Cannot use Zephyr built-in mbedTLS library with nRF5340
I have implemented an application for nRF5340 chip derived from the Zephyr AWS IoT MQTT sample. The application is based on W5500 Ethernet driver so the idea is to work with AWS IoT over Ethernet. This sample uses the Zephyr built-in mbedTLS library and I can successfully compile and run my application for nRF52840 chip. So the code itself is fine. Although when I compile for nRF5340 I get Kconfig warnings, compile warnings and linker errors related to mbedTLS.
It is clear to me that CONFIG_NRF_SECURITY, despite being disabled in my prj.conf prevents the use of the built-in Zephyr mbedTLS library. Since it works fine for nRF52, I'd rather use the same approach but I am also happy to switch to the Nordic pre-built mbedTLS library if necessary as long as I do not need to modify the application code.
I have tried to fix the issue for hours with no luck so any help would be much appreciated.
Thank you. 7875.prj.conf
warning: NRF_SECURITY (defined at /Users/marcorussi/firmware/elimo/template-app-
aws/external/nrf/subsys/nrf_security/Kconfig:33) was assigned the value 'n' but got the value 'y'.
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NRF_SECURITY and/or look up
NRF_SECURITY in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: MBEDTLS_MEMORY_DEBUG (defined at /Users/marcorussi/firmware/elimo/template-app-
aws/external/nrf/subsys/nrf_security/Kconfig.tls:167, modules/mbedtls/Kconfig:163,
modules/mbedtls/Kconfig:163) was assigned the value 'y' but got the value 'n'. Check these
unsatisfied dependencies: ((MBEDTLS_TLS_LIBRARY && NRF_SECURITY) || (MBEDTLS_BUILTIN && MBEDTLS) ||
(MBEDTLS_BUILTIN && MBEDTLS && 0)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_MEMORY_DEBUG and/or look up
MBEDTLS_MEMORY_DEBUG in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: MBEDTLS_AES_ROM_TABLES (defined at /Users/marcorussi/firmware/elimo/template-app-
aws/external/nrf/subsys/nrf_security/Kconfig.legacy:421, modules/mbedtls/Kconfig.tls-generic:261,
modules/mbedtls/Kconfig.tls-generic:261) was assigned the value 'y' but got the value 'n'. Check
these unsatisfied dependencies: ((!(OBERON_BACKEND || CC3XX_BACKEND) && MBEDTLS_CIPHER_MODE_CBC &&
MBEDTLS_AES_C && MBEDTLS_LEGACY_CRYPTO_C && NRF_SECURITY) || (MBEDTLS_CIPHER_AES_ENABLED &&
!(NRF_SECURITY || NORDIC_SECURITY_BACKEND) && MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-
generic.h" && MBEDTLS) || (MBEDTLS_CIPHER_AES_ENABLED && !(NRF_SECURITY || NORDIC_SECURITY_BACKEND)
&& MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS && 0)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_AES_ROM_TABLES and/or look up
MBEDTLS_AES_ROM_TABLES in the menuconfig/guiconfig interface. The Application Development Primer,
helpful too.
warning: MBEDTLS_PEM_CERTIFICATE_FORMAT (defined at modules/mbedtls/Kconfig.tls-generic:403,
modules/mbedtls/Kconfig.tls-generic:403) was assigned the value 'y' but got the value 'n'. Check
these unsatisfied dependencies: ((MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" &&
MBEDTLS) || (MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS && 0)) (=n).
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT and/or
look up MBEDTLS_PEM_CERTIFICATE_FORMAT in the menuconfig/guiconfig interface. The Application
Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
the manual might be helpful too.
warning: MBEDTLS_SERVER_NAME_INDICATION (defined at modules/mbedtls/Kconfig.tls-generic:448,
modules/mbedtls/Kconfig.tls-generic:448) was assigned the value 'y' but got the value 'n'. Check
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SERVER_NAME_INDICATION and/or
look up MBEDTLS_SERVER_NAME_INDICATION in the menuconfig/guiconfig interface. The Application
warning: MBEDTLS_HAVE_TIME_DATE (defined at modules/mbedtls/Kconfig.tls-generic:460,
modules/mbedtls/Kconfig.tls-generic:460) was assigned the value 'y' but got the value 'n'. Check
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_HAVE_TIME_DATE and/or look up
MBEDTLS_HAVE_TIME_DATE in the menuconfig/guiconfig interface. The Application Development Primer,
helpful too.
warning: MBEDTLS_SSL_MAX_CONTENT_LEN (defined at modules/mbedtls/Kconfig:70,
modules/mbedtls/Kconfig:70) was assigned the value '16384' but got the value ''. Check these
unsatisfied dependencies: ((MBEDTLS_BUILTIN && MBEDTLS) || (MBEDTLS_BUILTIN && MBEDTLS && 0)) (=n).
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN and/or look
up MBEDTLS_SSL_MAX_CONTENT_LEN in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
warning: The choice symbol MBEDTLS_BUILTIN (defined at modules/mbedtls/Kconfig:28,
modules/mbedtls/Kconfig:28) was selected (set =y), but MBEDTLS_LIBRARY_NRF_SECURITY (defined at
/Users/marcorussi/firmware/elimo/template-app-aws/external/nrf/subsys/nrf_security/Kconfig:254)
ended up as the choice selection. See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_BUILTIN and/or look up
MBEDTLS_BUILTIN in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
warning: Experimental symbol NET_SOCKETS_SOCKOPT_TLS is enabled.
warning: Experimental symbol NET_CONNECTION_MANAGER is enabled.
----- Installing platform NS -----
[302/467] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_tls.c.obj
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c: In function 'tls_session_store':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:663:15: warning: implicit declaration of function 'mbedtls_ssl_get_session'; did you mean 'mbedtls_ssl_get_version'? [-Wimplicit-function-declaration]
  663 |         ret = mbedtls_ssl_get_session(&context->ssl, &session);
      |               mbedtls_ssl_get_version
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c: In function 'tls_session_restore':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:699:15: warning: implicit declaration of function 'mbedtls_ssl_set_session'; did you mean 'mbedtls_ssl_get_version'? [-Wimplicit-function-declaration]
  699 |         ret = mbedtls_ssl_set_session(&context->ssl, &session);
[459/467] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/marcorussi/firmware/elimo/template-app-aws/build/zephyr/zephyr_pre0.map
: && ccache /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  tfm/api_ns/interface/lib/s_veneers.o  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/Users/marcorussi/firmware/elimo/template-app-aws/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/picolibc/liblib__libc__picolibc.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/soc/arm/nordic_nrf/libsoc__arm__nordic_nrf.a  zephyr/boards/arm/nrf5340dk_nrf5340/libboards__arm__nrf5340dk_nrf5340.a  zephyr/subsys/random/libsubsys__random.a  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a  zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a  zephyr/subsys/bluetooth/crypto/libsubsys__bluetooth__crypto.a  zephyr/subsys/net/libsubsys__net.a  zephyr/subsys/net/l2/ethernet/libsubsys__net__l2__ethernet.a  zephyr/subsys/net/ip/libsubsys__net__ip.a  zephyr/subsys/net/lib/mqtt/libsubsys__net__lib__mqtt.a  zephyr/subsys/net/lib/dns/libsubsys__net__lib__dns.a  zephyr/subsys/net/conn_mgr/libsubsys__net__conn_mgr.a  zephyr/drivers/bluetooth/libdrivers__bluetooth.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/hwinfo/libdrivers__hwinfo.a  zephyr/drivers/mbox/libdrivers__mbox.a  zephyr/drivers/ethernet/libdrivers__ethernet.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/spi/libdrivers__spi.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a  modules/nrf/modules/trusted-firmware-m/lib..__nrf__modules__trusted-firmware-m.a  modules/nrf/modules/trusted-firmware-m/libtfm_api_nrf.a  modules/dali-if/drivers/misc/daliif/lib..__dali-if__drivers__misc__daliif.a  modules/dali-lib/modules/dalilib/lib..__dali-lib__modules__dalilib.a  modules/trusted-firmware-m/libtfm_api.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/libmetal/libmetal/lib/libmetal.a  modules/open-amp/open-amp/lib/libopen_amp.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp"  -L/Users/marcorussi/firmware/elimo/template-app-aws/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  -DPICOLIBC_LONG_LONG_PRINTF_SCANF  modules/nrf/subsys/nrf_security/src/libmbedcrypto.a  /Users/marcorussi/firmware/elimo/template-app-aws/external/nrfxlib/crypto/nrf_oberon/lib/cortex-m33/soft-float/liboberon_mbedtls_3.0.14.a  modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -mtp=soft  /Users/marcorussi/firmware/elimo/template-app-aws/external/nrfxlib/crypto/nrf_oberon/lib/cortex-m33/soft-float/liboberon_3.0.14.a  --specs=picolibc.specs  -lc  -lgcc && cd /Users/marcorussi/firmware/elimo/template-app-aws/build/zephyr && /opt/homebrew/Cellar/cmake/3.28.1/bin/cmake -E true
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_mbedtls_reset':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1138: undefined reference to `mbedtls_ssl_session_reset'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `ztls_poll_update_pollin':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:2875: undefined reference to `mbedtls_ssl_get_bytes_avail'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `ztls_socket_data_check':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:2838: undefined reference to `mbedtls_ssl_read'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:2865: undefined reference to `mbedtls_ssl_get_bytes_avail'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_mbedtls_init':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1268: undefined reference to `mbedtls_ssl_set_bio'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1279: undefined reference to `mbedtls_ssl_config_defaults'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1354: undefined reference to `mbedtls_ssl_conf_authmode'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1358: undefined reference to `mbedtls_ssl_conf_rng'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1370: undefined reference to `mbedtls_ssl_conf_ciphersuites'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1392: undefined reference to `mbedtls_ssl_setup'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `ztls_poll_prepare_pollin':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:2767: undefined reference to `mbedtls_ssl_get_bytes_avail'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:2767: undefined reference to `mbedtls_ssl_get_bytes_avail'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_mbedtls_handshake':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1171: undefined reference to `mbedtls_ssl_handshake'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_alloc':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:451: undefined reference to `mbedtls_ssl_init'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:452: undefined reference to `mbedtls_ssl_config_init'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_release':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:521: undefined reference to `mbedtls_ssl_config_free'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:522: undefined reference to `mbedtls_ssl_free'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `ztls_close_ctx':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:2043: undefined reference to `mbedtls_ssl_close_notify'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_session_restore':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:691: undefined reference to `mbedtls_ssl_session_init'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_session_get':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:636: undefined reference to `mbedtls_ssl_session_load'
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:705: undefined reference to `mbedtls_ssl_session_free'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_session_store':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:661: undefined reference to `mbedtls_ssl_session_init'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:663: undefined reference to `mbedtls_ssl_get_session'
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:699: undefined reference to `mbedtls_ssl_set_session'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_session_save':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:594: undefined reference to `mbedtls_ssl_session_save'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:602: undefined reference to `mbedtls_ssl_session_save'
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:675: undefined reference to `mbedtls_ssl_session_free'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `send_tls':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:2206: undefined reference to `mbedtls_ssl_write'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `recv_tls':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:2419: undefined reference to `mbedtls_ssl_read'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_opt_ciphersuite_list_get':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1535: undefined reference to `mbedtls_ssl_list_ciphersuites'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_opt_ciphersuite_used_get':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1563: undefined reference to `mbedtls_ssl_get_ciphersuite'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1568: undefined reference to `mbedtls_ssl_get_ciphersuite_id'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_opt_ciphersuite_list_set':
/Users/marcorussi/firmware/elimo/template-app-aws/external/zephyr/subsys/net/lib/sockets/sockets_tls.c:1517: undefined reference to `mbedtls_ssl_conf_ciphersuites'
collect2: error: ld returned 1 exit status
