I am using CJSON_LIB from nrf-sdk modules, I even tested this cjson lib in such a simple way in helloworld app (I attached the sample project.), and after running for a while, I have a no memory space issue, Any idea? I was expecting to free up the memory by running cJSON_Delete(root_obj); these cjson libs are used in the asset tracker application. So it means this issue is valid for atv2 app as well?, Could you please verify?
{"status":{"echo":"error_report->cmd_echo","cmd":"cmd2str(error_report->cmd)","sub_cmd":"dev_sub_cmd2str(error_report->sub_cmd.dev_sub_cmd)","step":"common_steps2str(error_report->step[error_report->dev_type])","result":"dev_result2str(error_report->result)"},"data":{"ret":"error_report->data.data_str","type":"type2str(error_report->type)"}}
2143
40 main.c
53 main.c
61 main.c
75 main.c
77 main.c
91 main.c
92 main.c
94 main.c
105 main.c
2144
40 main.c
53 main.c
61 main.c
75 main.c
77 main.c
91 main.c
92 main.c
94 main.c
105 main.c
2145
40 main.c
53 main.c
61 main.c
75 main.c
77 main.c
91 main.c
92 main.c
94 main.c
105 main.c
2146
40 main.c
53 main.c
61 main.c
75 main.c
77 main.c
91 main.c
92 main.c
94 main.c
105 main.c
2147
40 main.c
53 main.c
61 main.c
75 main.c
77 main.c
91 main.c
92 main.c
94 main.c
97 main.c
105 main.c
[00:03:45.874,000] <err> os: ***** BUS FAULT *****
[00:03:45.874,000] <err> os: Precise data bus error
[00:03:45.874,000] <err> os: BFAR Address: 0x0
[00:03:45.874,000] <err> os: r0/a1: 0x00000000 r1/a2: 0x0800bf3a r2/a3: 0x00000000
[00:03:45.874,000] <err> os: r3/a4: 0x00000000 r12/ip: 0x00007252 r14/lr: 0x08001f35
[00:03:45.874,000] <err> os: xpsr: 0x61000000
[00:03:45.874,000] <err> os: Faulting instruction address (r15/pc): 0x08000e32
[00:03:45.874,000] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
[00:03:45.874,000] <err> os: Current thread: 0x20002e20 (unknown)
[00:03:46.016,000] <err> fatal_error: Resetting system*** Booting nRF Connect SDK v3.6.0 ***
in the test app: I am printing encoded json data with a 100ms delay (just to see error quickly), after printing 2147 times, memory issue happpend
here is the code:
#define FILE_NAME "main.c"
struct usb_codec_data {
/** Encoded output. */
char *buf;
/** Length of encoded output. */
size_t len;
static void encode_json(struct usb_codec_data * usb_log)
int err = 0;
__ASSERT_NO_MSG(error_report != NULL);
cJSON *root_obj = cJSON_CreateObject();
cJSON *sub_obj = cJSON_CreateObject();
cJSON *data_obj = cJSON_CreateObject();
if (root_obj == NULL || sub_obj == NULL|| data_obj == NULL) {
printk("%d %s\n", __LINE__, FILE_NAME);
err = -ENOMEM;
goto exit;
err = json_add_str(sub_obj, CMD_ECHO, "error_report->cmd_echo");
if (err)
printk("Encoding error: %d returned at %s:%d\n", err, __FILE__, __LINE__);
goto exit;
err = json_add_str(sub_obj, CMD_FOR, "cmd2str(error_report->cmd)");
if (err)
goto exit;
err = json_add_str(sub_obj, CMD_SUB_FOR, "dev_sub_cmd2str(error_report->sub_cmd.dev_sub_cmd)");
if (err)
goto exit;
err = json_add_str(sub_obj, CMD_STEP, "common_steps2str(error_report->step[error_report->dev_type])");
if (err)
goto exit;
err = json_add_str(sub_obj, CMD_RESULT, "dev_result2str(error_report->result)");
if (err)
goto exit;
json_add_obj(root_obj, OBJECT_STATUS, sub_obj);
err = json_add_str(data_obj, CMD_RETURN_OBJ, "error_report->data.data_str");
if (err)
goto exit;
err = json_add_str(data_obj, CMD_RETURN_TYPE, "type2str(error_report->type)");
if (err)
goto exit;
json_add_obj(root_obj, OBJECT_DATA, data_obj);
char *buffer = cJSON_PrintUnformatted(root_obj);
if (buffer == NULL) {
err = -ENOMEM;
goto exit;
usb_log->buf = buffer;
usb_log->len = strlen(buffer);
exit:
return;
int i = 0;
k_msleep(10000);
while(1)
struct usb_codec_data usb_log = {0};
encode_json(&usb_log);
printk("%s\n",usb_log.buf);
printk("%d\n", i++);
k_msleep(100);
k_msleep(100);
// printf("Hello World! %s\n", CONFIG_BOARD);
// encode_json_log();
