Zephyr i2s echo code channel number
Im currently adjusting this i2s sample code to work with my TAS2781 audio amplifier. The code works perfectly  but I just want to do a little adjustment on the channel number to 4 to give me a 64 ratio as per table 3(i2s nordic documentation) of the config clock set to "ACLK" using the settings below. Once I have change the channel from 2 --> 4 the code stop communication to the i2s channel.
I'm very new to this drivers and I would appreciate if you could suggest what I need to change on the macros below.
also, is there any plans to make the zephyr i2s drive to work with format "config.format = I2S_FMT_DATA_FORMAT_PCM_SHORT;"?
Lanz
