nrf_drv_saadc_abort doesn't raise SAADC DONE task
I have an application where I am using the SAADC to take ADC samples. At any point during the measurements, I want to be able to stop the samples prior to the ADC buffer filling completely. I've created a mock project of the general issue shown where the app_timer callback successfully calls the SAADC abort, however I don't receive a DONE task as the function description declares it does.
This is using the BLE SoftDevice as my intention is to essentially start ADC sampling from a BLE command. I will also be having a BLE command to provide an early stop to the measurements as well as activity detection to stop ADC sampling during movement, then resume afterwards (hence a timer interrupt occurs to stop the sampling as an expected time the ADC sampling would have completed if no activity was detected).
 * @brief Function for aborting the ongoing and buffered conversions.
 * @note @ref NRFX_SAADC_EVT_DONE event will be generated if there is a conversion in progress.
 *       Event will contain number of words in the sample buffer.
 * @warning This function must not be called from the context of event handler of the SAADC driver
 *          or from the context of interrupt with priority equal to or higher than priority
 *          of the SAADC interrupt.
void nrfx_saadc_abort(void);
Based on the above @warning I have attempted to use the abort directly from main() as well as ensuring the app_timer interrupt is a lower priority without success.
I have attached a dummy project based on the BLE App Template where I added the SAADC example where I also added an App Timer to abort the measurements early.
Any thoughts on the SAADC abort is not raising the DONE task or what I'm doing wrong here?
0654.ble_app_template.zip
  • A little more info: I do observe the SAADC stop sampling, but I am not receiving a NRF_DRV_SAADC_EVT_DONE SAADC event in my saadc_callback handler as I would expect.
    I'm guessing that your basing your assumption on this comment regarding the driver function:
    NRFX_SAADC_EVT_DONE is a HW event that isn't propagated to the application in this case. Calling nrfx_saadc_abort() will trigger the task NRF_SAADC_TASK_STOP which again will generate the NRF_SAADC_EVENT_STOPPED.
    regards
    Jared
  • Thanks for the info!
    I need to be able to cause an early stop using while still knowing how many samples were taken during the period before nrfx_saadc_abort was called. For example, my sampling period fills a buffer of 512 ADC measurements. If the abort is called and only 300 measurements were taken, I need to know this number and be able to still convert the 300 measurements with nrfx_saadc_buffer_convert. Do you have a suggestion on how I would accomplish this if nrfx_saadc_abort does not propogate the HW event to the application?
    When you call nrfx_saadc_abort() it will effectively call trigger the NRF_SAADC_TASK_STOP task which will eventually result in the EVENTS_STOPPED to be generated. When that event has been generated, you can check the RESULT.AMOUNT register to see how many samples that has been transferred to RAM.
    regards
    Jared
  • This is true that this works to get the last frame's number of samples. However, my 512 measurements are occurring from my SAADC being connected to a timer through the PPI to measure at a specific frequency. With this, each measurement is triggering a START then STOP event in the SAADC. Consequently, when I call nrf_saadc_amount_get() to read the RESULT.AMOUNT register, I am only receiving a value from the last measurement interval. For example, I have 3 SAADC channels, so whenever I read RESULT.AMOUNT, my value is either 3 or occasionally 6.
