AT+CPSMS returns ERROR
I am developing LTE-M software on nRF9160. Previously, I checked that it runs well with nRF9160DK. Now I try it with my own board.
First, only for testing, I made following program.
int main(void) {
    int err;
    err = nrf_modem_lib_init();
    return 0;
After start debugging, static int _nrf_modem_lib_init(void) on nrf/lib/nrf_modem_lib/nrf_modem_lib.c is called and modem is successfully initialized.
Next, static void on_modem_init(int err, void *ctx) on nrf/lib/lte_link_control/lte_lc_modem_hooks.c is called and:
	if (err) {
		LOG_ERR("Modem library init error: %d, lte_lc not initialized", err);
		return;
	/* Request configured PSM and eDRX settings to save power. */
	err = lte_lc_psm_req(IS_ENABLED(CONFIG_LTE_PSM_REQ));
	if (err) {
		LOG_ERR("Failed to configure PSM, err %d", err);
		return;
int lte_lc_psm_req(bool enable) on nrf/lib/lte_link_control/lte_lc.c is called subsequently.
	int err;
	if (enable) {
		if (strlen(psm_param_rptau) == 8 &&
		    strlen(psm_param_rat) == 8) {
			err = nrf_modem_at_printf("AT+CPSMS=1,,,\"%s\",\"%s\"",
						  psm_param_rptau,
						  psm_param_rat);
		} else if (strlen(psm_param_rptau) == 8) {
			err = nrf_modem_at_printf("AT+CPSMS=1,,,\"%s\"", psm_param_rptau);
		} else if (strlen(psm_param_rat) == 8) {
			err = nrf_modem_at_printf("AT+CPSMS=1,,,,\"%s\"", psm_param_rat);
		} else {
			err = nrf_modem_at_printf("AT+CPSMS=1");
	} else {
		err = nrf_modem_at_printf(psm_disable);
	if (err) {
		LOG_ERR("nrf_modem_at_printf failed, reported error: %d", err);
		return -EFAULT;
	return 0;
In prj.conf, CONFIG_LTE_PSM_REQ=y is set. Following values are checked with debugger:
psm_param_rptau = "00000011",  psm_param_rat = "00100001".
I don't know why, nrf_modem_at_printf("AT+CPSMS=1,,,\"%s\",\"%s\"", psm_param_rptau, psm_param_rat) returns 65536.
prf.conf:
CONFIG_LOG=y
CONFIG_RTT_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_ASSERT=y
CONFIG_REBOOT=y
CONFIG_LTE_LINK_CONTROL=y
CONFIG_AT_HOST_LIBRARY=y
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC=y
CONFIG_NRF_MODEM_LIB_TRACE=n
CONFIG_MODEM_INFO=y
CONFIG_MODEM_INFO_ADD_NETWORK=y
CONFIG_PDN=y
CONFIG_PDN_ESM_STRERROR=y
CONFIG_MODEM=y
CONFIG_MODEM_MODULES=y
CONFIG_NRFX_PDM=y
Why nrf_modem_at_printf() fails? What items should I check?
