Snoring detection using thingy53
I have been working on snoring detection using thingy53 project which is there in https://www.electromaker.io/project/view/snoring-detection-using-nordic-thingy53-backup#:~:text=When%20it%20detected%20the%20snoring,ring%20buffer%20to%20make%20decision.
The project is created on v2.0.0, it got build successfully but I am facing issues while flashing the code.
Getting, the below error related to jlink
-- west flash: using runner nrfjprog
-- runners.nrfjprog: mass erase requested
-- runners.nrfjprog: Flashing file: /opt/nordic/ncs/v2.0.0/zephyr/samples/basic/button/build/zephyr/zephyr.hex
[error] [SeggerBackend] - Error in dlopen: dlopen(/Applications/SEGGER/JLink/libjlinkarm.7.96.11.dylib, 0x0001): tried: '/Applications/SEGGER/JLink/libjlinkarm.7.96.11.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64')), '/System/Volumes/Preboot/Cryptexes/OS/Applications/SEGGER/JLink/libjlinkarm.7.96.11.dylib' (no such file), '/Applications/SEGGER/JLink/libjlinkarm.7.96.11.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64')), '/Applications/SEGGER/JLink_V796k/libjlinkarm.7.96.11.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64')), '/System/Volumes/Preboot/Cryptexes/OS/Applications/SEGGER/JLink_V796k/libjlinkarm.7.96.11.dylib' (no such file), '/Applications/SEGGER/JLink_V796k/libjlinkarm.7.96.11.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64'))
[error] [ Worker] - Dll failed to open.
[error] [ Client] - Encountered error -101: Command open executed for 22 milliseconds with result -101
ERROR: JLinkARM DLL load failed. Try again. If it keeps failing, please
ERROR: reinstall latest JLinkARM from Segger webpage.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 32: nrfjprog --program /opt/nordic/ncs/v2.0.0/zephyr/samples/basic/button/build/zephyr/zephyr.hex --chiperase --verify -f NRF53 --snr 1050088816 --coprocessor CP_APPLICATION
    Based on the error messages, it looks like you don't have the 'universal' version of the J-link drivers installed.
    https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/installation/recommended_versions.html#nrf_command_line_tools
    Please try to uninstall your current Jlink driver then install the latest nRF command line tools package available at https://www.nordicsemi.com/Products/Development-tools/nRF-Command-Line-Tools/Download?lang=en#infotabs
    Vidar
  • Also I am working on to make the code compatible with nrf sdk v2.5.2 anything which you would like to add to keep in mind while converting
  • I would start by building your project against v2.5.2 to see if you encounter any build errors. Then, read through the release notes and migration documents to see if there are any breaking changes that are relevant to your application.
  • For my case when I try to build the code on v2.5.2, I get errors related to dependency loop
    Attaching it for reference
     *  Executing task: nRF Connect: Build [pristine]: wifi_over_http/build (active)
    Building wifi_over_http
    west build --build-dir /opt/nordic/nrf/samples/bluetooth/wifi_over_http/build /opt/nordic/nrf/samples/bluetooth/wifi_over_http --pristine --board nrf7002dk_nrf5340_cpuapp_ns --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/opt/nordic/nrf/samples/bluetooth/wifi_over_http;/opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection;/opt/nordic/ncs/v2.5.2/zephyr/samples/drivers/led_ws2812;/opt/nordic/nrf/samples/bluetooth/nRF_tinaZ-master;/opt/nordic/nrf/samples/bluetooth/wifi_try -DCACHED_CONF_FILE=/opt/nordic/nrf/samples/bluetooth/wifi_over_http/prj.conf;/opt/nordic/nrf/samples/bluetooth/wifi_over_http/boards/nrf7002dk_nrf5340_cpuapp_ns.conf -DDTC_OVERLAY_FILE=/opt/nordic/nrf/samples/bluetooth/wifi_over_http/app.overlay;/opt/nordic/nrf/samples/bluetooth/wifi_over_http/boards/nrf7002dk_nrf5340_cpuapp_ns.overlay
    -- Application: /opt/nordic/nrf/samples/bluetooth/wifi_over_http
    -- CMake version: 3.20.5
    -- Found Python3: /opt/nordic/ncs/toolchains/20d68df7e5/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: /Users/rakshitamundra/Library/Caches/zephyr
    -- Zephyr version: 3.4.99 (/opt/nordic/ncs/v2.5.2/zephyr)
    -- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
    -- Board: nrf7002dk_nrf5340_cpuapp_ns
    -- Found host-tools: zephyr 0.16.1 (/opt/nordic/ncs/toolchains/20d68df7e5/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.1 (/opt/nordic/ncs/toolchains/20d68df7e5/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/20d68df7e5/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /opt/nordic/nrf/samples/bluetooth/wifi_over_http/boards/arm/nrf7002dk_nrf5340_cpuapp/nrf7002dk_nrf5340_cpuapp_ns.dts
    -- Found devicetree overlay: /opt/nordic/nrf/samples/bluetooth/wifi_over_http/app.overlay
    -- Found devicetree overlay: /opt/nordic/nrf/samples/bluetooth/wifi_over_http/boards/nrf7002dk_nrf5340_cpuapp_ns.overlay
    -- Generated zephyr.dts: /opt/nordic/nrf/samples/bluetooth/wifi_over_http/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /opt/nordic/nrf/samples/bluetooth/wifi_over_http/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /opt/nordic/nrf/samples/bluetooth/wifi_over_http/build/zephyr/dts.cmake
    warning: LOG_PRINTK (defined at subsys/logging/Kconfig.processing:8) was assigned the value 'n' but
    got the value 'y'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_PRINTK and/or
    look up LOG_PRINTK in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: Experimental symbol TFM_EXPERIMENTAL is enabled.
    warning: Experimental symbol HTTP_CLIENT is enabled.
    warning: Experimental symbol NET_CONNECTION_MANAGER is enabled.
    Parsing /opt/nordic/ncs/v2.5.2/zephyr/Kconfig
    Loaded configuration '/opt/nordic/nrf/samples/bluetooth/wifi_over_http/boards/arm/nrf7002dk_nrf5340_cpuapp/nrf7002dk_nrf5340_cpuapp_ns_defconfig'
    Merged configuration '/opt/nordic/nrf/samples/bluetooth/wifi_over_http/prj.conf'
    Merged configuration '/opt/nordic/nrf/samples/bluetooth/wifi_over_http/boards/nrf7002dk_nrf5340_cpuapp_ns.conf'
    Configuration saved to '/opt/nordic/nrf/samples/bluetooth/wifi_over_http/build/zephyr/.config'
    Kconfig header saved to '/opt/nordic/nrf/samples/bluetooth/wifi_over_http/build/zephyr/include/generated/autoconf.h'
    -- Found GnuLd: /opt/nordic/ncs/toolchains/20d68df7e5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /opt/nordic/ncs/toolchains/20d68df7e5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /opt/nordic/nrf/samples/bluetooth/wifi_over_http/build
    [1/456] Preparing syscall dependency handling
    [8/456] Generating include/generated/version.h
    -- Zephyr version: 3.4.99 (/opt/nordic/ncs/v2.5.2/zephyr), build: 4b5ef270413a
    [9/456] Generating ../../tfm/CMakeCache.txt
    CMake Warning at cmake/version.cmake:22 (message):
      Actual TF-M version is not available from Git repository.  Settled to
      v1.8.0
      CMakeLists.txt:22 (include)
    -- Found Git: /opt/nordic/ncs/toolchains/20d68df7e5/bin/git (found version "2.37.3")
    -- Found Python3: /opt/nordic/ncs/toolchains/20d68df7e5/opt/[email protected]/bin/python3.9 (found version "3.9.6") found components: Interpreter
    CMake Deprecation Warning at /opt/nordic/ncs/v2.5.2/zephyr/cmake/modules/FindDeprecated.cmake:121 (message):
      'PYTHON_PREFER' variable is deprecated.  Please use Python3_EXECUTABLE
      instead.
      /opt/nordic/ncs/v2.5.2/zephyr/cmake/modules/python.cmake:16 (find_package)
      /opt/nordic/ncs/v2.5.2/zephyr/cmake/modules/user_cache.cmake:30 (include)
      /opt/nordic/ncs/v2.5.2/zephyr/cmake/modules/extensions.cmake:5 (include)
      /opt/nordic/ncs/v2.5.2/nrf/subsys/nrf_security/tfm/CMakeLists.txt:36 (include)
    -- Configuring done
    -- Generating done
    [209/213] Linking C executable bin/tfm_s.axf
               FLASH:      114064 B       256 KB     43.51%
                 RAM:       55476 B        96 KB     56.43%
    [16/456] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    [111/456] Building C object CMakeFiles/app.dir/src/main.c.obj
    ../src/main.c: In function 'nrf_cal_set_time':
    ../src/main.c:197:28: warning: unused variable 'difftime' [-Wunused-variable]
      197 |     time_t uncal_difftime, difftime, newtime;
    ../src/main.c:197:12: warning: unused variable 'uncal_difftime' [-Wunused-variable]
    ../src/main.c: In function 'uart_cb':
    ../src/main.c:279:25: warning: implicit declaration of function 'new_process_uart_data'; did you mean 'process_uart_data'? [-Wimplicit-function-declaration]
      279 |                         new_process_uart_data(buf->data);
          |                         process_uart_data
    ../src/main.c: In function 'uart_init':
    ../src/main.c:393:29: warning: unused variable 'tx' [-Wunused-variable]
      393 |         struct uart_data_t *tx;
    ../src/main.c:391:13: warning: unused variable 'pos' [-Wunused-variable]
      391 |         int pos;
    ../src/main.c: At top level:
    ../src/main.c:761:6: warning: conflicting types for 'new_process_uart_data'; have 'void(const char *)'
      761 | void new_process_uart_data(const char *uart_data) {
    ../src/main.c:279:25: note: previous implicit declaration of 'new_process_uart_data' with type 'void(const char *)'
    ../src/main.c: In function 'new_process_uart_data':
    ../src/main.c:771:16: warning: 'return' with a value, in function returning void [-Wreturn-type]
      771 |         return 1;
    ../src/main.c:761:6: note: declared here
    ../src/main.c: In function 'storing_functionality_1':
    ../src/main.c:973:22: warning: implicit declaration of function 'is_sd_card_empty' [-Wimplicit-function-declaration]
      973 |                 if(!(is_sd_card_empty(filename)))        // if sd card is empty send the received data directly to cloud
    ../src/main.c:1396:12: warning: 'clear_file' defined but not used [-Wunused-function]
     1396 | static int clear_file(const char *filename)
    ../src/main.c:169:29: warning: 'sw2_cb_data' defined but not used [-Wunused-variable]
      169 | static struct gpio_callback sw2_cb_data;
    ../src/main.c:168:29: warning: 'sw1_cb_data' defined but not used [-Wunused-variable]
      168 | static struct gpio_callback sw1_cb_data;
    ../src/main.c:113:16: warning: 'count_data' defined but not used [-Wunused-variable]
      113 | static uint8_t count_data = 0;
    ../src/main.c:94:32: warning: 'server' defined but not used [-Wunused-variable]
       94 | static struct sockaddr_storage server;
    ../src/main.c:93:12: warning: 'sock' defined but not used [-Wunused-variable]
       93 | static int sock;
    ../src/main.c:91:12: warning: 'counter' defined but not used [-Wunused-variable]
       91 | static int counter = 0;
    ../src/main.c:88:13: warning: 'client_id_buf' defined but not used [-Wunused-variable]
       88 | static char client_id_buf[CLIENT_ID_SIZE+2];
    ../src/main.c:87:13: warning: 'recv_buf' defined but not used [-Wunused-variable]
       87 | static char recv_buf[RECV_BUF_SIZE];
    [454/456] Linking C executable zephyr/zephyr.elf
               FLASH:      557404 B       704 KB     77.32%
                 RAM:      265836 B       352 KB     73.75%
            IDT_LIST:          0 GB         2 KB      0.00%
    [456/456] Generating zephyr/merged.hex
     *  Executing task: nRF Connect: Build [pristine]: thingy53_snoring_detection/build (active)
    Building thingy53_snoring_detection
    west build --build-dir /opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/build /opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection --pristine --board thingy53_nrf5340_cpuapp --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/opt/nordic/nrf/samples/bluetooth/wifi_over_http;/opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection -Dhci_rpmsg_OVERLAY_CONFIG=/opt/nordic/ncs/v2.0.0/nrf/subsys/bootloader/image/secure_boot.conf;/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/partition_manager_enabled.conf -Dmcuboot_DTC_OVERLAY_FILE=/opt/nordic/ncs/v2.0.0/nrf/modules/mcuboot/flash_sim.overlay;/opt/nordic/ncs/v2.0.0/nrf/modules/mcuboot/usb.overlay -Dmcuboot_OVERLAY_CONFIG=/opt/nordic/ncs/v2.0.0/nrf/subsys/pcd/pcd.conf;/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf;/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/partition_manager_enabled.conf -DCACHED_CONF_FILE=/opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/prj.conf;/opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/boards/thingy53_nrf5340_cpuapp.conf -DDTC_OVERLAY_FILE=/opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/boards/thingy53_nrf5340_cpuapp.overlay
    -- Application: /opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection
    -- Board: thingy53_nrf5340_cpuapp
    -- Found BOARD.dts: /opt/nordic/ncs/v2.5.2/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpuapp.dts
    -- Found devicetree overlay: /opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/boards/thingy53_nrf5340_cpuapp.overlay
    'label' is marked as deprecated in 'properties:' in /opt/nordic/ncs/v2.5.2/zephyr/dts/bindings/serial/zephyr,cdc-acm-uart.yaml for node /soc/peripheral@50000000/usbd@36000/cdc_acm_uart0.
    'label' is marked as deprecated in 'properties:' in /opt/nordic/ncs/v2.5.2/zephyr/dts/bindings/flash_controller/zephyr,sim-flash.yaml for node /soc/nordic_ram-flash-controller@0.
    'label' is marked as deprecated in 'properties:' in /opt/nordic/ncs/v2.5.2/zephyr/dts/bindings/mtd/soc-nv-flash.yaml for node /soc/nordic_ram-flash-controller@0/flash_sim@0.
    node '/soc/peripheral@50000000/i2c@9000/vm3011@60' compatible 'vesper,vm3011' has unknown vendor prefix 'vesper'
    -- Generated zephyr.dts: /opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/build/zephyr/dts.cmake
    Parsing /opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/Kconfig
    /opt/nordic/ncs/v2.5.2/zephyr/scripts/kconfig/kconfig.py: Dependency loop
    I2C (defined at boards/arm/thingy53_nrf5340/Kconfig.defconfig:95, drivers/i2c/Kconfig:9), with definition...
    config I2C
            bool
            default y
            depends on !TRUSTED_EXECUTION_SECURE && (BOARD_THINGY53_NRF5340_CPUAPP || BOARD_THINGY53_NRF5340_CPUAPP_NS)
    menuconfig I2C
            bool "Inter-Integrated Circuit (I2C) bus drivers"
            help
              Enable I2C Driver Configuration
    (select-related dependencies: (ADC_ADS1X1X && (DT_HAS_TI_ADS1013_ENABLED || DT_HAS_TI_ADS1014_ENABLED || DT_HAS_TI_ADS1015_ENABLED || DT_HAS_TI_ADS1113_ENABLED || DT_HAS_TI_ADS1114_ENABLED || DT_HAS_TI_ADS1115_ENABLED || DT_HAS_TI_ADS1119_ENABLED) && ADC) || (ADC_ADS1112 && DT_HAS_TI_ADS1112_ENABLED && ADC) || (ADC_ADS1119 && DT_HAS_TI_ADS1119_ENABLED && ADC) || (ADC_TLA2021 && DT_HAS_TI_TLA2021_ENABLED && ADC) || (AUXDISPLAY_JHD1313 && DT_HAS_JHD_JHD1313_ENABLED && AUXDISPLAY) || (AUDIO_TLV320DAC && DT_HAS_TI_TLV320DAC_ENABLED && GPIO && AUDIO_CODEC && AUDIO) || (BBRAM_MICROCHIP_MCP7940N && DT_HAS_MICROCHIP_MCP7940N_ENABLED && BBRAM) || (COUNTER_MICROCHIP_MCP7940N && DT_HAS_MICROCHIP_MCP7940N_ENABLED && COUNTER) || (DAC_DACX3608 && (DT_HAS_TI_DAC43608_ENABLED || DT_HAS_TI_DAC53608_ENABLED) && DAC) || (DAC_MCP4725 && DT_HAS_MICROCHIP_MCP4725_ENABLED && DAC) || (DAC_MCP4728 && DT_HAS_MICROCHIP_MCP4728_ENABLED && DAC) || (EEPROM_AT24 && DT_HAS_ATMEL_AT24_ENABLED && EEPROM) || (EEPROM_MB85RCXX && DT_HAS_FUJITSU_MB85RCXX_ENABLED && EEPROM) || (MAX17048 && DT_HAS_MAXIM_MAX17048_ENABLED && FUEL_GAUGE) || (SBS_GAUGE_NEW_API && DT_HAS_SBS_SBS_GAUGE_NEW_API_ENABLED && FUEL_GAUGE) || (GPIO_AXP192 && DT_HAS_X_POWERS_AXP192_GPIO_ENABLED && DT_HAS_X_POWERS_AXP192_ENABLED && GPIO) || (GPIO_SX1509B && DT_HAS_SEMTECH_SX1509B_ENABLED && GPIO) || (GPIO_PCAL64XXA && (DT_HAS_NXP_PCAL6408A_ENABLED || DT_HAS_NXP_PCAL6416A_ENABLED) && GPIO) || (GPIO_PCA953X && DT_HAS_TI_TCA9538_ENABLED && GPIO) || (GPIO_PCF8574 && DT_HAS_NXP_PCF8574_ENABLED && GPIO) || (GPIO_NPM1300 && DT_HAS_NORDIC_NPM1300_GPIO_ENABLED && GPIO) || (GPIO_NPM6001 && DT_HAS_NORDIC_NPM6001_GPIO_ENABLED && GPIO) || (INPUT_CAP1203 && DT_HAS_MICROCHIP_CAP1203_ENABLED && INPUT) || (INPUT_CST816S && DT_HAS_HYNITRON_CST816S_ENABLED && INPUT) || (INPUT_FT5336 && DT_HAS_FOCALTECH_FT5336_ENABLED && INPUT) || (INPUT_GT911 && DT_HAS_GOODIX_GT911_ENABLED && INPUT) || (HT16K33 && DT_HAS_HOLTEK_HT16K33_ENABLED && LED) || (IS31FL3216A && DT_HAS_ISSI_IS31FL3216A_ENABLED && LED) || (LP3943 && DT_HAS_TI_LP3943_ENABLED && LED) || (LP50XX && (DT_HAS_TI_LP5009_ENABLED || DT_HAS_TI_LP5012_ENABLED || DT_HAS_TI_LP5018_ENABLED || DT_HAS_TI_LP5024_ENABLED || DT_HAS_TI_LP5030_ENABLED || DT_HAS_TI_LP5036_ENABLED) && LED) || (LP5562 && DT_HAS_TI_LP5562_ENABLED && LED) || (LP5569 && DT_HAS_TI_LP5569_ENABLED && LED) || (NCP5623 && DT_HAS_ONNN_NCP5623_ENABLED && LED) || (LED_NPM1300 && DT_HAS_NORDIC_NPM1300_LED_ENABLED && LED) || (PCA9633 && DT_HAS_NXP_PCA9633_ENABLED && LED) || (TLC59108 && DT_HAS_TI_TLC59108_ENABLED && LED) || (IS31FL3733 && DT_HAS_ISSI_IS31FL3733_ENABLED && LED) || (MFD_AXP192 && DT_HAS_X_POWERS_AXP192_ENABLED && MFD) || (MFD_NPM1300 && DT_HAS_NORDIC_NPM1300_ENABLED && MFD) || (MFD_NPM6001 && DT_HAS_NORDIC_NPM6001_ENABLED && MFD) || (PWM_PCA9685 && DT_HAS_NXP_PCA9685_PWM_ENABLED && PWM) || (PWM_MAX31790 && DT_HAS_MAXIM_MAX31790_ENABLED && PWM) || (REGULATOR_AXP192 && DT_HAS_X_POWERS_AXP192_REGULATOR_ENABLED && DT_HAS_X_POWERS_AXP192_ENABLED && REGULATOR) || (REGULATOR_ADP5360 && DT_HAS_ADI_ADP5360_REGULATOR_ENABLED && REGULATOR) || (REGULATOR_NPM1300 && DT_HAS_NORDIC_NPM1300_REGULATOR_ENABLED && REGULATOR) || (REGULATOR_NPM6001 && DT_HAS_NORDIC_NPM6001_REGULATOR_ENABLED && REGULATOR) || (REGULATOR_PCA9420 && DT_HAS_NXP_PCA9420_ENABLED && REGULATOR) || (RTC_PCF8523 && DT_HAS_NXP_PCF8523_ENABLED && RTC) || (RTC_PCF8563 && DT_HAS_NXP_PCF8563_ENABLED && RTC) || (ADT7420 && DT_HAS_ADI_ADT7420_ENABLED && SENSOR) || (AK8975 && DT_HAS_ASAHI_KASEI_AK8975_ENABLED && SENSOR) || (AKM09918C && DT_HAS_ASAHI_KASEI_AKM09918C_ENABLED && SENSOR) || (AMG88XX && DT_HAS_PANASONIC_AMG88XX_ENABLED && SENSOR) || (AMS_AS5600 && DT_HAS_AMS_AS5600_ENABLED && SENSOR) || (AMS_IAQ_CORE && DT_HAS_AMS_IAQCORE_ENABLED && SENSOR) || (APDS9960 && DT_HAS_AVAGO_APDS9960_ENABLED && SENSOR) || (BH1750 && DT_HAS_ROHM_BH1750_ENABLED && SENSOR) || (BMA280 && DT_HAS_BOSCH_BMA280_ENABLED && SENSOR) || (BMC150_MAGN && DT_HAS_BOSCH_BMC150_MAGN_ENABLED && SENSOR) || (BME680 && DT_HAS_BOSCH_BME680_ENABLED && SENSOR) || (BMG160 && DT_HAS_BOSCH_BMG160_ENABLED && SENSOR) || (BMI08X && (n || n) && (DT_HAS_BOSCH_BMI08X_ACCEL_ENABLED || DT_HAS_BOSCH_BMI08X_GYRO_ENABLED) && SENSOR) || (BMM150 && DT_HAS_BOSCH_BMM150_ENABLED && SENSOR) || (BQ274XX && DT_HAS_TI_BQ274XX_ENABLED && SENSOR) || (CCS811 && DT_HAS_AMS_CCS811_ENABLED && SENSOR) || (DPS310 && DT_HAS_INFINEON_DPS310_ENABLED && SENSOR) || (ENS210 && DT_HAS_AMS_ENS210_ENABLED && SENSOR) || (FDC2X1X && DT_HAS_TI_FDC2X1X_ENABLED && (NEWLIB_LIBC || EXTERNAL_LIBC) && SENSOR) || (HMC5883L && DT_HAS_HONEYWELL_HMC5883L_ENABLED && SENSOR) || (HP206C && DT_HAS_HOPERF_HP206C_ENABLED && SENSOR) || (ICP10125 && DT_HAS_INVENSENSE_ICP10125_ENABLED && SENSOR) || (INA219 && DT_HAS_TI_INA219_ENABLED && SENSOR) || (INA23X && (DT_HAS_TI_INA230_ENABLED || DT_HAS_TI_INA237_ENABLED) && SENSOR) || (INA3221 && DT_HAS_TI_INA3221_ENABLED && SENSOR) || (ISL29035 && DT_HAS_ISIL_ISL29035_ENABLED && SENSOR) || (IST8310 && DT_HAS_ISENTEK_IST8310_ENABLED && SENSOR) || (LIS3MDL && DT_HAS_ST_LIS3MDL_MAGN_ENABLED && SENSOR) || (LM75 && DT_HAS_LM75_ENABLED && SENSOR) || (LM77 && DT_HAS_LM77_ENABLED && SENSOR) || (LPS22HB && DT_HAS_ST_LPS22HB_PRESS_ENABLED && SENSOR) || (LPS25HB && DT_HAS_ST_LPS25HB_PRESS_ENABLED && SENSOR) || (LSM303DLHC_MAGN && DT_HAS_ST_LSM303DLHC_MAGN_ENABLED && SENSOR) || (LSM6DS0 && DT_HAS_ST_LSM6DS0_ENABLED && SENSOR) || (LSM9DS0_GYRO && DT_HAS_ST_LSM9DS0_GYRO_ENABLED && SENSOR) || (LSM9DS0_MFD && DT_HAS_ST_LSM9DS0_MFD_ENABLED && SENSOR) || (MAX17055 && DT_HAS_MAXIM_MAX17055_ENABLED && SENSOR) || (MAX17262 && DT_HAS_MAXIM_MAX17262_ENABLED && SENSOR) || (MAX30101 && DT_HAS_MAXIM_MAX30101_ENABLED && SENSOR) || (MAX31875 && DT_HAS_MAXIM_MAX31875_ENABLED && SENSOR) || (MAX44009 && DT_HAS_MAXIM_MAX44009_ENABLED && SENSOR) || (MCP9600 && DT_HAS_MICROCHIP_MCP9600_ENABLED && SENSOR) || (MCP9808 && DT_HAS_MICROCHIP_MCP9808_ENABLED && SENSOR) || (MPR && DT_HAS_HONEYWELL_MPR_ENABLED && SENSOR) || (MPU6050 && DT_HAS_INVENSENSE_MPU6050_ENABLED && SENSOR) || (MPU9250 && DT_HAS_INVENSENSE_MPU9250_ENABLED && SENSOR) || (MS5837 && DT_HAS_MEAS_MS5837_ENABLED && SENSOR) || (NPM1300_CHARGER && DT_HAS_NORDIC_NPM1300_CHARGER_ENABLED && SENSOR) || (OPT3001 && DT_HAS_TI_OPT3001_ENABLED && SENSOR) || (S11059 && DT_HAS_HAMAMATSU_S11059_ENABLED && SENSOR) || (SBS_GAUGE && DT_HAS_SBS_SBS_GAUGE_ENABLED && SENSOR) || (SGP40 && DT_HAS_SENSIRION_SGP40_ENABLED && SENSOR) || (SHT3XD && DT_HAS_SENSIRION_SHT3XD_ENABLED && SENSOR) || (SHT4X && DT_HAS_SENSIRION_SHT4X_ENABLED && SENSOR) || (SHTCX && DT_HAS_SENSIRION_SHTCX_ENABLED && SENSOR) || (SI7006 && DT_HAS_SILABS_SI7006_ENABLED && SENSOR) || (SI7055 && DT_HAS_SILABS_SI7055_ENABLED && SENSOR) || (SI7060 && DT_HAS_SILABS_SI7060_ENABLED && SENSOR) || (SI7210 && DT_HAS_SILABS_SI7210_ENABLED && SENSOR) || (STTS751 && DT_HAS_ST_STTS751_ENABLED && SENSOR) || (SX9500 && DT_HAS_SEMTECH_SX9500_ENABLED && SENSOR) || (TCN75A && DT_HAS_MICROCHIP_TCN75A_ENABLED && SENSOR) || (TCS3400 && DT_HAS_AMS_TCS3400_ENABLED && SENSOR) || (TH02 && DT_HAS_HOPERF_TH02_ENABLED && SENSOR) || (TI_HDC && DT_HAS_TI_HDC_ENABLED && SENSOR) || (TI_HDC20XX && (DT_HAS_TI_HDC2010_ENABLED || DT_HAS_TI_HDC2021_ENABLED || DT_HAS_TI_HDC2022_ENABLED || DT_HAS_TI_HDC2080_ENABLED) && SENSOR) || (TMD2620 && DT_HAS_AMS_TMD2620_ENABLED && SENSOR) || (TMP007 && DT_HAS_TI_TMP007_ENABLED && SENSOR) || (TMP108 && (DT_HAS_TI_TMP108_ENABLED || DT_HAS_AMS_AS6212_ENABLED) && SENSOR) || (TMP112 && DT_HAS_TI_TMP112_ENABLED && SENSOR) || (TMP116 && DT_HAS_TI_TMP116_ENABLED && SENSOR) || (VCNL4040 && DT_HAS_VISHAY_VCNL4040_ENABLED && SENSOR) || (VEML7700 && DT_HAS_VISHAY_VEML7700_ENABLED && SENSOR) || (VL53L0X && DT_HAS_ST_VL53L0X_ENABLED && SENSOR) || (VL53L1X && DT_HAS_ST_VL53L1X_ENABLED && SENSOR) || (ITDS && DT_HAS_WE_WSEN_ITDS_ENABLED && SENSOR) || (VIDEO_MT9M114 && DT_HAS_APTINA_MT9M114_ENABLED && VIDEO) || (VIDEO_OV7725 && DT_HAS_OVTI_OV7725_ENABLED && VIDEO) || (VIDEO_OV2640 && DT_HAS_OVTI_OV2640_ENABLED && VIDEO) || (W1_DS2482_800 && DT_HAS_MAXIM_DS2482_800_ENABLED && W1) || (W1_DS2484 && DT_HAS_MAXIM_DS2484_ENABLED && W1) || (W1_DS2485 && DT_HAS_MAXIM_DS2485_ENABLED && W1) || (WDT_NPM1300 && DT_HAS_NORDIC_NPM1300_WDT_ENABLED && WATCHDOG) || (WDT_NPM6001 && DT_HAS_NORDIC_NPM6001_WDT_ENABLED && WATCHDOG))
    ...depends on GPIO_PCAL64XXA (defined at drivers/gpio/Kconfig.pcal64xxa:7), with definition...
    menuconfig GPIO_PCAL64XXA
            bool "PCAL64XXA I2C GPIO chip"
            default y
            select I2C
            depends on (DT_HAS_NXP_PCAL6408A_ENABLED || DT_HAS_NXP_PCAL6416A_ENABLED) && GPIO
            help
              Enable driver for PCAL64XXA I2C GPIO chip.
    ...depends on GPIO (defined at soc/arm/microchip_mec/mec1501/Kconfig.defconfig.mec1501hsz:11, soc/arm/microchip_mec/mec172x/Kconfig.defconfig.mec172xnlj:11, soc/arm/microchip_mec/mec172x/Kconfig.defconfig.mec172xnsz:11, soc/arm/nordic_nrf/Kconfig.defconfig:39, soc/arm/nxp_imx/mcimx7_m4/Kconfig.defconfig.mcimx7_m4:14, soc/arm/nxp_imx/mimx8ml8_m7/Kconfig.defconfig.mimx8ml8_m7:16, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1010:18, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1015:17, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1021:17, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1024:17, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1042:12, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1052:14, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1062:14, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1064:14, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1166_cm4:14, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1166_cm7:14, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1176_cm4:14, soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1176_cm7:14, soc/arm/nxp_kinetis/k2x/Kconfig.defconfig.mk22f12:11, soc/arm/nxp_kinetis/k6x/Kconfig.defconfig.mk64f12:15, soc/arm/nxp_kinetis/k6x/Kconfig.defconfig.mk66f18:15, soc/arm/nxp_kinetis/k8x/Kconfig.defconfig.series:22, soc/arm/nxp_kinetis/ke1xf/Kconfig.defconfig.series:36, soc/arm/nxp_kinetis/kv5x/Kconfig.defconfig.series:15, soc/arm/nxp_lpc/lpc54xxx/Kconfig.defconfig.lpc54114_m0:11, soc/arm/nxp_lpc/lpc55xxx/Kconfig.defconfig.lpc55S69_cpu1:11, drivers/gpio/Kconfig:6), with definition...
    config GPIO
            bool
            default y
            depends on SOC_MEC1501_HSZ && SOC_SERIES_MEC1501X
    config GPIO
            bool
            default y
            depends on SOC_MEC172X_NLJ && SOC_SERIES_MEC172X
    config GPIO
            bool
            default y
            depends on SOC_MEC172X_NSZ && SOC_SERIES_MEC172X
    config GPIO
            bool
            default y
            depends on SPI && SOC_FAMILY_NRF
    config GPIO
            bool
            default y
            depends on SOC_MCIMX7_M4 && SOC_SERIES_IMX7_M4
    config GPIO
            bool
            default y
            depends on SOC_MIMX8ML8 && SOC_SERIES_IMX8ML_M7
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1011 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1015 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1021 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1024 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1042 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1052 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1062 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1064 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1166_CM4 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1166_CM7 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1176_CM4 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MIMXRT1176_CM7 && SOC_SERIES_IMX_RT
    config GPIO
            bool
            default y
            depends on SOC_MK22F51212 && SOC_SERIES_KINETIS_K2X
    config GPIO
            bool
            default y
            depends on SOC_MK64F12 && SOC_SERIES_KINETIS_K6X
    config GPIO
            bool
            default y
            depends on SOC_MK66F18 && SOC_SERIES_KINETIS_K6X
    config GPIO
            bool
            default y
            depends on SOC_SERIES_KINETIS_K8X
    config GPIO
            bool
            default y
            depends on SOC_SERIES_KINETIS_KE1XF
    config GPIO
            bool
            default y
            depends on SOC_SERIES_KINETIS_KV5X
    config GPIO
            bool
            default n
            depends on SOC_LPC54114_M0 && SOC_SERIES_LPC54XXX
    config GPIO
            bool
            default y
            depends on SOC_LPC55S69_CPU1 && SOC_SERIES_LPC55XXX
    menuconfig GPIO
            bool "General-Purpose Input/Output (GPIO) drivers"
            help
              Include GPIO drivers in system config
    (select-related dependencies: (MPSL_FEM_NRF21540_GPIO && (n || n) && MPSL_FEM_NRF21540_GPIO_SUPPORT && <choice MPSL_FEM_CHOICE>) || (MPSL_FEM_NRF21540_GPIO_SPI && (n || n) && MPSL_FEM_NRF21540_GPIO_SPI_SUPPORT && <choice MPSL_FEM_CHOICE>) || (MPSL_CX_NRF700X && !MPSL_CX_PIN_FORWARDER && MPSL_CX_NRF700X_SUPPORT && <choice MPSL_CX_CHOICE>) || (MPSL_CX_THREAD && !MPSL_CX_PIN_FORWARDER && !BT && <choice MPSL_CX_CHOICE>) || (MPSL_CX_BT_1WIRE && SOC_SERIES_NRF52X && <choice MPSL_CX_CHOICE>) || DK_LIBRARY || NRF_SW_LPUART || (AUXDISPLAY_ITRON && DT_HAS_NORITAKE_ITRON_ENABLED && AUXDISPLAY) || (IEEE802154_RF2XX && DT_HAS_ATMEL_RF2XX_ENABLED && IEEE802154) || (REGULATOR_GPIO && DT_HAS_REGULATOR_GPIO_ENABLED && REGULATOR) || (SPI_SAM && DT_HAS_ATMEL_SAM_SPI_ENABLED && SPI) || (SPI_XMC4XXX && DT_HAS_INFINEON_XMC4XXX_SPI_ENABLED && SPI) || (WDT_NXP_FS26 && DT_HAS_NXP_FS26_WDOG_ENABLED && WATCHDOG) || (WIFI_ESWIFI && (DT_HAS_INVENTEK_ESWIFI_ENABLED || DT_HAS_INVENTEK_ESWIFI_UART_ENABLED) && WIFI))
    (imply-related dependencies: (MPSL_FEM_NRF21540_GPIO && (n || n) && MPSL_FEM_NRF21540_GPIO_SUPPORT && <choice MPSL_FEM_CHOICE>) || (MPSL_FEM_NRF21540_GPIO_SPI && (n || n) && MPSL_FEM_NRF21540_GPIO_SPI_SUPPORT && <choice MPSL_FEM_CHOICE>) || (MPSL_CX_NRF700X && !MPSL_CX_PIN_FORWARDER && MPSL_CX_NRF700X_SUPPORT && <choice MPSL_CX_CHOICE>) || (MPSL_CX_THREAD && !MPSL_CX_PIN_FORWARDER && !BT && <choice MPSL_CX_CHOICE>) || (MPSL_CX_BT_1WIRE && SOC_SERIES_NRF52X && <choice MPSL_CX_CHOICE>) || DK_LIBRARY || NRF_SW_LPUART || (AUXDISPLAY_ITRON && DT_HAS_NORITAKE_ITRON_ENABLED && AUXDISPLAY) || (IEEE802154_RF2XX && DT_HAS_ATMEL_RF2XX_ENABLED && IEEE802154) || (REGULATOR_GPIO && DT_HAS_REGULATOR_GPIO_ENABLED && REGULATOR) || (SPI_SAM && DT_HAS_ATMEL_SAM_SPI_ENABLED && SPI) || (SPI_XMC4XXX && DT_HAS_INFINEON_XMC4XXX_SPI_ENABLED && SPI) || (WDT_NXP_FS26 && DT_HAS_NXP_FS26_WDOG_ENABLED && WATCHDOG) || (WIFI_ESWIFI && (DT_HAS_INVENTEK_ESWIFI_ENABLED || DT_HAS_INVENTEK_ESWIFI_UART_ENABLED) && WIFI))
    ...depends on SPI_XMC4XXX (defined at drivers/spi/Kconfig.xmc4xxx:4), with definition...
    menuconfig SPI_XMC4XXX
            bool "XMC4XX SPI driver"
            default y
            select GPIO
            depends on DT_HAS_INFINEON_XMC4XXX_SPI_ENABLED && SPI
            help
              Enable XMC4XXX SPI driver.
    ...depends on SPI (defined at boards/shields/x_nucleo_idb05a1/Kconfig.defconfig:8, boards/arm/thingy53_nrf5340/Kconfig.defconfig:98, soc/arm/nxp_kinetis/k6x/Kconfig.defconfig.mk64f12:18, soc/arm/nxp_kinetis/kwx/Kconfig.defconfig.mkw2xd512:19, drivers/spi/Kconfig:9), with definition...
    config SPI
            bool
            default y
            depends on BT && SHIELD_X_NUCLEO_IDB05A1
    config SPI
            bool
            default y
    config SPI
            bool
            default n
    config SPI
            bool
            default y
            depends on (SOC_MKW22D5 || SOC_MKW24D5) && SOC_SERIES_KINETIS_KWX
    menuconfig SPI
            bool "Serial Peripheral Interface (SPI) bus drivers"
            help
              Enable support for the SPI hardware bus.
    (select-related dependencies: (NRF700X_ON_SPI && WIFI_NRF700X && WIFI) || (ADC_LMP90XXX && (DT_HAS_TI_LMP90077_ENABLED || DT_HAS_TI_LMP90078_ENABLED || DT_HAS_TI_LMP90079_ENABLED || DT_HAS_TI_LMP90080_ENABLED || DT_HAS_TI_LMP90097_ENABLED || DT_HAS_TI_LMP90098_ENABLED || DT_HAS_TI_LMP90099_ENABLED || DT_HAS_TI_LMP90100_ENABLED) && ADC) || (ADC_MCP320X && (DT_HAS_MICROCHIP_MCP3204_ENABLED || DT_HAS_MICROCHIP_MCP3208_ENABLED) && ADC) || (ADC_ADS7052 && DT_HAS_TI_ADS7052_ENABLED && ADC) || (ADC_ADS114S0X && DT_HAS_TI_ADS114S08_ENABLED && ADC) || (ADC_MAX1125X && (DT_HAS_MAXIM_MAX11254_ENABLED || DT_HAS_MAXIM_MAX11253_ENABLED) && ADC) || (AUXDISPLAY_PT6314 && DT_HAS_PTC_PT6314_ENABLED && AUXDISPLAY) || (CAN_MCP2515 && DT_HAS_MICROCHIP_MCP2515_ENABLED && CAN) || (DAC_DACX0508 && (DT_HAS_TI_DAC60508_ENABLED || DT_HAS_TI_DAC70508_ENABLED || DT_HAS_TI_DAC80508_ENABLED) && DAC) || (DAC_LTC166X && (DT_HAS_LLTC_LTC1660_ENABLED || DT_HAS_LLTC_LTC1665_ENABLED) && DAC) || (ILI9340 && DT_HAS_ILITEK_ILI9340_ENABLED && DISPLAY) || (ILI9341 && DT_HAS_ILITEK_ILI9341_ENABLED && DISPLAY) || (ILI9342C && DT_HAS_ILITEK_ILI9342C_ENABLED && DISPLAY) || (ILI9488 && DT_HAS_ILITEK_ILI9488_ENABLED && DISPLAY) || (SSD16XX && (DT_HAS_SOLOMON_SSD1608_ENABLED || DT_HAS_SOLOMON_SSD1673_ENABLED || DT_HAS_SOLOMON_SSD1675A_ENABLED || DT_HAS_SOLOMON_SSD1680_ENABLED || DT_HAS_SOLOMON_SSD1681_ENABLED) && DISPLAY) || (ST7735R && DT_HAS_SITRONIX_ST7735R_ENABLED && DISPLAY) || (ST7789V && DT_HAS_SITRONIX_ST7789V_ENABLED && DISPLAY) || (UC81XX && (DT_HAS_ULTRACHIP_UC8176_ENABLED || DT_HAS_ULTRACHIP_UC8179_ENABLED) && DISPLAY) || (LS0XX && DT_HAS_SHARP_LS0XX_ENABLED && DISPLAY) || (MAX7219 && DT_HAS_MAXIM_MAX7219_ENABLED && DISPLAY) || (EEPROM_AT25 && DT_HAS_ATMEL_AT25_ENABLED && EEPROM) || (ETH_ENC28J60 && DT_HAS_MICROCHIP_ENC28J60_ENABLED && ETH_DRIVER) || (ETH_ENC424J600 && DT_HAS_MICROCHIP_ENC424J600_ENABLED && ETH_DRIVER) || (ETH_W5500 && DT_HAS_WIZNET_W5500_ENABLED && ETH_DRIVER) || (ETH_ADIN2111 && (DT_HAS_ADI_ADIN2111_ENABLED || DT_HAS_ADI_ADIN1110_ENABLED) && ETH_DRIVER) || (SPI_FLASH_AT45 && DT_HAS_ATMEL_AT45_ENABLED && FLASH) || (SPI_NOR && DT_HAS_JEDEC_SPI_NOR_ENABLED && FLASH) || (IEEE802154_MCR20A && DT_HAS_NXP_MCR20A_ENABLED && IEEE802154) || (IEEE802154_RF2XX && DT_HAS_ATMEL_RF2XX_ENABLED && IEEE802154) || (IEEE802154_DW1000 && DT_HAS_DECAWAVE_DW1000_ENABLED && IEEE802154) || (INPUT_XPT2046 && DT_HAS_XPTEK_XPT2046_ENABLED && INPUT) || (FT800 && DT_HAS_FTDI_FT800_ENABLED) || (SPI_SDHC && DT_HAS_ZEPHYR_SDHC_SPI_SLOT_ENABLED && SDHC) || (ADT7310 && DT_HAS_ADI_ADT7310_ENABLED && SENSOR) || (ADXL362 && DT_HAS_ADI_ADXL362_ENABLED && SENSOR) || (BMI08X && (n || n) && (DT_HAS_BOSCH_BMI08X_ACCEL_ENABLED || DT_HAS_BOSCH_BMI08X_GYRO_ENABLED) && SENSOR) || (I3G4250D && DT_HAS_ST_I3G4250D_ENABLED && SENSOR) || (ICM42605 && DT_HAS_INVENSENSE_ICM42605_ENABLED && SENSOR) || (ICM42670 && DT_HAS_INVENSENSE_ICM42670_ENABLED && SENSOR) || (ICM42688 && DT_HAS_INVENSENSE_ICM42688_ENABLED && SENSOR) || (IIS3DHHC && DT_HAS_ST_IIS3DHHC_ENABLED && SENSOR) || (MAX31855 && DT_HAS_MAXIM_MAX31855_ENABLED && SENSOR) || (MAX31865 && DT_HAS_MAXIM_MAX31865_ENABLED && SENSOR) || (MAX6675 && DT_HAS_MAXIM_MAX6675_ENABLED && SENSOR) || (UHC_MAX3421E && DT_HAS_MAXIM_MAX3421E_SPI_ENABLED && UHC_DRIVER) || (WDT_NXP_FS26 && DT_HAS_NXP_FS26_WDOG_ENABLED && WATCHDOG) || (WIFI_WINC1500 && DT_HAS_ATMEL_WINC1500_ENABLED && WIFI) || (WIFI_ESWIFI_BUS_SPI && <choice WIFI_ESWIFI_BUS>))
    ...depends on ADC_ADS7052 (defined at drivers/adc/Kconfig.ads7052:5), with definition...
    config ADC_ADS7052
            bool "Texas instruments ADS7052 SPI"
            default y
            select SPI
            select ADC_CONFIGURABLE_INPUTS
            depends on DT_HAS_TI_ADS7052_ENABLED && ADC
            help
              Enable the driver implementation for the ADS7052
    ...depends on ADC (defined at drivers/adc/Kconfig:9), with definition...
    menuconfig ADC
            bool "Analog-to-Digital Converter (ADC) drivers"
            help
              Enable ADC (Analog to Digital Converter) driver configuration.
    (select-related dependencies: (MCP970X && DT_HAS_MICROCHIP_MCP970X_ENABLED && SENSOR) || (NTC_THERMISTOR && (DT_HAS_NTC_THERMISTOR_GENERIC_ENABLED || DT_HAS_EPCOS_B57861S0103A039_ENABLED) && SENSOR) || (STM32_VREF && DT_HAS_ST_STM32_VREF_ENABLED && SENSOR))
    ...depends on SENSOR (defined at /opt/nordic/ncs/v2.5.2/nrf/drivers/sensor/Kconfig:7, drivers/sensor/Kconfig:6), with definition...
    menuconfig SENSOR
            bool "Sensor Drivers"
            help
              Include sensor drivers in config
    menuconfig SENSOR
            bool "Sensor drivers"
            help
              Include sensor drivers in system config
    (select-related dependencies: (BT_BAS && BT_CONN && BT_RPC_STACK) || (BT_BAS && BT_CONN && BT_CONN && BT_HCI_HOST && BT_RPC_STACK) || (NRF_802154_SL_OPENSOURCE && NRF_802154_TEMPERATURE_UPDATE && <choice NRF_802154_SL_TYPE>) || (VM3011 && I2C) || (NRF_802154_SL && NRF_802154_TEMPERATURE_UPDATE && !NRF_802154_SOURCE_HAL_NORDIC && <choice NRF_802154_SL_TYPE>) || (NRF_802154_SL_OPENSOURCE && NRF_802154_TEMPERATURE_UPDATE && <choice NRF_802154_SL_TYPE>) || (CLOCK_CONTROL_NRF_USES_TEMP_SENSOR && HAS_HW_NRF_TEMP && CLOCK_CONTROL_NRF_DRIVER_CALIBRATION && CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION && CLOCK_CONTROL_NRF && CLOCK_CONTROL) || (BT_BAS && BT_CONN && BT_CONN && BT_HCI_HOST && BT_HCI && BT))
    ...depends on VM3011 (defined at /opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/drivers/vm3011/Kconfig.vm3011:4), with definition...
    menuconfig VM3011
            bool "VM3011 dmic"
            select NRFX_PDM
            select SENSOR
            depends on I2C
            help
              Enable driver for VM3011 Digital MEMS Microphone.
    ...depends again on I2C (defined at boards/arm/thingy53_nrf5340/Kconfig.defconfig:95, drivers/i2c/Kconfig:9)
    CMake Error at /opt/nordic/ncs/v2.5.2/zephyr/cmake/modules/kconfig.cmake:348 (message):
      command failed with return code: 1
      /opt/nordic/ncs/v2.5.2/nrf/cmake/modules/kconfig.cmake:29 (include)
      /opt/nordic/ncs/v2.5.2/zephyr/cmake/modules/zephyr_default.cmake:129 (include)
      /opt/nordic/ncs/v2.5.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      /opt/nordic/ncs/v2.5.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:15 (find_package)
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/20d68df7e5/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/20d68df7e5/opt/[email protected]/bin/python3.9 -B/opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/build -GNinja -DBOARD=thingy53_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION=NONE '-DBOARD_ROOT=/opt/nordic/nrf/samples/bluetooth/wifi_over_http;/opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection' '-Dhci_rpmsg_OVERLAY_CONFIG=/opt/nordic/ncs/v2.0.0/nrf/subsys/bootloader/image/secure_boot.conf;/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/partition_manager_enabled.conf' '-Dmcuboot_DTC_OVERLAY_FILE=/opt/nordic/ncs/v2.0.0/nrf/modules/mcuboot/flash_sim.overlay;/opt/nordic/ncs/v2.0.0/nrf/modules/mcuboot/usb.overlay' '-Dmcuboot_OVERLAY_CONFIG=/opt/nordic/ncs/v2.0.0/nrf/subsys/pcd/pcd.conf;/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf;/opt/nordic/ncs/v2.0.0/nrf/subsys/partition_manager/partition_manager_enabled.conf' '-DCACHED_CONF_FILE=/opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/prj.conf;/opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/boards/thingy53_nrf5340_cpuapp.conf' -DDTC_OVERLAY_FILE=/opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection/boards/thingy53_nrf5340_cpuapp.overlay -S/opt/nordic/nrf/samples/bluetooth/thingy53_snoring_detection
     *  The terminal process terminated with exit code: 1.
