urgently need modem trace logs to resolve it. Could you please suggest any alternative methods to obtain these logs? If necessary, we can arrange a call to discuss this high-priority issue.
Hi
Since you are using RTT, could you try to use Segger RTT viewer and use log to file, and then import it into Cellular Monitor?
Regards
Runar
Hi Runar,
I have attempted to use the Segger RTT viewer for capturing logs, but I am not receiving all the logs. I have attached a screenshot for your reference.
Hi Pradeep
Was there anything in the log file? What did you see when you tried to import the log file into cellular monitor?
Regards
Runar
