testing nf5340_audio_dk
I am trying to use the nrf5340 audio DK for the first time using one of the sample blink codes. I keep getting an error when first creating an application by copying the sample provided. The system seems to be missing a board information and I could not figure out where and how to provide that information. My system configuration and versions of my tools are given below. I am beginning to wonder if my installation is ok as some of the folders are different from the nrfConnect instruction videos from Nordic which  were for a Windows PC.
My Toolchain is 2.6.1 at /opt/Nordic/ncs/toolchains
My SDK is 2.6.1 at /opt/Nordic/ncs/v2.6.1
My applications are in user/name/ncs/
MacBook Pro 2.9ghz quad core i7
16GB RAM Mac OS13.6.7
VS Code
Version: 1.90.1
Commit: 611f9bfce64f25108829dd295f54a6894e87339d
Date: 2024-06-11T21:02:41.372Z
Electron: 29.4.0
ElectronBuildId: 9593362
Chromium: 122.0.6261.156
Node.js: 20.9.0
V8: 12.2.281.27-electron.0
OS: Darwin x64 22.6.0
The error I am getting is below. Apologies for the long text captured and pasted. Can someone help?
CMake Error at /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/extensions.cmake:2891 (message):BOARD is not being defined on the CMake command-line, in the environment or
by the app.
"resource": "/opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/extensions.cmake",
"owner": "cmake-configure-diags",
"severity": 8,
"message": "CMake Error at /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/extensions.cmake:2891 (message):BOARD is not being defined on the CMake command-line, in the environment or\nby the app.",
"source": "CMake (message)",
"startLineNumber": 2891,
"startColumn": 1,
"endLineNumber": 2891,
"endColumn": 10000,
"relatedInformation": [
"startLineNumber": 56,
"startColumn": 1,
"endLineNumber": 56,
"endColumn": 1000,
"message": "In call to 'zephyr_check_cache' here",
"resource": "/opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/boards.cmake"
"startLineNumber": 129,
"startColumn": 1,
"endLineNumber": 129,
"endColumn": 1000,
"message": "In call to 'include' here",
"resource": "/opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/zephyr_default.cmake"
"startLineNumber": 66,
"startColumn": 1,
"endLineNumber": 66,
"endColumn": 1000,
"resource": "/opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake"
"startLineNumber": 159,
"startColumn": 1,
"endLineNumber": 159,
"endColumn": 1000,
"message": "In call to 'include_boilerplate' here",
"startLineNumber": 4,
"startColumn": 1,
"endLineNumber": 4,
"endColumn": 1000,
"message": "In call to 'find_package' here",
"resource": "/Users/assegid/ncs/blinky/CMakeLists.txt"
    Could you open your VS Code command pallette (ctrl/cmd +  shift + p) and generate support information and paste it here? You can avoid longer text snippets by using the insert -> code feature as seen below:
    It seems like that the board is not defined when you're building. Could you describe the procedure you go through when trying to build the firmware?
    Does the issue persist if you add the SDK folder into your workspace as seen below?
    Andreas
  • Hi Andreas, I simply used Create a new application in Visual Studio Code and then copied the sample provided for the nrf5340_audio_dk and created a build using the dafault settings. I have attached the support file generated as you requested. I was unable to add the SDK folder to the workspace because the /opt folder where the SDK is in was not available in the add folder dialog window. Do you want me to copy the SDK folder and paste it in the application folder and try?
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "darwin",
        "osVersion": "Darwin Kernel Version 22.6.0: Mon Apr 22 20:54:28 PDT 2024; root:xnu-8796.141.3.705.2~1/RELEASE_X86_64",
        "osKernel": "22.6.0",
        "vscode": "1.90.1",
        "electron": "29.4.0",
        "node": "v20.9.0"
      "system": {
        "date": "2024-06-18T05:22:20.847Z",
        "vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
        "vscodeUptime": "00:11:28",
        "osUptime": "32:40:15",
        "cpu": "Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz"
      "workspace": {
        "name": "nrf5340_audio (Workspace)",
        "workspaceFile": "/Users/assegid/ncs/nrf5340_audio/nrf5340_audio.code-workspace",
        "folders": [
          "/Users/assegid/ncs/nrf5340_audio"
      "sdks": [
          "version": "v2.6.1",
          "path": "/opt/nordic/ncs/v2.6.1"
      "activeBuild": "/Users/assegid/ncs/nrf5340_audio/buildAsIs",
      "apps": [
          "workspace": "/Users/assegid/ncs/nrf5340_audio",
          "uri": "/Users/assegid/ncs/nrf5340_audio",
          "buildConfigurations": [
              "id": "/Users/assegid/ncs/nrf5340_audio/buildAsIs",
              "name": "buildAsIs",
              "boardId": "nrf5340_audio_dk_nrf5340_cpuapp",
              "type": "Zephyr",
              "isChild": false,
              "isStale": false,
              "taskBindings": {
                "build": [],
                "pristineBuild": [],
                "flash": [],
                "eraseAndFlash": []
      "topdir": "/opt/nordic/ncs/v2.6.1",
      "workspaceState": "freestanding-ready",
      "toolchains": [
          "version": "2.6.1",
          "path": "/opt/nordic/ncs/toolchains/580e4ef81c"
      "connectedDevices": [
          "serialNumber": "001050124819"
      "deviceProvider": "nrfutil",
      "tools": {
        "/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.16.5",
        "/Applications/SEGGER/JLink/JLinkExe": "7.94e",
        "/usr/local/bin/nrfjprog": null,
        "nrfutil": "Not found",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/cmake": "3.21.0",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/west": "1.2.0",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/python3": "3.9.6",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/ninja": "1.10.2",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/gperf": "3.1",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc": "1.6.1",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/gn": "2154",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/git": "2.37.3",
        "gdbPath": "/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb"
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.0.0",
          "binPath": "/Users/assegid/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.3.25-darwin-x64/platform/nrfutil/bin/nrfutil-device"
        "nrfutil-toolchain-manager": {
          "version": "0.14.1",
          "binPath": "/Users/assegid/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.3.25-darwin-x64/platform/nrfutil/bin/nrfutil-toolchain-manager"
      "environment": {
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/580e4ef81c/Cellar/git/2.37.3/libexec/git-core",
          "HOME": "/Users/assegid",
          "PATH": "/opt/nordic/ncs/toolchains/580e4ef81c/bin:/opt/nordic/ncs/toolchains/580e4ef81c/usr/bin:/opt/nordic/ncs/toolchains/580e4ef81c/usr/local/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/nanopb/generator-bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/aarch64-zephyr-elf/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/x86_64-zephyr-elf/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/riscv64-zephyr-elf/bin:/Library/Frameworks/Python.framework/Versions/3.10/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/share/dotnet:/opt/X11/bin:~/.dotnet/tools:/Library/Apple/usr/bin:/Applications/Wireshark.app/Contents/MacOS:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Frameworks/Python.framework/Versions/3.10/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/share/dotnet:/opt/X11/bin:~/.dotnet/tools:/Library/Apple/usr/bin:/Applications/Wireshark.app/Contents/MacOS:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin",
          "ZEPHYR_BASE": "/opt/nordic/ncs/v2.6.1/zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk",
          "USER": "assegid"
        "inherited": {
          "PATH": "/Library/Frameworks/Python.framework/Versions/3.10/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/share/dotnet:/opt/X11/bin:~/.dotnet/tools:/Library/Apple/usr/bin:/Applications/Wireshark.app/Contents/MacOS:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin",
          "USER": "assegid"
        "toolchainPath": "/opt/nordic/ncs/toolchains/580e4ef81c",
        "toolchainBinPath": "/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin",
        "toolchainVersion": "2.6.1"
      "terminal": {
        "defaultProfile": null
      "config": {
          "topdir": "",
          "toolchain": {
            "path": ""
          "ozonePath": "",
          "applications": [],
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "buildTerminal": {
            "condensedProgress": true
          "debugging": {
            "flash": true,
            "bindings": {},
            "justMyCode": true
          "deviceProvider": "",
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
          "enableTelemetry": null,
          "thirdpartyIntegration": {},
          "toolchainManager": {
            "indexURL": null,
            "installDirectory": null
          "nrfutil": {
            "home": null
          "defaultOpenAction": "ask"
          "terminalMode": "character"
      "extensions": {
        "internal": {
            "version": "2024.3.25",
            "path": "/Users/assegid/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.3.25-darwin-x64",
            "isActive": true
            "version": "2024.3.15",
            "path": "/Users/assegid/.vscode/extensions/nordic-semiconductor.nrf-terminal-2024.3.15",
            "isActive": true
            "version": "2024.3.78",
            "path": "/Users/assegid/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2024.3.78",
            "isActive": true
            "version": "2024.3.21",
            "path": "/Users/assegid/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2024.3.21",
            "isActive": true
        "external": {
          "marus25.cortex-debug": null,
          "ms-vscode.cpptools": "1.20.5",
          "ms-vscode.js-debug": "1.90.0",
          "ms-vscode.js-debug-companion": "1.1.2",
          "ms-vscode.vscode-js-profile-table": "1.0.9",
          "devicescript.devicescript-vscode": "2.16.2",
          "espressif.esp-idf-extension": "1.7.1",
          "ms-vscode-remote.remote-containers": "0.369.0",
          "ms-vscode.cmake-tools": "1.18.42",
          "platformio.aceinna-ide": "0.1.2",
          "platformio.platformio-ide": "3.3.3",
          "raspberry-pi.raspberry-pi-pico": "0.13.1",
          "twxs.cmake": "0.0.17"
    You should be able to add the NCS folder to your Favourites
    And from there add your Favourite folder directly in Finder making the SDK folder be available. Let me know if this is an option for you
    I assume you don't see the same behavior with different samples from the SDK? Could you verify this?
    Andreas
  • Ok, first I will attach the generate support data from my last attempt.
      "platform": {
        "os": "darwin",
        "vscode": "1.90.1",
        "node": "v20.9.0"
      "system": {
        "date": "2024-06-18T11:28:53.518Z",
        "vscodeUptime": "00:34:14",
        "osUptime": "38:46:47",
      "workspace": {
        "folders": [
      "sdks": [
      "activeBuild": "/Users/assegid/ncs/nrf5340_audio/buildAsis_bcast",
      "apps": [
              "id": "/Users/assegid/ncs/nrf5340_audio/buildAsis_bcast",
              "name": "buildAsis_bcast",
              "type": "Zephyr",
              "isChild": false,
              "isStale": false,
              "taskBindings": {
                "build": [],
                "flash": [],
                "eraseAndFlash": []
      "workspaceState": "mixed-ready",
      "toolchains": [
          "version": "2.6.1",
          "serialNumber": "001050124819",
          "boardVersion": "PCA10121",
          "deviceFamily": "NRF53_FAMILY",
          "deviceVersion": "NRF5340_xxAA_ENGD",
          "jlinkObFirmwareVersion": "J-Link OB-nRF5340-NordicSemi compiled Oct 30 2023 12:13:06"
      "tools": {
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.0.0",
      "environment": {
        "westEnv": {
          "USER": "assegid"
        "inherited": {
          "USER": "assegid"
      "terminal": {
      "config": {
          "topdir": "",
          "toolchain": {
            "path": ""
          "ozonePath": "",
          "applications": [],
          "kconfig": {
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "buildTerminal": {
          "debugging": {
            "flash": true,
            "bindings": {},
            "justMyCode": true
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
            "indexURL": null,
          "nrfutil": {
            "home": null
      "extensions": {
        "internal": {
            "isActive": true
            "isActive": true
            "isActive": true
            "isActive": true
        "external": {
    Next, I have attached the capture of what I get when I first create the application by copying the provided sample.
    Next is a capture showing I was able to add the SDK folder to the wokspace as advised.
    The next capture is what I got when I attempted to flash the board anyway(knowing it would not work)
    Lastly, the results were similar. when I attempted to test the board with the much simpler Blink example provided.
  • Thank you for providing these images. I will go through them and try to see if I am able to recreate what you're seeing. I'll get back to you with an update tomorrow (Wednsday).
    Andreas
