Restricting some GATT characteristics to a bonded device
I'm implementing a BLE GATT peripheral that has no display but it does have a button.
I'd like to make some characteristics only available to devices that are BONDED but all of the docs I've read so far talk about pairing, or what I think are equivalent words like "encryption" or "authentication".
E.g. I've found flags like BT_GATT_PERM_WRITE_LESC|BT_GATT_PERM_WRITE_ENCRYPT and some doc about whitelisting, but the descriptions of both suggest they're only looking at the current connection, not whether the connection is to a device from the bond list. And I can't add BT_GATT_PERM_WRITE_AUTHEN because it's got no display.
Anyone have any pointers how to do this? Or am I just misunderstanding the doc?
Seems like I should say why, in case there's another way to do a similar thing.
I don't actually care about MITM for this - it's a wearable and I really only want to make it harder for some random to flatten the battery. Sure MITM could do that but it'd be noticed and they'd have to follow the person constantly.
So really I only care whether whether I'm currently connected to the phone (or potentially MITM) the nRF was bonded to. Plan is to use JustWorks but only allow a bonding to occur for a short period after the button was pressed.
But let's say I've already been through the bonding process with some phone but that phone's now out of range and disconnected. If another device comes along I believe it could initiate a pair and create a link with encryption (but not authentication) but stop before bonding without the user even knowing it happened. It sounds like this would be a gap in the security, even though it doesn't seem actual phones do this.
Bill
  • Hi Bill,
    I am a little confused why you don't limit connection establishment and pairing entirely, but just bonding.
    Also, can you not also setup the device to ask for user's explicit permission before accepting a pairing request?
    A GATT characteristic permission can only limit read/write access on the basis of whether pairing has happened or not, and what level of security such pairing achieves. It doesn't care if the paired peer is also bonded.
    If your device really needs to allow that scenario where a rogue device can pair with it, then perhaps you can see if you can reject an attempt to read/write an attribute based on whether the device is in the list of bonded device or not.
    I haven't checked to be sure, but you can try using the read and write callbacks field when declaring your Characteristic with BT_GATT_CHARACTERISTIC.
    Refer to LBS implementation: https://github.com/nrfconnect/sdk-nrf/blob/v2.6.1/subsys/bluetooth/services/lbs.c
    Hieu
  • Hi Hieu,
    Thanks for the response. Yes I did wonder if I was overthinking this, seems like something that should be solved already.
    Well I thought that would also prevent a previously bonded device from reconnecting, e.g. if it was out of range and comes back?
    This is why I was looking at whitelisting, but best I can tell that's only looking at the MAC, which is spoofable (IRK doesn't prevent that).
    Definitely open to trying ideas like this though - what is the usual way to block all pairing?
    E.g. I've been experimenting with
    struct bt_conn_auth_cb but not sure which is the best option.
    Can you not also setup the device to ask for user's explicit permission before accepting a pairing request?
    Well there's no display or other output that seems usable to inform the user that there's a pairing request.
    So ideally I'd like to let the bonded device back in without user interaction.
    Yeah, I wondered if there might be a way to check the connection state (is it bonded) during the callback, I'll look into it some more.
  • Hi Bill,
    Right, if you want the bonded peer to always be able to reconnect, it's best to have white-list advertising after the "pairable" window.
    Yes, this is true but only with Just Works pairing. You mentioned the device not having a display, but does it have any other IO capabilities for an Out-of-Band method? Refer to Bluetooth spec, Vol 3, Part H, Section 2.3.5.1, Selecting key generation method:
    It actually seems like the best option to me. Do you find something unfitting about it?
    There is. You can check if the current peer address is in the list of bonded devices.
    See:
    https://docs.nordicsemi.com/bundle/ncs-2.6.1/page/zephyr/connectivity/bluetooth/api/connection_mgmt.html#c.bt_conn_get_dst
    https://docs.nordicsemi.com/bundle/ncs-2.6.1/page/zephyr/connectivity/bluetooth/api/gap.html#c.bt_foreach_bond
  • Hi Hieu,
    E.g. I've been experimenting with struct bt_conn_auth_cb but not sure which is the best
    Just that there's a lot of callbacks in the structs and which ones are set seems to determine the IO capabilities and therefore the auth procedure and I find the wording in the doc a but vague on the implications.
    I think maybe pairing_accept() is the right one, but pairing_confirm() seems interesting too?
    And then there's the
    BT_CONN_CB_DEFINE() ones, if I can rely on only one device being connected at a time.
    Anyway I'll do some more experiments in the next couple of days and get back to you.
    Nothing obvious that I can see, e.g. there's no NFC or other way to talk to a phone except something crazy like pointing the phone camera at a LED. But I'll have a think.
    But that's the key question that's driving this - the doc is only talking about addresses, which can be faked easily.
    What's harder to fake (especially in LE secure connections) is the actual encryption key in use, but I haven't read anything that says the stack is checking that key matches the one in the bond list and the links you've given don't have a way for me to check that in my own app.
    I.e. I can't see anything that would prevent an attacker (that wasn't present at the initial bonding) from just spoofing the MAC and then negotiating a new key for the session.
    The only thing I can think of is that key negotiation is probably considered a "pair" and might still trigger one or more of the bt_conn_auth_cb calls even in JustWorks, and it those calls are _not_ triggered when a bonded device reuses the bond key (i.e. if a previously bonded device coming back in range is not a "pair") then we might be OK. But the doc isn't explicit on this so I'll still be nervous about it even if my experiments look good.
    I might end up having to read the full BLE spec, stack source, and maybe pentesting it, but it just feels like what I'm trying to do here must have been done before and that if it was actually a problem there'd be papers written on it already. I mean the UI is basically the BLE equivalent of one of the Bluetooth Classic dongles or hands-free and those _do_ have issues but I thought BLE was supposed to have fixed them?
  • Hi Bill,
    But if your device is advertising with Resolvable Random Private Address, then only the bonded peer with the agreed Identity Resolving Key can identify it and initiate a connection.
    Using Just Works, there is also nothing stopping a MITM from getting the agreed key. They don't even have to fake being the device and getting a new key.
    At the end of the day, vulnerability to MITM is an inherent issue when you use Just Works pairing. There is simply no way around it. Some secrets must be agreed on a different physical channel to defend against the MITM.
    I discussed some alternatives in a recent ticket:  Using Just Works mode with MITM protection.
