testing nf5340_audio_dk
I am trying to use the nrf5340 audio DK for the first time using one of the sample blink codes. I keep getting an error when first creating an application by copying the sample provided. The system seems to be missing a board information and I could not figure out where and how to provide that information. My system configuration and versions of my tools are given below. I am beginning to wonder if my installation is ok as some of the folders are different from the nrfConnect instruction videos from Nordic which  were for a Windows PC.
My Toolchain is 2.6.1 at /opt/Nordic/ncs/toolchains
My SDK is 2.6.1 at /opt/Nordic/ncs/v2.6.1
My applications are in user/name/ncs/
MacBook Pro 2.9ghz quad core i7
16GB RAM Mac OS13.6.7
VS Code
Version: 1.90.1
Commit: 611f9bfce64f25108829dd295f54a6894e87339d
Date: 2024-06-11T21:02:41.372Z
Electron: 29.4.0
ElectronBuildId: 9593362
Chromium: 122.0.6261.156
Node.js: 20.9.0
V8: 12.2.281.27-electron.0
OS: Darwin x64 22.6.0
The error I am getting is below. Apologies for the long text captured and pasted. Can someone help?
CMake Error at /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/extensions.cmake:2891 (message):BOARD is not being defined on the CMake command-line, in the environment or
by the app.
"resource": "/opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/extensions.cmake",
"owner": "cmake-configure-diags",
"severity": 8,
"message": "CMake Error at /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/extensions.cmake:2891 (message):BOARD is not being defined on the CMake command-line, in the environment or\nby the app.",
"source": "CMake (message)",
"startLineNumber": 2891,
"startColumn": 1,
"endLineNumber": 2891,
"endColumn": 10000,
"relatedInformation": [
"startLineNumber": 56,
"startColumn": 1,
"endLineNumber": 56,
"endColumn": 1000,
"message": "In call to 'zephyr_check_cache' here",
"resource": "/opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/boards.cmake"
"startLineNumber": 129,
"startColumn": 1,
"endLineNumber": 129,
"endColumn": 1000,
"message": "In call to 'include' here",
"resource": "/opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/zephyr_default.cmake"
"startLineNumber": 66,
"startColumn": 1,
"endLineNumber": 66,
"endColumn": 1000,
"resource": "/opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake"
"startLineNumber": 159,
"startColumn": 1,
"endLineNumber": 159,
"endColumn": 1000,
"message": "In call to 'include_boilerplate' here",
"startLineNumber": 4,
"startColumn": 1,
"endLineNumber": 4,
"endColumn": 1000,
"message": "In call to 'find_package' here",
"resource": "/Users/assegid/ncs/blinky/CMakeLists.txt"
  • Hi Andreas,
    I have now abandoned using Visual Studio Code and simply using the python script in zsh editing the json file and the prj.conf file as needed. When I was using VS Code, I was using the nrf Connect terminal within VS Code. I have also tried the other terminals in the list.
  • Noted,
    Thank you for verifying that the behavior was present in either ways to open the terminal.
    assegid said:
    Please confirm my boards are older engineering versions, I have attached a picture showing version, production date and serial numbers.
    The boards seems to be of a new enough revision.
    For now, does this resolve the original issue in this case?
    If so we'll mark your case as resolved and as always please feel free to open new cases for new queries and questions
    Andreas
